12th October 2006, 00:22 | #81 | Link |
Retired, but still around
Buzzqw, I wanted to redo an encode so chose the d2v previously made. I changed the filter also. The script that resulted:
#resizestart #test4 Lanczos4Resize(out_width,out_height) #filter2start #test5 FFT3DFilter(sigma=3) tart #test5 RemoveGrain(mode=2)
How to Optimize Bitrate for CCE multipass |
12th October 2006, 11:05 | #83 | Link | ||||
HDConvertToX author
update www.64k.it/andres/data/a/AutoMKV27.exe
added job queue (VERY EXPERIMENTAL) (0.27) little layout change on size (MB) (0.27) added subtitles to files to cancel added saving settings button. On click on "save setting" the following setting are saved Container,Size,Slice,Resizer,Width,Set encoding mode,Audio Codec 1,Audio Bit 1,Audio Codec 2,Audio Bit 2, Encoding Profiles,Bitrate Encoding,Bitrate Value a file named automkv.ini is created and will always parsed at program start (if present) added launch windows minimized --------------------------------------- Quote:
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 12th October 2006 at 11:10. |
12th October 2006, 11:36 | #84 | Link |
HDConvertToX author
update www.64k.it/andres/data/a/AutoMKV28.exe
fixed loading of ifo file that aren't main movie (user can choose video.ifo even if movie is in VTS_09_0.IFO) (0.28) added autoloading of vob files. just click on first to input (0.28) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
12th October 2006, 12:51 | #85 | Link |
I have problem with automvk and nero aac.I download nero aac encoder and copy it in BeSweet folder.But,when Automvk starting process of aac I have these errors:
13:42:47 Encoding C:\Documents and Settings\Alessandro.ALEX-4B73A998DD\Desktop\Nuova cartella\fixed1.ac3 to AAC with 0.40 quality 13:42:47 No audio create, retry without apply Original 13:42:47 Encoding C:\Documents and Settings\Alessandro.ALEX-4B73A998DD\Desktop\Nuova cartella\fixed1.ac3 to AAC with 0.40 quality 13:42:47 No audio create, retry without apply Original 13:42:47 Encoding C:\Documents and Settings\Alessandro.ALEX-4B73A998DD\Desktop\Nuova cartella\fixed1.ac3 to AAC with 0.40 quality 13:42:47 No audio create, retry without apply Original 13:42:47 Encoding C:\Documents and Settings\Alessandro.ALEX-4B73A998DD\Desktop\Nuova cartella\fixed1.ac3 to AAC with 0.40 quality 13:42:47 No audio create, retry without apply Original 13:42:47 Encoding C:\Documents and Settings\Alessandro.ALEX-4B73A998DD\Desktop\Nuova cartella\fixed1.ac3 to AAC with 0.40 quality 13:42:48 No audio create, retry without apply Original 13:42:48 Encoding C:\Documents and Settings\Alessandro.ALEX-4B73A998DD\Desktop\Nuova cartella\fixed1.ac3 to AAC with 0.00 quality ................................................... How solve my problem? |
12th October 2006, 13:10 | #86 | Link |
HDConvertToX author
first of all Ciao ! (fa piacere che ci sia qualche italiano che usa il programma)
check these options: 1)is neroaac executable named "neroAacEnc.exe" ? also 2) if you choose Ogg or Winamp do you get the same error ? 3) try to move the "Nuova Cartella" in a folder like "c:\nuova_cartella" hope better news ! BHH
12th October 2006, 14:34 | #88 | Link |
HDConvertToX author
if even ogg is failing... i don't know...
last try please uncheck "Del temp file" (in advanced tab) and launch encoding. when failed close automkv. From dos-prompt launch mkvaudio.bat and watch the error thanks ! BHH
12th October 2006, 14:44 | #89 | Link |
buzzqw, running into several problems and have some comments:
There seems to be something changed with the auto res/multiple (28). I choose 1cd and checked crf 19, 2% sample, and multiple resize. The res came up as 320 which is different than before. I then changed to 2cds and selected redo, res was not changed and the continue/redo window stole the focus so I could not make any changes. Seems like it steals the focus every second time and it is not picking up the changes. Choose "custom" which presents me with "custom" and "1" - Makes no sense at all to me. 1 what? Understand the queue is experimental - Some way to delete from the queue? Also, what if a person wants to use multiple resize and such? That's why I suggested requiring the user to go through the initial stages and only have the actual encoding and muxing queued. Adding so many features so quickly is great in many ways, but you might want to keep a more stable version like 22 in the first post and only update that as testing shows your next versions are somewhat stable.
12th October 2006, 15:37 | #90 | Link | |
HDConvertToX author
www.64k.it/andres/data/a/AutoMKV29.exe
fixed size problem on autoresize. added clear job list (all job) Quote:
about filter error (tart) please edit default.avs in filter folder and add a return between Code:
#test5 #filter2end BHH
12th October 2006, 16:06 | #92 | Link | |
All of them did not work properly using AM28. Is anyone else having this problem?? In some cases DGIndex runs but it seems to be still just doing ONE VOB file, not all after picking first one. In some cases DGIndex ran twice??? I finally went back to AM22 and chose the video.ifo file, got the normal DGindex's warnings I got before in AM22 like "checkPIDS" then deleted the video.ifo file in the ADD file window of DGIndex and then clicked on ADD in the same window and chose all five of the VOB's and it goes on it's way...AM seems to work OK from there. Also, AM 28 did not seem like it was using force film when appropriate. Does it use it if I use AM 22 as described above. Last edited by MiGster; 12th October 2006 at 16:17. |
12th October 2006, 16:13 | #93 | Link | |
HDConvertToX author
choose VTS_01_0.IFO or VTS_01_1.VOB (or those used by movie) (even if for me choosing videots.ifo is ok..) BHH
12th October 2006, 19:31 | #94 | Link | |||
@fenomeno83, go to program files\avisynth\examples directory and play the version.avs in windows media player, or VDub if you have it installed. Let buzzqw know what you see.
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 12th October 2006 at 20:00. |
12th October 2006, 21:24 | #96 | Link |
Kinda what I thought <picks up baseball bat and whacks fenomeno83>
12th October 2006, 22:12 | #97 | Link |
Life's clearer in 4K UHD
Many thanks for the new builds and apologies for not posting for a while...
I've been trying to generate XviD streams directly into the MP4 container but for some reason I can't.... XviD into the MKV container seems to work okay though! Can anybody else confirm please? Cheers
12th October 2006, 22:50 | #98 | Link |
(0.29) Using multi res, If I change from 1 cd to 2 and redo the test, the same resolution is computed and it continues to steal focus and not allow me to change anything after the 2nd or 3rd redo. Maybe because I am multitasking doing several other things like spreadsheets and email while the redo test is running? I do notice, when the focus is stolen, that instead of having 3 AutoMK items in the taskbar, I have 2. To rephrase that, I've noticed when the settings in AutoMK can be changed for a redo there is always a 3 in the AutoMK icons on the taskbar. Does that make any sense to you?
13th October 2006, 06:31 | #99 | Link |
Registered Loser
Nice work Buzzqw!
Some feedback: 1) Subtitles are still left behind. 2) Saved settings are great! Only thing missing (for me) is saving Audio tracks as "Original" (always defaults to stereo, doesn't seem to be a setting in the ini file) 3) Batch Encoding - ignores output directory and puts everything in the main movie directory 4) Batch Encoding - GUI disappears completely (no taskbar, no tray icon) but the process continues to run and completes. AutoMKV quits after batch completes. 5) Minimize works great! Only thing missing is dgindex - just add a -minimize at the end of the command line. Any way of naming the final movie in advance instead of "movie.mkv" ? Keep up the great work! agressiv |
13th October 2006, 06:53 | #100 | Link | ||||||||
HDConvertToX author
i got no problem... a question: is automkv producing all temporary file ? link audio.mp4 and movie.avi ? just for info the final file should be "movie_full.mp4" also you can look at automkv.log to search the culprint (or mail it to me azanzani @ gmail . com ) Quote:
yes... i know... isn't so good... but is the first build with queue Quote:
thanks Quote:
and about steal focus: i had only one time this problem... i don't know why. seems that log window is the stealer (but don't close it!!!) update www.64k.it/andres/data/a/AutoMKV30.exe fixed size in multiresize envirnment, also added between [] (brachet ?) the exact computed size (before modding 16 and scale down to max 704) my thanks again to DDogg and his patience ! BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 13th October 2006 at 07:17. |
