2nd September 2008, 15:15 | #902 | Link |
Sorry. I talked about my build. The problem arises when I use make fprofiled with gcc version 4.4.0 20080822 (experimental) (GCC). Standard build raises the same error. I try update my gcc from svn...
2nd September 2008, 15:18 | #903 | Link |
x264 developer
Ah. Have you pinpointed exactly where gcc is miscompiling the code? It'd be useful to know just as a warning for where to potentially look in the future, as the absolute most nightmarish of bugs are the ones caused by miscompilation.
2nd September 2008, 15:27 | #904 | Link |
I found only one problem before with profiling VFW-version of x264. After profiling in "common/common.c" in function "x264_log"
h->param.pf_log( h->param.p_log_private, i_level, psz_fmt, arg ); Code:
x264_log_default( h->param.p_log_private, i_level, psz_fmt, arg ); P.S. This misunderstanding has helped find BugMaster. Last edited by komisar; 2nd September 2008 at 15:32. |
2nd September 2008, 16:27 | #905 | Link |
Compiling Encoder
no wonder, i tried compiling some stuff with gcc 4.4.0 and kept getting seg faults from the cpu id asm method when trying to run it.
definitely shouldn't use it right now, imo. quarkfusion: I haven't been able to reproduce such lack of playback on any of those settings, granted i don't really have any video files of that resolution for that length. Last edited by kemuri-_9; 2nd September 2008 at 16:41. |
2nd September 2008, 16:57 | #907 | Link |
Mr. Sandman
then use a stable GCC version...
2nd September 2008, 17:31 | #910 | Link |
Mr. Sandman
komisar, then you need to start a new thread and discuss gcc 4.4 problems there since it's not a x264 problem...
also, your statement made ppl think it was a x264 problem while it was a gcc one... that means confusion... you should provide those info to the GCC devs not the x264 devs.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 2nd September 2008 at 18:44. |
2nd September 2008, 17:49 | #911 | Link | |
I believe that the correct spelling of code for different versions of compilers are also important. |
2nd September 2008, 18:45 | #912 | Link |
Mr. Sandman
coz gcc 4.4 is still not released... it's beta or whatever you wanna call it so it's not a matter of "code spelling" but just a plain compiler bug and that has nothing in common with x264.
3rd September 2008, 01:38 | #913 | Link |
Compiling Encoder
altered to to include kb/s like in r957 and fix rejections:
apply via patch -p 1 -i x264_progress.indication_r957.diff x264_progress.indication_r957.diff |
3rd September 2008, 02:43 | #914 | Link |
x264.957.modified.exe - Alternate Download
Patches used: x264_psy_rdo_0.6_r956.diff <-- One line change from r953's patch to get rid of that oh-so-scary fuzz warning. x264_new_bframe_decision_04.7.diff <-- Enable with --b-adapt 2. Random code removal fixed in this patch. x264_hrd_pulldown.09_interlace.diff x264_progress.indication_r957.diff <-- Thanks, kemuri. gcc 3.4.5 fprofiled build. |
3rd September 2008, 05:26 | #915 | Link |
rang_x264_r957
Thanks to kemuri for the fixed progress indication patch!
Home Direct download, Mirrors Code:
x264 r957 from Git (patched). Compiled by Ranguvar on September 3rd, 2008, with GCC 4.3.2 on Windows XP Professional x64 SP2. I have removed the non-AMD build, because the AMD build is of equal speed or faster than the non-AMD one in all of my tests so far - even on non-AMD hardware. Why? Who knows. But you don't need to worry about it. Open this archive with the free, multi-platform tools 7-Zip or p7zip. Compressed with LZMA. The src folder contains the patched source code. The bin folder contains a binary executable, and a DLL for those apps that use them (NOT for AviDemux - get those from LoRd_MuldeR). Git: git://git.videolan.org/x264.git Info, and source tarballs: http://www.videolan.org/developers/x264.html Changelog: http://git.videolan.org/gitweb.cgi?p=x264.git Vanilla builds: http://x264.nl/ Discussion: http://forum.doom9.org/forumdisplay.php?f=77 http://forum.doom9.org/showthread.php?t=130364 Applied patches (included, unchanged, in the patches folder): patch -p1 < ../x264diffs/x264_dll_alignment_fix.01.diff patch < ../x264diffs/x264_progress.indication_r957.diff patch -p1 < ../x264diffs/x264_hrd_pulldown.09_interlace.diff patch -p1 < ../x264diffs/x264_psy_rdo_0.6_r953.diff patch -p1 < ../x264diffs/x264_new_bframe_decision_04.7.diff CLI used for build: ./configure --enable-shared --extra-cflags="-march=athlon -pipe" make fprofiled VIDS="../enctests/deadline_cif.y4m" Platform: X86 System: MINGW asm: yes avis input: yes mp4 output: yes pthread: yes gtk: no debug: no gprof: no PIC: no shared: yes visualize: no |
3rd September 2008, 08:53 | #916 | Link |
Strictly Rhythm
x264_x86_r957_techouse
Source: x264 r957 GIT (git://git.videolan.org/x264.git) Applied patches (current versions): x264_progress.indication_r957.diff x264_psy_rdo.0.6_r957.diff x264_hrd_pulldown.09_interlace.diff x264_new_bframe_decision_04.7.diff Please check http://forum.doom9.org/showthread.php?t=130364 and http://git.videolan.org/gitweb.cgi?p=x264.git;a=shortlog for more info Compiled by techouse on September 3rd 2008, 09:39:49 CEST with GCC-4.3.2 on Windows Vista Business SP-1 64-bit. Commandline used: ./configure --extra-cflags="-march=core2 -pipe" && make fprofiled Platform: X86 System: MINGW asm: yes avis input: yes mp4 output: yes pthread: yes gtk: no debug: no gprof: no PIC: no shared: no visualize: no
3rd September 2008, 09:55 | #917 | Link | |
3rd September 2008, 10:05 | #918 | Link |
I know... But on my system "02 Sep" svn release building with error. And I switch to gcc 4.3.2... When I make worked build of gcc 4.4 -- I continue my finding.
4th September 2008, 17:59 | #919 | Link |
I am just wondering if the x264_fix_extended_zones.diff by VFR maniac is still needed or is the problem with using zone option he mentioned fixed?
diff --git a/common/common.h b/common/common.h index ca555d1..4b18486 100644 --- a/common/common.h +++ b/common/common.h @@ -584,6 +584,12 @@ struct x264_t } stat; + struct + { + int b_interlaced_esa; + int b_interlaced_temporal; + } warn; + /* CPU functions dependents */ x264_predict_t predict_16x16[4+3]; x264_predict_t predict_8x8c[4+3]; diff --git a/encoder/encoder.c b/encoder/encoder.c index ad7151c..42c16fb 100644 --- a/encoder/encoder.c +++ b/encoder/encoder.c @@ -328,7 +328,7 @@ static void x264_bitstream_check_buffer( x264_t *h ) * ****************************************************************************/ -static int x264_validate_parameters( x264_t *h ) +static int x264_validate_parameters( x264_t *h, int b_zone ) { #ifdef HAVE_MMX if( !(x264_cpu_detect() & X264_CPU_MMXEXT) ) @@ -363,7 +363,8 @@ static int x264_validate_parameters( x264_t *h ) if( h->param.i_threads > 1 ) { #ifndef HAVE_PTHREAD - x264_log( h, X264_LOG_WARNING, "not compiled with pthread support!\n"); + if ( !b_zone ) + x264_log( h, X264_LOG_WARNING, "not compiled with pthread support!\n"); h->param.i_threads = 1; #else if( h->param.i_scenecut_threshold >= 0 ) @@ -375,12 +376,20 @@ static int x264_validate_parameters( x264_t *h ) { if( h->param.analyse.i_me_method >= X264_ME_ESA ) { - x264_log( h, X264_LOG_WARNING, "interlace + me=esa is not implemented\n" ); + if ( !h->warn.b_interlaced_esa ) + { + x264_log( h, X264_LOG_WARNING, "interlace + me=esa is not implemented\n" ); + h->warn.b_interlaced_esa = 1; + } h->param.analyse.i_me_method = X264_ME_UMH; } if( h->param.analyse.i_direct_mv_pred > X264_DIRECT_PRED_SPATIAL ) { - x264_log( h, X264_LOG_WARNING, "interlace + direct=temporal is not implemented\n" ); + if ( !h->warn.b_interlaced_temporal ) + { + x264_log( h, X264_LOG_WARNING, "interlace + direct=temporal is not implemented\n" ); + h->warn.b_interlaced_temporal = 1; + } h->param.analyse.i_direct_mv_pred = X264_DIRECT_PRED_SPATIAL; } } @@ -424,7 +433,7 @@ static int x264_validate_parameters( x264_t *h ) h->param.rc.i_qp_min = x264_clip3( h->param.rc.i_qp_min, 0, h->param.rc.i_qp_max ); if( ( h->param.i_width % 16 || h->param.i_height % 16 ) - && h->param.i_height != 1080 && !h->mb.b_lossless ) + && h->param.i_height != 1080 && !h->mb.b_lossless && !b_zone ) { // There's nothing special about 1080 in that the warning still applies to it, // but chances are the user can't help it if his content is already 1080p, @@ -491,7 +500,7 @@ static int x264_validate_parameters( x264_t *h ) if( h->param.rc.f_aq_strength <= 0 ) h->param.rc.i_aq_mode = 0; /* VAQ effectively replaces qcomp, so qcomp is raised towards 1 to compensate. */ - if( h->param.rc.i_aq_mode == X264_AQ_GLOBAL ) + if( h->param.rc.i_aq_mode == X264_AQ_GLOBAL && !b_zone ) h->param.rc.f_qcompress = x264_clip3f(h->param.rc.f_qcompress + h->param.rc.f_aq_strength / 0.7, 0, 1); h->param.analyse.i_noise_reduction = x264_clip3( h->param.analyse.i_noise_reduction, 0, 1<<16 ); @@ -604,7 +613,7 @@ x264_t *x264_encoder_open ( x264_param_t *param ) /* Create a copy of param */ memcpy( &h->param, param, sizeof( x264_param_t ) ); - if( x264_validate_parameters( h ) < 0 ) + if( x264_validate_parameters( h, 0 ) < 0 ) { x264_free( h ); return NULL; @@ -798,6 +807,10 @@ int x264_encoder_reconfig( x264_t *h, x264_param_t *param ) COPY( analyse.b_dct_decimate ); COPY( analyse.b_fast_pskip ); COPY( analyse.b_mixed_references ); + // COPY( rc.f_ip_factor ); + // COPY( rc.f_pb_factor ); + COPY( rc.i_aq_mode ); + COPY( rc.f_aq_strength ); // can only twiddle these if they were enabled to begin with: if( h->pps->b_transform_8x8_mode ) COPY( analyse.b_transform_8x8 ); @@ -807,7 +820,7 @@ int x264_encoder_reconfig( x264_t *h, x264_param_t *param ) mbcmp_init( h ); - return x264_validate_parameters( h ); + return x264_validate_parameters( h, 1 ); } /* internal usage */ diff --git a/encoder/ratecontrol.c b/encoder/ratecontrol.c index 1d41200..c0a61fb 100644 --- a/encoder/ratecontrol.c +++ b/encoder/ratecontrol.c @@ -569,7 +569,8 @@ int x264_ratecontrol_new( x264_t *h ) static int parse_zone( x264_t *h, x264_zone_t *z, char *p ) { int len = 0; - char *tok, *saveptr; + int i, j = 0; + char *tok, *buff; z->param = NULL; z->f_bitrate_factor = 1; if( 3 <= sscanf(p, "%u,%u,q=%u%n", &z->i_start, &z->i_end, &z->i_qp, &len) ) @@ -586,11 +587,32 @@ static int parse_zone( x264_t *h, x264_zone_t *z, char *p ) p += len; if( !*p ) return 0; + + /* Parse some options. */ + if( p[0] != ',' ) + return -1; + else + buff = ++p; z->param = malloc( sizeof(x264_param_t) ); memcpy( z->param, &h->param, sizeof(x264_param_t) ); - while( (tok = strtok_r( p, ",", &saveptr )) ) + while( *buff ) { - char *val = strchr( tok, '=' ); + char *val; + tok = x264_malloc( strlen(buff)+1 ); + memset( tok, 0, sizeof(tok) ); + for( i = 0; p[j] != ',' && *buff; i++ ) + { + tok[i] = p[j++]; + buff++; + } + if ( !*tok ) + { + x264_free( tok ); + return -1; + } + tok[i] = '\0'; + j++; + val = strchr( tok, '=' ); if( val ) { *val = '\0'; @@ -599,9 +621,10 @@ static int parse_zone( x264_t *h, x264_zone_t *z, char *p ) if( x264_param_parse( z->param, tok, val ) ) { x264_log( h, X264_LOG_ERROR, "invalid zone param: %s = %s\n", tok, val ); + x264_free( tok ); return -1; } - p = NULL; + x264_free( tok ); } return 0; } |
5th September 2008, 08:27 | #920 | Link |
Problem with --no-cabac in profiling gcc 4.4.0 solved (Thnx BugMaster). GCC 4.4.0 wrong inline function bs_write_vlc in cavlc.c. I change this with define:
#define bs_write_vlc(a,b) bs_write(a, b.i_size, b.i_bits) /*static inline void bs_write_vlc( bs_t *s, vlc_t v ) { bs_write( s, v.i_size, v.i_bits ); }*/ Comparing gcc profiling: Code:
x264.gcc433.pf.exe --crf 26 --no-cabac --trellis 2 --ref 4 --bframes 3 --subme 6 --me umh --threads 1 --thread-input encoded 20 frames, 6.96 fps, 4719.71 kb/s x264.gcc440.pf.exe --crf 26 --no-cabac --trellis 2 --ref 4 --bframes 3 --subme 6 --me umh --threads 1 --thread-input encoded 20 frames, 10.49 fps, 4719.71 kb/s |
h.264, x264, x264 builds, x264 patches, x264 unofficial builds |
