Old 6th October 2007, 15:34   #61  |  Link
sunbeam
sunbeam's Avatar
Hi neuron2,
no way for me to open a mpeg file at all in these 3 last releases. No one else with this problem on w2k around ?
Very small sample as attachment, no space available these days. Excuse me for that.
Greetings,
sunbeam
A way becomes a way by going
Last edited by sunbeam; 9th October 2007 at 14:45. Reason: Attachment deleted because problem solved in 1.5.0b5
sunbeam is offline
Old 6th October 2007, 20:33   #62  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
It would probably be best if you uploaded it to an external site like maxupload, yousendit, rapidshare, etc. Chances are you will get help faster, as the attachment has to be approved first before anyone can look at it.
first of all, what kind of "mpeg file" is it? Are we talking .vob, .mpg, .ts, etc.?
second, what error are you getting? what happens when you try to load a mpeg file into dgindex? can you seek correctly in the window?
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline
Old 6th October 2007, 22:09   #63  |  Link
sunbeam
sunbeam's Avatar
@Merlin7777:
vob, m2v, m2p, mpg, all mpeg files.
The error is, that they do not show up in the File List anymore.
I can see all of them, load them and then they do not appear in the file list as mentioned in post #59
sunbeam is offline
Old 6th October 2007, 23:08   #64  |  Link
Works fine for me with your test file. I have WinXP. I'll try with Win2000 at work on Monday.
Any Win2000 users want to try it?
Guest is offline
Old 6th October 2007, 23:18   #65  |  Link
Rainy
Drag & drop works, adding files using open dialog doesn't. Tested with different files on Windows 2000 Pro SP4; neither showed up in the list.
Rainy is offline
Old 6th October 2007, 23:35   #66  |  Link
Wow, Rainy, that's pretty shocking. Both work on WinXP. The only thing I did was add a new file type to the open types string for the open dialog. Maybe I hit a string length limit for Win2000. I'll check it on Monday and fix it as needed. For now, use drag and drop.
EDIT: I also expanded the lpstrFile buffer. It turns out that it triggered an obscure Windows bug. See below.
Guest is offline
Old 8th October 2007, 19:13   #67  |  Link
It's an obscure Windows bug:
http://www.swiftgear.com/windows_bug.html
You can see that it is the same bug because if you select two or more files it works. I have it fixed and will release a new beta tonight.
Guest is offline
Old 9th October 2007, 03:50   #68  |  Link
Version 1.5.0 beta 5
* Fixed a problem with PSIP PID detection that could cause programs to be missed.
* Fixed a problem that resulted in an abort of processing with the message box popup "Force film mode not supported with frame repeats".
* Fixed a problem that caused the file open dialog to fail for some earlier versions of Windows. I didn't include this in the formal change list because it was exposed by a change in beta 2 (increased size of internal buffers!), so it is not present in version 1.4.9.
http://neuron2.net/dgmpgdec/dgmpgdec150b5.zip
Guest is offline
Old 9th October 2007, 04:42   #69  |  Link
Originally Posted by 3ngel View Post
I have two question:
Can you add the ability to recognize DTS-HD MA?
You have an example in the stream i sent to you.
It's possible to add the ability to "Select the Main Movie" from a pool of m2ts (movie spread in different m2ts)?
Hey, better late than never, eh?
What is DTS-HD MA? Did you send me a stream?
I don't get the second question at all.
Guest is offline
Old 9th October 2007, 06:41   #70  |  Link
sunbeam
sunbeam's Avatar
Thank you for fixing this, neuron2.
sunbeam is offline
Old 9th October 2007, 16:34   #71  |  Link
Inventive Software
Turkey Machine
DTS-HD MA is the DTS-HD Master audio stream, sometimes found in, I think, BluRay discs.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 9th October 2007, 20:13   #72  |  Link
Yoshiyuki Blade
Novice x264 User
Yoshiyuki Blade's Avatar
Hmmm... for some reason, I get this error in virtualdub (and megui) unless I have "Use Full Paths" checked:
MPEG2Source: Could not open one of the input files.
Other than that, it works fine.
Yoshiyuki Blade is offline
Old 9th October 2007, 22:34   #73  |  Link
guada2
Really Interesting.... BUT
@neuron2
why to update "Dgavcdec" if Dgindex can do all thing (except avc)?
guada2 is offline
Old 9th October 2007, 22:53   #74  |  Link
@guada2
I don't understand your question. How about PM me about it so as not to clutter up the thread? Thanks.
@Yoshiyuki
I need a lot more information than that. I need all your file locations, the DV2 file, and the AVS script. I also want you to try it manually and not through MEGUI, because I don't want to get involved with MEGUI.
Guest is offline
Old 10th October 2007, 01:17   #75  |  Link
Yoshiyuki Blade
Novice x264 User
@Yoshiyuki
I'm not using megui for anything more than loading the avs script to see if it works, just like virtualdub. Both throw the same error, at the same line. It has to do with mpeg2source("C:\...\file.d2v").
Heres the first 4 lines of the d2v file generated without "Use Full Paths" checked (I'm encoding Cowboy Bebop btw):
DGIndexProjectFile16
2
..\DVD\Rips\COWBOY_BEBOP_VTS_06_PGC1\VTS_06_1.VOB
..\DVD\Rips\COWBOY_BEBOP_VTS_06_PGC1\VTS_06_2.VOB
The actual .d2v file is generated to "New Folder" on my desktop, which I specify in the mpeg2source() of the avs script.
When I manually replace the shortened directories with the full paths (C:\Documents and Settings\...etc), it works fine. So it seems to be a problem with the shortened directories.
Old 10th October 2007, 02:21   #76  |  Link
@Yoshi
For your failing case, I need to know the exact path locations and names of the source file(s), the exact paths as written in the D2V file, the exact path location and name of the AVS script, and the contents of the script. Without all those things I cannot determine the problem. This is my second request for all these things. Thank you.
Everything is relative to the location of the D2V file, and the AVS script must be in the same directory as the D2V file.
Guest is offline
Old 10th October 2007, 06:57   #77  |  Link
Yoshiyuki Blade
Novice x264 User
@Yoshi
Ok, here's how its set up right now:
Location of VOB files (source):
C:\Documents and Settings\User\Desktop\DVD\Rips\COWBOY_BEBOP_VTS_06_PGC1\VTS_06_1.VOB
C:\Documents and Settings\User\Desktop\DVD\Rips\COWBOY_BEBOP_VTS_06_PGC1\VTS_06_2.VOB
C:\Documents and Settings\User\Desktop\DVD\Rips\COWBOY_BEBOP_VTS_06_PGC1\VTS_06_0.IFO (I don't know if this file is necessary or not)
Location of d2v file:
C:\Documents and Settings\User\Desktop\New Folder\VTS_06_1.d2v
Path as written in the d2v:
Location of AVS script:
C:\Documents and Settings\User\Desktop\test.avs
Contents within the AVS script:
loadplugin("C:\Documents and Settings\User\Desktop\Encoding Tools\AVISynth Plugins\awarpsharp.dll")
loadplugin("C:\Documents and Settings\User\Desktop\Encoding Tools\AVISynth Plugins\colormatrix.dll")
loadplugin("C:\Documents and Settings\User\Desktop\Encoding Tools\AVISynth Plugins\dgdecode.dll")
loadplugin("C:\Documents and Settings\User\Desktop\Encoding Tools\AVISynth Plugins\fluxsmooth.dll")
loadplugin("C:\Documents and Settings\User\Desktop\Encoding Tools\AVISynth Plugins\sangnom.dll")
loadplugin("C:\Documents and Settings\User\Desktop\Encoding Tools\AVISynth Plugins\undot.dll")
loadplugin("C:\Documents and Settings\User\Desktop\Encoding Tools\AVISynth Plugins\unfilter.dll")
import("C:\Documents and Settings\User\Desktop\Encoding Tools\AVISynth Plugins\aaa.avs")
mpeg2source("C:\Documents and Settings\User\Desktop\New Folder\VTS_06_1.d2v")
colormatrix()
tweak(sat=1.2)
aaa(1280,720,100,100,1,2,chroma=true)
awarpsharp(depth=30)
fluxsmoothst(15,15)
temporalsoften(10,4,4,30,2)
undot()
EDIT: Oh, It does happen to work when the AVS file is in the same directory as the d2v. I guess using the relative paths instead of the full paths doesn't work too well for me. Is it absolutely necessary to have both the d2v and avs files in the same location? This whole thing was confusing to say the least. Man... I think having "Use Full Paths" off by default was what started this mess. Oh well, thanks for clarifying things.
Old 10th October 2007, 14:12   #78  |  Link
Regarding the AVS script location having to be in the same directory as the D2V file, I agree that it is an undesirable limitation. I will see if it can be removed. I have also changed the default back to full paths for the next beta.
Guest is offline
Old 12th October 2007, 04:10   #79  |  Link
Version 1.5.0 beta 6
* Removed the limitation that the AVS and D2V files must be in the same directory when the Use Full Paths option is disabled. Thanks to Rainy for showing the way.
* Restored the default setting of the Use Full Paths option to enabled for backward compatibility with third-party applications. If you turn this off, you are expected to know what you are doing.
http://neuron2.net/dgmpgdec/dgmpgdec150b6.zip
Guest is offline
Old 12th October 2007, 15:55   #80  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
thank you neruon2, this is going to get its way into megui autoupdate
Sharktooth is offline
