23rd May 2010, 22:31 | #11782 | Link |
24th May 2010, 01:01 | #11783 | Link |
契約者
Yep, seems to be fixed. Thank you!
EDIT: however if "add tray icon menu to player's stream/languages menu" is active and i'm trying to turn on/off subtitles - MPC-HC with ffdshow crashes. EDIT2: or better to say this option now has no effect. Tray icon menu always there. If I selecting subtitles in tray icon menu - it works. Also I noticed another problem, if I'm trying to select mplayer temporal noise reducer, libavcodec crashes... Last edited by Keiyakusha; 24th May 2010 at 03:13. |
24th May 2010, 02:15 | #11784 | Link | |
"Do everything by hand, even when using the computer." - Hayao Miyazaki |
24th May 2010, 04:47 | #11785 | Link |
Kid for Today
so I guess this is non-negotiable?
seriously: It doesn't happen for ffdshow audio...so why do you force it for ffdshow video? After you've spent a lot of time working on automatic profiles, you couldn't care less about all this...all it does is filling my HTPC screen w/ useless stuff, and require one more click to reach "setup" on the very top of the screen It'd be really nice if you could add an option to disable all those shorcuts, in order to make it the way it was before...hope you will consider it Last edited by leeperry; 24th May 2010 at 05:00. |
24th May 2010, 14:27 | #11787 | Link | |
Please explain why you are having both in the same graph, because I see no reason for it. In fact, it is just very inefficient to do so.
MPC-HC 2.2.1 |
24th May 2010, 14:32 | #11788 | Link |
I am not sure what the rationale was behind this change. Maybe Albain can explain. Maybe for selecting subs?
Perhaps we could show just an on/off for subtitles in there, instead of showing all the filters.
MPC-HC 2.2.1 |
24th May 2010, 16:34 | #11789 | Link | |
契約者
Also having the same options kind of defeats the purpose of having separate subtitles filter at all. By the way there probably can be confusion because it is not obvious enough that here, if checkbox that marked red is unchecked, this options marked blue still has effect on intext pin behavior and thats why he says that RAW filter "stealing" connection. You probably haven't seen MPC-HC yet. Last edited by Keiyakusha; 24th May 2010 at 17:09. |
24th May 2010, 16:52 | #11790 | Link |
24th May 2010, 16:56 | #11791 | Link | |
Kid for Today
one click > the ffdshow config panel opens: perfect! but this new layout is good if you're still messing around w/ the settings, so a simple checkbox to enable all those shortcuts would be really great....best of both worlds! |
24th May 2010, 17:11 | #11792 | Link | |
MPC-HC 2.2.1 |
24th May 2010, 17:16 | #11793 | Link |
Kid for Today
oh and BTW, I know I still believe in Santa Claus...but if there were a way you guys could look into this bug report, that'd be really sweet: http://sourceforge.net/tracker/index...41&atid=867360
because I posted a sample a little while ago, and some AC3 files are 5.1 but seem to be tagged as stereo..so using the ffdshow built-in AC3 decoders, it will trigger the stereo automatic profile using AC3Filter fixes the problem altogether, but ffdshow is unable to detect the number of channels...for some reason |
24th May 2010, 18:14 | #11794 | Link |
Kid for Today
anyway, I tried the new layout...it doesn't seem to work for me
I've got the Avisynth filter enabled and ticked, if I click on it...it enables the "Offset" filter if I click on "Overlay", it flips the picture?! it looks like none of those things are doing what they are supposed to for me.. |
24th May 2010, 21:30 | #11796 | Link |
契約者
Midzuki
Do you still see the problem if you disable all options that marked blue on this picture? Because I think if everything is disabled there, RAW filter shouldn't except connections to in-text pin. If it still accepts them, maybe this is a bug. Last edited by Keiyakusha; 24th May 2010 at 22:36. |
25th May 2010, 02:13 | #11797 | Link |
Unavailable
@ Keiyakusha:
For the time being, I can only confirm the old BUG still is present in r3448. Yes, I downloaded r3452 , and I should have checked if that BUG remains unsolved, however I uninstalled r3452 as soon as I found out a brand-new problem — the raw video filter "automagically resizes" the clips to an incorrect aspect ratio, even if it has all of its checkboxes unticked. EDIT: Just a "wild guess" — maybe the new BUG happens only when the monitor is set to the "outdated" 800x600 resolution. Last edited by Midzuki; 25th May 2010 at 03:40. Reason: add emphasis |
25th May 2010, 16:34 | #11798 | Link | |
On my test 3453 fix it Thank you Albain as usual Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
25th May 2010, 16:53 | #11799 | Link |
On this sample? I don't have the setup to compile it here to test so I'll have to wait until someone makes a build available. If it doesn't work I'll make a more detailed post since after I demuxed and examined the subs the problem isn't exactly what I thought it was.
Either was, thank you Albain.
