5th December 2009, 23:15 | #61 | Link |
Thanks. I spent all day trying to crack this bug. I was not able to get it to crash after making that change. Of course, albain didn't commit his latest changes to SVN last I checked so my version doesn't have his DTS-HD fix, but, anyway it still works. Watching Monsters Inc with my son right now. We never got to finish it the other night.
5th December 2009, 23:25 | #62 | Link |
I let my compile finish and tested it anyway and this works. TaudioParser block starting at line 437 (addition in bold):
if (useDTSHDPassthrough && newsrcBuffer->size() > 0) { if (backupbuf.size()!=0) backupbuf.append(&newsrcBuffer->begin(), newsrcBuffer->size()); newsrcBuffer->clear(); audioParserData.frames.clear(); } |
5th December 2009, 23:27 | #63 | Link |
Ok. When I checked the size on backupbuf even during working runs it was 0, so, I didn't think that was a viable option. Basically your code is never going to fill that backupbuf. And I'm not sure what it even does. It's no different than commenting out the line, though.
5th December 2009, 23:32 | #64 | Link |
That's what I was thinking which is why I deleted my previous post. Your change works for me as well so I say go with yours unless albain shoots us both down.
if (useDTSHDPassthrough && newsrcBuffer->size() > 0) { backupbuf.append(&*newsrcBuffer->begin(), newsrcBuffer->size()); newsrcBuffer->clear(); audioParserData.frames.clear(); } |
5th December 2009, 23:39 | #66 | Link |
Media Control author
Hi, sorry for the delay
You found the solution actually : this &* thing is the solution, it is reproduced elsewhere in the code. I think this is a matter of cast to get the right address. This block of code line 437 corresponds to that case : in the previous parsing loop I detected a DTS core block and added it to the output buffer (newsrcbuffer). But after that I detected a DTS HD block : so the stream format is not DTS but DTS HD. And I cannot let this DTS block into the output buffer if I don't have a full DTS HD block because DTS HD bitstream are pairs of 1 DTS core and 1 DTS HD block So I have to remove it, back it up and get it back once I have my full HD block. Great job, I wouldn't have suspected this. When you're looking for errors, you don't look after missing stars between & and a variable ! :-) Would you join the developers team ? EDIT : by the way there is a similar mistake line 748, it concerns DD+ (and it would explain crashes with this format a few weeks ago) THANKS AGAIN ! EDIT2 : also the last build should work better I hope with non working DTS HD samples. I am committing the sources so that you get the last fixes Last edited by albain; 5th December 2009 at 23:44. |
5th December 2009, 23:52 | #68 | Link |
Yes, awesome buddy !
Fixes committed in revision 3145 And here comes a new build too So now can we say that TrueHD and DTS HD are fully functional on the ATI 5xxx series ? |
5th December 2009, 23:56 | #70 | Link |
Mostly I would agree with that, yes. WaveOut does not work on DTS-HD MA for me. The receiver never locks...keeps searching for an audio signal. But all the other renderers work for me. (Well, arcsoft doesn't but that's never done anything for me.) DirectShow both default and ATI, MPC, etc. All working now. Thanks so much for your work on this!!!!!!
6th December 2009, 00:06 | #71 | Link |
Thanks to you on this one fellows
Man, if I knew that I would have built 47 betas to get this working (compared to the 23 betas for the initial implementation of the audio parser for Truehd and DD+ decoding, also with madshi's contribution). |
6th December 2009, 00:09 | #72 | Link |
It probably would have been easier on you had I set up a dev environment on that machine earlier. sigh. I was just afraid of breaking my only working player at the time. And indeed, if VS is running, TMT3 refuses to start. However, it's ok as long as VS isn't running, so at least now I know I can have both on the same machine. If you need help with anything else, just yell.
6th December 2009, 00:12 | #73 | Link |
Audiophile
Okay with build 49 and my xonar and arcsoft renderer DTS-HD movies that crashed (well all dts-hd movies crashed before) now don't crash in fact i can't find any movies that will crash it i think you fixed it 100% as for as the bug you were looking for.
I can also skip anywhere in the movie and voila the audio doesn't miss a beat. This build is close to perfection for the xonar with arcsoft renderer, I am sure you would like to get the xonar to work with direct sound or waveout because you can't incorporate arcsoft renderer into ffdshow, and it would be nice if the same renderer worked with both the xonar and the ati 5*** series cards. Anyway I thought I would share the xonar side of your success. And by the way awesome job Samurihl in finding the reason for the app crash. Cheers
never give up or at least die trying Last edited by sub24ox7; 6th December 2009 at 00:15. |
6th December 2009, 00:17 | #74 | Link |
That's really good news that it's not crashing for you on the Xonar, as well! Sweet!! It took WAY longer to find this bug than it should have. I was stubborn and was looking for a way to trace into the code directly. I finally gave up on that and started adding dprintf's all over the place. That helped me narrow it down, but, even then I got it wrong a couple times. Java is so much easier. I used to be very good at C++ but I haven't really done much with it in a few years. It's coming back to me now, though. I'm just glad I was able to find this as it was driving me insane. Working with one renderer, not with another, then working on one run but not the next. BLAH! I'm putting together a list of renderers that don't work with the ATI card now.
6th December 2009, 00:25 | #75 | Link |
I have updated the first post according to the last (good) results
I hope now that DD+ is working too and that I'll figure out a solution for the xonar. Last step after that LPCM support and we are done! I will continue tomorrow. Thanks again SamuriHl for your hard work |
6th December 2009, 00:27 | #76 | Link |
DTS-HD MA (Monsters Inc which was crashing until the new build):
ATI HDMI Output - Doesn't lock and continues to search for the audio track Default WaveOut Device - see above, same as ATI HDMI Output Cyberlink Audio Renderer - LPCM as always MPC - Working Default DirectSound - Working DirectSound: ATI HDMI Output - Working ArcSoft - No audio, doesn't even try to find an audio stream TrueHD (Mounted ISO rebuilt with tsMuxer): ATI HDMI Output - Working Default WaveOut Device - Working Cyberlink Audio Renderer - LPCM as always, INSANELY SLOW playback...audio really messed up MPC - Working Default DirectSound - Working DirectSound: ATI HDMI Output - Working ArcSoft - No audio, doesn't even try to find an audio stream As you can see there are differences between TrueHD and DTS-HD MA. albain, let me know if you need anything from me.
6th December 2009, 00:28 | #77 | Link |
Audiophile
I am trying this very minute the TrondheimSolistene divertimenti blu-ray on my hdd and i am having complete success with it on both the dts-hd 192,000hz 24bit 5.1 channel and the true-hd 192,000hz 24bit 5.1 channel track. so it seems to work with the 192,000hz tracks of both perfectly!!! this with the same setup as my previous post! beta 49. I even had trouble getting the dts-hd track of this one with the official totalmedia theatre 3 from arcsoft, but not with ffdshow I can get both the lpcm(obviously most likely molested) which never worked and the dolby-true hd and dts-hd bitperfect to receiver awesome!
never give up or at least die trying Last edited by sub24ox7; 6th December 2009 at 00:48. |
6th December 2009, 00:33 | #80 | Link | |
