14th December 2009, 22:06 | #25 | Link | |
Now that I have more comments about multi pass quality-based encoding and such I will need to spend some time doing some more tests before I can come back with a 'new' setting that people can critique. Thanks all for your feedback. |
14th December 2009, 22:35 | #26 | Link |
I often say "maybe"...
(Return to serious mode)After all the explanations you got on this thread...I hope you simply forgot the ' , ' ? Am I right?
We are spitting food to these hungry eyes. You see they ask, we know they are greedy of our rot. Better than to give jam to pigs. x264 r2146 MOD Last edited by MatLz; 14th December 2009 at 22:43. |
14th December 2009, 23:05 | #27 | Link | |
Well I'm going to spend some time playing with Staxrip so I can get a feel for the current settings, my previous GUI doesn't seem really relevant to x264 as its currently implemented so if I'm going to use x264 well I need to take Dark Shikari's advice and use the presets rather than re-inventing the wheel. I think the job for me now is to try single pass quality encoding vs 2pass encoding and see how the results stack up vs filesize. I'm very encouraged by what I have learned so far so thanks all for your help and I'm sorry I was so far off the page |
14th December 2009, 23:15 | #28 | Link | |
There is ABSOLUTELY NO DIFFERENCE in quality between multi pass and CRF given the same bitrate and settings. You are WASTING TIME if you do 2 pass encoding when you don't care about having a strict final size. Got that? |
14th December 2009, 23:19 | #29 | Link | |
Its my understanding of compression in general that multi pass will let you get a lower bitrate for the same effective quality. Also quality mode with a higher preset might be a better balance of quality vs time than 2-pass, this is what I want to test. |
14th December 2009, 23:23 | #30 | Link | ||
Software Developer
file_size = bitrate * duration If you want a smaller file, simply lower the bitrate accordingly. Yes, it really is that easy Quote:
In fact a video encoded with 2-Pass mode will have (almost) identical quality compared to a video encoded with 1-Pass CRF mode -- given that both videos have the same average bitrate (file size). The difference is that with CRF mode the final file size is completely unpredictable, while the final size is known in advance when using 2-Pass mode Conclusion: If you need to hit a specific file size or a specific bitrate, then go with 2-Pass mode. But if you want to hit a specific level of quality and don't care about filesize, then use CRF mode.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th December 2009 at 23:41. |
15th December 2009, 01:09 | #31 | Link |
I think there're still some features working better in multi-pass than crf mode, like --direct auto.
But since the frame decision is done in 1st pass, unless one uses high precision 1st pass settings, they would obtain worse decision with fast 1st pass+slow 2nd pass than simply slow crf mode. |
15th December 2009, 01:36 | #32 | Link |
Simplified:
CRF: You choose a quality, x264 will encode. 2-pass: You choose a bitrate (filesize). On the 1st pass x264 finds out what quality will fit into that size, and the 2nd pass it encodes with that quality. |
15th December 2009, 14:31 | #37 | Link |
Ok i dont know if this is x264 related or dgindexnv but will try here first, I am using the latest x264 from x264.nl (at this time 1373) and i am using
D:\>x264.exe --profile high --level 4.1 --preset veryslow --tune film --pass 1 --bitrate 9132 --stats "stats" --slow-firstpass --thread-input --b-adapt 2 --ref 4 --partitions all --me umh --direct auto -o gran.torino.mkv gran.torino.avs But it seems like x264 is stalling, the cpu useage is at 0%, CUVIDServer is running (used to pipe the dgv to avisynth) can anyone see anything wrong with the above? Thanks, if this isnt a x264 issue i will post in nvtools thread
The Internet: where men are men, women are men, and children are FBI Agents Last edited by Carpo; 15th December 2009 at 14:50. |
15th December 2009, 15:00 | #38 | Link |
I have experienced this a few times and after using VDub and avs2yuv. Make sure that there is not another instance of a script using DGSource. Close it if there is. If not, try restarting the cuvid server then running x264 again.
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
15th December 2009, 15:02 | #39 | Link |
Software Developer
Well, if you open the very same AVS file in VirtualDub, can you play it up to the point where x264 freezes and beyond that point?
15th December 2009, 15:18 | #40 | Link | ||
I wondering if its something in the above line that is causing x264 to kick out, and therefore i will need to correct it, or if its a dgindexnv issue Quote:
loadplugin("D:\dgdecnv200b6\DGDecodeNV.dll") dgsource("D:\gran.torino.dgv", resize_w=1280, resize_h=720)
The Internet: where men are men, women are men, and children are FBI Agents Last edited by Carpo; 15th December 2009 at 15:42. |
