3rd October 2008, 17:31 | #4381 | Link |
Media Control author
After looking on ffmpeg mailing list, they advise to use libavformat to create the correct audio frames.
But I don't want to waste time integrating libavformat into FFDShow if it gives the same results... |
4th October 2008, 08:46 | #4382 | Link | |
Our DVBSource filter currently only extracts AC3 frames from a BDMV TrueHD stream.
Bye |
4th October 2008, 19:57 | #4384 | Link | |
I think the main reason why the Haali splitter works and the internal MPC splitter is not is that the Haali splitter "collects" data and tries to send full frames to the output pin. In contrast I think the MPC internal splitter sends every small data bytes forward as soon as it gets them. So with the MPC internal splitter you'll likely get small packages of 100 bytes each (or something like that). In order to make your ffdshow branch work with that you need to buffer the data internally until you have enough data available for at least one audio frame. |
4th October 2008, 22:56 | #4385 | Link | |
For an unknown reason the parser rejets 1 blocks of 2 on my sample. From the other hand, I spent some time studying libavformat and it appears that it would be useless for audio formats : libavformat constructs frames from the buffer for the parser for video streams only whereas audio buffers are sent directly to the parser. So libavformat seems to be useful only for developing a "FFDShow splitter" which is not his role for now Last edited by albain; 5th October 2008 at 09:26. |
5th October 2008, 11:50 | #4386 | Link | |
The buffer given by mplayerc splitter is not the same as haali's on a DTS sample. The beginning is the same but not the end :
Haali's buffer : Code:
7FFE8001FC3C3ED275E0D3A098C63189CE73980002DB6DB6DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000195755555533110CCA88733CA86242222222222399710ECA86666444666553E864422222222222355E864222222222222200000000000015CD34 Quote:
5th October 2008, 14:00 | #4387 | Link |
The dts sample you got this buffer is a DTS-HD sample in a container (and which)?
I did some tests and realized that haali media splitter outputs the core of the DTS-HD track on m2ts and evo files, while it outputs the complete DTS-HD stream in mkv files only. MPC-HC's splitter outputs the full DTS-HD info. So i tried the next graphs: m2ts: haali (dts core) --> libav --> ok m2ts: mpc (dts-hd) --> libav --> problem m2ts: mpc (dts-hd) --> libdts --> ok mkv: haali (dts-hd) --> libav --> ok evo: haali (dts core) --> libav --> ok ffdshow is beta 10 because beta 11 doesn't work at all. Last edited by nautilus7; 5th October 2008 at 14:04. |
5th October 2008, 16:53 | #4388 | Link | |
(1) In ffdshow dump all the DTS input data into a test file. (2) Use eac3to (or any other working demuxer) to extract the raw DTS data from the source file. (3) Compare the ffdshow dump to the eac3to dump. Do that with both Haali and MPC splitter. That might help finding out what's going on. |
5th October 2008, 18:14 | #4389 | Link |
I made my tests with a regular DTS sample (no DTS-HD blocks in it).
This is Bhack_Hawk_Down_LPCM_problem_Sample.ts (don't remember from whom I got it). I tested it with MPC and then with windows media player (that uses Haali splitter) I made deeper analysis, and the DTS headers are fine in both cases. This is clearly a ffmpeg bug which does not know how to handle the subframes in all cases. I won't go further in the anlysis However libdts is okay to decode those. |
5th October 2008, 18:18 | #4390 | Link | |
EDIT : I spoke too quickly, actually the parser acts as the same way for Haali and MPC. Last edited by albain; 5th October 2008 at 18:23. |
5th October 2008, 18:40 | #4391 | Link |
I may have good news, but this must be confirmed : the problem comes from the input splitter that gives wrong information about the number of channels and the bitrate.
Making my own DTS parsing and updating the libavcodec structure seems to fix the problem |
5th October 2008, 21:24 | #4392 | Link |
That makes a lot of sense. In my experience you can't trust the media type information of the input pin for compressed audio sources. All you can reliably (?) get from the media type information is which codec is being used. The media type information is reliable only for PCM, I think. E.g. just today I created a 7.1 AAC test encoding with the new Nero AAC encoder. Then I played that file back with the Nero DirectShow Audio Decoder. The source filter reported 7 channels (instead of 8).
8th October 2008, 11:35 | #4393 | Link |
I have made a new build that should (I hope) decode all DTS formats including DTS in wav when using libavcodec
Here is the link : http://rapidshare.com/files/15200443...eta12.exe.html However I have troubles to make TrueHD/MLP decoding work : when I strip off MLP/TrueHD blocks (and keep AC3 blocks) to make decode by the AC3 decoder or when I strip off AC3 blocks (and keep MLP/TrueHD blocks) to make decode by the MLP decoder this does not work. I hope to find the solution soon Last edited by albain; 8th October 2008 at 11:38. |
8th October 2008, 13:35 | #4394 | Link |
4:2:0 hater
Testing the lastest beta now, it works! All DTS files and DTS in WAV also! Perfect.
However, this lastest betas are incomplete or something? Opening a video with ffdshow = crash, Vorbis = doesn't load, TTA = freeze. But DTS works now |
8th October 2008, 14:40 | #4396 | Link |
It should not.
Here is an updated version (with the last updates from the trunk). I recompiled it completely Link : http://rapidshare.com/files/15204455...eta12.exe.html |
8th October 2008, 15:33 | #4398 | Link | |
8th October 2008, 15:37 | #4399 | Link |
4:2:0 hater
Nice, now everything works like it should. If I find any bug I'll post it.
EDIT: It seems there are still some files that will show mp2 instead of mp3. Last edited by STaRGaZeR; 8th October 2008 at 16:06. |
