15th May 2012, 17:28 | #15001 | Link |
The problem is caused by r4260, in which support for interlaced VC-1 was added.
MPC-HC 2.2.1 |
23rd May 2012, 10:10 | #15003 | Link |
I think I've found a glitch with the MPEG2 libavcodec decoder. The skips happen when I open the DVD from the VIDEO_TS.IFO file. The glitch is 100% reproducible for me and the skips happen at the same exact spots. If I open the VOB by itself using LAV video decoder, the skips do not occur. If I open the VIDEO_TS.IFO using the MPC-HC mpeg2 decoder, the skips do not occur. Here is a sample: http://www.mediafire.com/download.php?im9htdjxo3v2kp7
EDIT: I tested the sample on my other machine and the skips are still there with latest ffdshow. Also, I realized depositfiles requires a 60 second wait, a captcha, and a 20 minute download time... so I updated the link to mediafire Last edited by FlashGordon; 25th May 2012 at 00:27. Reason: better link |
25th May 2012, 13:26 | #15004 | Link |
QuickSync Decoder author
I've added HW deinterlacing, detail and denoise to the Intel QuickSync Decoder.
I don't want to commit my changes before there's some kind of GUI (in ffdshow) to control these. My preferred option is to create a new tab instead of changing existing ones. Can someone give me some pointers?
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
27th May 2012, 13:21 | #15005 | Link |
How may options are we talking about?
You could add a page below "Decoder options" if you need a lot of space. Or add to the "Decoder options" page if just a few options. The IDCT and quant options could be removed imo to free up some extra space on that page.
MPC-HC 2.2.1 |
28th May 2012, 13:58 | #15006 | Link |
I'd like to add a new page - below the decoder options is fine.
I want to add options for: * HW DI on/off/force, half/full rate, etc. * Denoise filter * Detail filter * procamp filter These will only work with the Intel QuickSync Decoder - covers most of the video content these days.
29th May 2012, 09:07 | #15007 | Link |
Committed several small changes:
Synced with latest QS decoder - video post processing is hard coded off until GUI is ready. Fixed telecine manager - detected H264 frame doubling/tripling flags as 3:2. Tweaked fps calculation - more stable.
30th May 2012, 08:09 | #15008 | Link |
Last commit:
Added "Intel QuickSync" page below the decoder options.
31st May 2012, 16:37 | #15010 | Link |
http://forum.doom9.org/showpost.php?...ostcount=19549
Is there any chance to fix this? |
2nd June 2012, 14:49 | #15011 | Link | |
My problem... If I use just VobSub/vsfilter for IDX/SUB subtitles, I see double subtitles when playing SRT subtitles. If I disable ffdshow's text subtitles, it works, but I loose the nice extras in ffdshow. Does anyone have any ideas what I can do to make ffdshow the only one that displays for SRTs? I've gone back to build 4422 for now. |
7th June 2012, 12:56 | #15012 | Link |
Hi, is it possible to set Profiles/Preset Settings by file extension (ie FLV, AVI, MP4 etc)? If so how to do you that as I don't see any option to select file extensions when I click "Preset Autoload Conditions..."
Cheers much |
7th June 2012, 13:19 | #15013 | Link |
Try "on movie file name match (with wildcards)".
Roelofs Coaching |
8th June 2012, 09:45 | #15014 | Link |
Hello, used ffdshow_rev4422_20120409.exe
Accroding to spec for VC1 there is no restrict to change it during the stream http://rfc-ref.org/RFC-TEXTS/4425/chapter4.html 4.6. Repeating the Sequence Layer Header Here is sample file that hangs on decoding the stream, using WMVideo Decoder DMO it plays fine: http://dl.dropbox.com/u/9992211/crash.wmv The sequence layer and entry layer changes during the stream: Code:
00 00 01 0f cb ee 13 f0 ef 88 80 00 00 01 0e 18 44 4f c3 bc 80 00 00 01 0f cb ef 13 f0 ef 0a 13 f8 3b f1 c0 ef 90 81 2d c6 db 8d 40 00 00 01 0e 4a 3f 28 40 00 00 01 0e 4a 3b 98 40 http://dl.dropbox.com/u/9992211/broken.wmv The sequence layer and entry layer changes during the stream: Code:
00 00 01 0f ca 00 13 f0 ef 0a 13 f8 3b f1 c0 ef 88 00 00 01 0e 4c 10 80 00 00 01 0f cb ef 13 f0 ef 0a 13 f8 3b f1 c0 ef 90 81 2d c6 db 8d 40 00 00 01 0e 4a 3f 28 40 00 00 01 0e 4a 3b 98 40
Solveig Multimedia - Video Editing Software Last edited by Stanislav Mikhailenko; 8th June 2012 at 09:48. |
14th June 2012, 17:14 | #15016 | Link | |||
My hobby website |
17th June 2012, 11:41 | #15018 | Link |
>>^^__^^<<
I want to ask, is it possible to add ability to prefer connection to ASIO Renderer to ffdshow audio filter (Output section, "Connect to:" menu)? It's CLSID is {8E14549A-DB61-4309-AFA1-3578E927E933}
24th June 2012, 17:00 | #15019 | Link |
Software Developer
I've encountered an issue/bug when using ffdshow's subtitle renderer filter. What I'm trying to do is build a graph where the ffdshow subtitle renderer is connected to the video decoder and the external subtitle file resides in a different directory entirely. I'm trying to use the API to manually specify the subtitle file by calling the "IffDecoder2" interface like this: putParam(IDFF_isSubtitles,Integer(True)); // Make sure subtitle processing is enabled. putParam(IDFF_subAutoFlnm,Integer(False)); // Supposed to disable the auto-searching for sub files in the same dir as menu file. putParamStrW(IDFF_subFilename,@SubFileLoad[1]); // Set the subtitle filename. There are two issues: 1. The 'search in' radio-item remains checked rather than the 'file' radio-item becoming enabled and the subs are not rendered. 2. The IAMStreamSelect interface that lists the available subtitles doesn't see to be properly updated when using this method, even when manually switching to 'file' and clicking on the 'reload' button. Am I doing something wrong? Can this be fixed? |
