21st September 2005, 19:45 | #681 | Link | ||
Swallowed in the Sea
Thanks. @Dimzon : sounds good to me... |
22nd September 2005, 11:31 | #683 | Link |
I got this little problem:
1)i select two or more avi files to convert their audio to .mp2 2) select the mp2 DVD preset and click start 3) the prograssive bar go immediately to the extreme right but keep on displaying 0% 4)anyway the conversion proceed in the right way and when the log says that the process is complete the .mp2 file is there where i want to be. So the conversion is ok but the progressive bar not! |
22nd September 2005, 13:54 | #684 | Link |
@boombastic : avi as input file is not supported in the 0.22 branch for the moment...So, uses 0.21 instead.
@cw_uk : thanks...it's fixed now. Last edited by Kurtnoise; 22nd September 2005 at 15:07. |
22nd September 2005, 17:58 | #685 | Link |
@CinCH, @cw_uk, @vito9 : could you try this build and tell me if all it's ok.
@all : I added some goodies in this daily build...I hope you like them. Last edited by Kurtnoise; 23rd September 2005 at 11:13. |
22nd September 2005, 18:18 | #686 | Link | |
FAAC with "Wrap aac stream in mp4" enabled -> switch to WinAmp -> output extension remains *.mp4 (should be *.aac)
Bye |
23rd September 2005, 15:27 | #689 | Link |
Hello.
When i open BeLight and see the log ('options -> view -> log'), here is the result 16:14:18 BeLight version 0.2.2.0 beta 8 @09/23/2005 started ! 16:14:18 Microsoft Windows XP Professional (version 5.1, Build 2600 : Service Pack 2) 16:14:18 Checking libraries for BeSweet... 16:14:18 libvorbis.dll missing !!! 16:14:18 bsn_NeroAAC.dll missing !!! Libvorbis.dll is in the same directory where BeLight and BeSweet are (so the warning message is wrong). About 'bsn' the warning is correct i have not renamed 'bsn.dll', but i thought that with besweet 1.5b31 it was not necesary to do it. Anyway when I encode a mp3 into a HE-AAC with Nero digital encoder it works perfectly with -bsn parameter. BTW good work abd thanks a lot Kurt. |
23rd September 2005, 16:44 | #690 | Link | ||
23rd September 2005, 17:11 | #691 | Link | ||
Yes i'm using only libvorbis.dll. Quote:
I use -bsn for "Nero Digital" and -dimzon for "Dimzon Framework". BeLight works perfectly with both enconders (parameters) without renameing. Last edited by Palikrovol; 23rd September 2005 at 17:14. |
24th September 2005, 12:11 | #694 | Link | ||
I put the daily builds on CC.org now... |
24th September 2005, 13:05 | #696 | Link |
XviD User
Thanks again for all the constant effort on this great application!
Is it possible to have BeLight warn you before overwriting a file? Maybe a better idea could be that BeLight just appends a "1" to the end of the filename. Also, maybe it's just me but my Vorbis audio volume is very low compared to AAC using the same gain settings for some reason.
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2 |
24th September 2005, 13:34 | #697 | Link | |||
/me just kidding.. Quote:
24th September 2005, 14:08 | #698 | Link | |
digitally remastered
The advantage would be that it's correctly sorted in file explorers.
May The FourCC Be With You |
25th September 2005, 12:15 | #700 | Link |
Unregistered User
@Kurtnoise13: If it is not a problem, could you change all comboboxes' Style property to csDropDownList and you can get rid of JVCL by simply using lbButtons I've suggested. I suppose the final EXE will be smaller
my subtitle site |
