6th April 2011, 23:28 | #2082 | Link | |
Also, you might not notice this on most TVs, but for instance the Pioneers have automatic inverse telecine for content originally shot at 24 fps. I output my PS3 at 1080i, and I can watch that content refreshed at 72 Hz. All good, except starz doesn't preserve usual 2-3 cadence, and all is effed up. Some TV content like Psych look just fine at 24p/72Hz. |
6th April 2011, 23:46 | #2083 | Link | |
7th April 2011, 13:15 | #2084 | Link |
I saw you guys mentioned SP Pro, what is the benefit of that over a player such as MPC HC? I take it SP Pro uses all its own codecs/filters, so you cannot replace as you can with MPC HC. Looking at the FAQ comparison SP Pro looks like it can barely play back anything (the HD-Cam version looks like the only useful one)
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
7th April 2011, 13:26 | #2085 | Link |
I don't use it. Hadn't ever heard of it until it was mentioned as being able to do DD+ on an AMD card. However the only real way to test that theory is to bitstream a 7.1 DD+ stream and see if you do, in fact, get 7.1 channels. Every time I've tried that with anything on an AMD card, it fails. PDVD incorrectly marks DD tracks on a BD as DD+. It's *NOT* DD+....it's just mislabeling it somehow. (Neat trick, though).
8th April 2011, 10:11 | #2086 | Link |
Me either, "Ontherocks" mentioned it. S/he also mentioned the same about it being able to bitstream DD+ at Tulli's EDID thread at AVS, Tulli said he'd check it out but didn't come back to it, so I just checked myself with the trial of SP Pro. It looks OK though, and it at least played m2ts files. I didn't test further. But yeah, no directshow, it's gonna be barely useful for us. Just look at VLC. No WASAPI exclusive, no bitstreaming, no DTS-HD decoding, no madVR, etc etc. If Slyplayer turns out to be what we've been hoping for, it's because James is one of us .
8th April 2011, 10:13 | #2087 | Link | |
8th April 2011, 11:46 | #2088 | Link | |
8th April 2011, 13:11 | #2089 | Link |
Yes, it is. Peer posted that it already plays avatar, some clearly progress is being made. I hope that if it doesn't bit stream natively that it allows us to use ffdshow or another dshow bitstreaming decoder.
14th April 2011, 22:09 | #2090 | Link |
Hi! Guys, please, tell me, I outputed TrueHD and DTSHD Master by bitstream (from comp to receiver) and indicators HD lit up on the receiver and
the sound is normal from all 5 dynamics, but I don't understand, Why in this case ffdshow displays this: "Input: Dolby TrueHD, 7.1, 96000 Hz, 327 kbps (bitstream)", "Output: HDMI bitstream (1402)". File type is *.m2ts., although, in my opinion, the sound of TrueHD and DTSHD Master must be higher than 2000 kbps. But when I tested almost all of my files with HD audio types, ffdshow displayed from 300 kbps to 1500 kbps (mainly it concerns not True-HD, but DTS-HD). What is DTS core ? Is core only the part of DTS-HD or True-HD also has core ? P.S. My htpc configuration: a) hardware: videocard Asus GTS 450 (can output HD audio by bitstream), Windows 7 32 bit, receiver Onkyo 508 (supports all HD formats); b) software: MPC-HC (player), ffdshow (codecs) (for audio) and coreavc (for video for "CUDA nvidia"), haali media splitter. P.P.S. When I tested HD files, which Rica referenced on ("dtshd_out" (m2ts and mkv) and "thd_out" (m2ts and mkv)), ffdshow displayed this: "Input: Dolby TrueHD, 7.1, 96000 Hz, 1536 kbps (bitstream)", "Output: HDMI bitstream (1403)" - file "DTSHD_out" (m2ts and mkv) and "Input: Dolby TrueHD, 5.1, 48000 Hz, 5220 kbps (bitstream)", "Output: HDMI bitstream (1402)" (m2ts and mkv) - file "THD_out". |
14th April 2011, 22:19 | #2091 | Link |
Don't worry about the display. It's a bug. If you're bitstreaming, you're getting the full HD audio experience at whatever the bitrate actually is.
22nd April 2011, 10:37 | #2092 | Link | ||
Try with the demo trailers from here http://www.demo-world.eu/trailers/hi...n-trailers.php Download the following from the above website and test it with Splash Player Pro. Dolby Digital Plus (Lossless) [Filename --> hd_dolby_digital_plus_lossless.m2ts] Dolby Digital Plus Channel Check (Lossless) [Filename --> hd_dolby_digital_plus_channel_check_lossless.m2ts] Don't forget to set the following in Splash Player Pro as in the image below Its indeed a crappy player, I don't use it myself. But surprisingly its the only player I have come across that can bitsteram DD+. |
4th May 2011, 12:12 | #2094 | Link |
So it seems that the AMD hardware can, in fact, bit stream eac3. Nevcairiel does it now in lav audio. Looks like it's been a bug in ffdshow as to why it wasn't working for us.
Sent from my Xoom using Tapatalk
5th May 2011, 10:16 | #2095 | Link | |
Dude are you crazy, vudu looks absolutely amazing. It looks nearly identical to bluray on hdx with good bandwith. By the way thanx for the help with lav splitter. I still havnt been able to integrate mpchc in xbmc so I'm using a build with dsplayer/ffdshow to bitsream for the time being.
5th May 2011, 13:43 | #2096 | Link |
For a streaming service, VUDU is by far the best of the bunch, but, it's nowhere near as good as blu-ray itself. You should try using LAV Audio for bitstreaming and see how that works for you. ffdshow still has a bug where EAC3 can't be bitstreamed.
6th May 2011, 12:36 | #2097 | Link |
TrueHD 7.1 decoding is apparently broken. The rear surrounds and side surrounds are swapped. Doesn't happen with LAV audio or the Arcsoft decoder. Samples:
File name: THD 7.1.mka File size: 37.97 MB http://www.avsforum.com/avs-vb/showt...php?p=20333665 |
6th June 2011, 23:31 | #2098 | Link |
Clicking when playing DTS-HD
Does anyone have issues playing some MKV rips with DTS-HD soundtrack where there is a clicking sound coming from the speakers while DTS Core track is perfectly fine? I am using the latest FFDShow.
Alex |
6th June 2011, 23:33 | #2099 | Link |
I didn't have that issue when I was using ffdshow for bitstreaming, no. What receiver is it? And is it only happening in MKV rips? The splitter you're using?
6th June 2011, 23:47 | #2100 | Link | |
Alex |
