Old 20th May 2010, 04:42   #7701  |  Link
nekrosoft13
new Haali
http://www.videohelp.com/tools/Haali_Media_Splitter
20/05/2010
* New Features:
o Added support for WebM files
* Fixed items:
o Fixed a lot of issues with mp4 muxer
o Better support for VC-1 in MPEG Transport streams
for the love of god, don't force people to install old haali version
nekrosoft13 is offline   Reply With Quote
Old 20th May 2010, 05:27   #7702  |  Link
pacaveli211
Originally Posted by wakebrder View Post
Demux the HD audio track with TSMuxer or Eac3to. Check the size.
Re-encode video if necessary.
23830 MB - (HD audio size) -500 MB for padding = target encode size for Ripbot.
ReMux with TsMuxer.
Although this could be what you're already doing.
unfortunately it's more complex than that.
star trek was 21106MB prior to muxing
after it is: 23074MB ( I fell a little bit under target size, but under is a lot better than over =) )
so it's a lot more than 500MB of padding. and it seems to vary depending on the length of the movie, maybe the audio track (bitrate & codec or something) and etc. if ripbot allowed 'copy track' for HD audio I would probably be able to get a much closer encode using the avchd output to gauge it, as it's structure is almost identical. right now I just kinda guess...subtract the size of the audio from my BDR size 23866MB, then allow for a gig or 2 of padding
pacaveli211 is offline   Reply With Quote
Old 21st May 2010, 05:20   #7703  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
Originally Posted by servocrow View Post
hello,
i did scan though a few pages but didnt come across my issue: ripbot on my current pc setup (windows 7 64x enterprise) will only tackle a few blu rays, handbrake will, but Id rather use ripbot...
the two issues , errors i keep coming across are either related to DIRECTSHOW or AVISYNTH
any fix available for these reoccuring issues??
thx in advance
OK ripbot264 requires Avisynth and FFDShow to be installed.
The installer at this address it should do what you need just fine.
http://www.mediafire.com/?tmm2jqmht2g
When it opens the webpage click on the green button.
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 21st May 2010, 07:54   #7704  |  Link
hoju3508
Originally Posted by nekrosoft13 View Post
new Haali
20/05/2010
* New Features:
* Fixed items:
Cool! Have you tried it? Any issues?
hoju3508 is offline   Reply With Quote
Old 21st May 2010, 08:52   #7705  |  Link
Ajax_Undone
RipBot does not support it yet...
My Installer's ||
Old 21st May 2010, 14:54   #7706  |  Link
thebasa
thebasa's Avatar
Yeah it works great. now how do i get past the ripbot264 software check? CheckRequiredSoftware=0 doesn't work anymore. Is that not supported anymore? Is there a path I can change in the registry or .ini to tell ripbot where to look? I have the new Haali installed with Shark007 Win7Codecs, and no, I don't want to drop the codec pack and install ffdshow and an old version of haali.
thebasa is offline   Reply With Quote
Old 21st May 2010, 16:03   #7707  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Question: Does your AppleTV play [MAIN 3.0] SD. PSP profile?
Old 21st May 2010, 17:20   #7708  |  Link
Atak_Snajpera
Whoever has iPAD or AppleTV please test this sample (it has no sound so don't panic)
http://www.mediafire.com/file/ozj3ir2h4et/park_joy.mp4
Old 21st May 2010, 17:30   #7709  |  Link
thebasa
thebasa's Avatar
Works for me on iPad.
Is CheckRequiredSoftware=0 supposed to work in 1.15.1? I don't care if the answer is no. Just looking for an answer of any sort. Would very much like to use Ripbot264 with Haali 1.10.175.0.
Old 21st May 2010, 17:33   #7710  |  Link
Atak_Snajpera
Just wait for 1.16.0. it is almost finished.
Old 21st May 2010, 17:49   #7711  |  Link
thebasa
thebasa's Avatar
Thanks, that's great news. If you need beta testers,......
Old 21st May 2010, 17:53   #7712  |  Link
Atak_Snajpera
find me somebody who can test above sample on AppleTV...
Old 21st May 2010, 18:07   #7713  |  Link
thebasa
thebasa's Avatar
Wish I had one. Works on our Mac Mini with latest OSX here at work. Couldn't find anyone here with Apple TV tho.
Old 21st May 2010, 22:52   #7714  |  Link
Ajax_Undone
It worked on my apple tv w/latest firmware.
My Installer's ||
Old 21st May 2010, 23:25   #7715  |  Link
Atak_Snajpera
awesome. finally we have correct hq appletv and ipad profile!
Old 22nd May 2010, 03:13   #7716  |  Link
mmmmdonut
I tested your Joy Park sample and PQ looked fine for those 10seconds however video sample did not stream well (I only run hardwire) and aTV struggled to keep up. I did not try syncing the content to the aTV to see if it played any differently as that defeats point of having a media stream imo.
Looking at mediainfo on the file, I see you have cabac on. That has been known to cause locks of blockiness issues on the aTV not to mention its not officially supported by Apple even though folks have got it to work.
Will be glad to do some other testing if you can post profile you are working on.
mmmmdonut is offline   Reply With Quote
Old 22nd May 2010, 07:16   #7717  |  Link
Atak_Snajpera
According to spec AppleTV supports Main level 3.1 so CABAC must be supported as well. In this sample I used the highest bitrate allowed for level 3.1. I doubt you will be encoding anything at 14mbps
Old 22nd May 2010, 13:18   #7718  |  Link
TRONDROM
TRONDROM's Avatar
Awesome....looking forward to it.....
TRONDROM is offline   Reply With Quote
Old 22nd May 2010, 15:51   #7719  |  Link
jeffreynya
Originally Posted by jeffreynya View Post
Hey everyone
New here and trying to figure out whats going on. I am getting the following error:
DirectShowSource: couldn't open file F:\Video\TRANSFORMERS_2_D1_AC.Title3.mkv:
The source filter for this file could not be loaded.
(F:\temp\RipBot264temp\job1\getinfo.avs, line 2)
Log file:
Log file:
F:\>"C:\Users\Jeffrey\Desktop\RipBot264v1.15.1\tools\bepipe\bepipe.exe" --script "import(^F:\temp\RipBot264temp\job1\job1.avs^)" | "C:\Users\Jeffrey\Desktop\RipBot264v1.15.1\Tools\enc_aacPlus\enc_aacPlus.exe" - "F:\temp\RipBot264temp\audio.aac" --lc --br 131072 --mpeg4aac
BePipe by dimzon
Script used:
# BEGIN
import("F:\temp\RipBot264temp\job1\job1.avs")
# END
Scanning for Audio Stream...
ERROR: Can't find audio stream!
* AACPlus v2 Encoder (using Winamp enc_aacplus.dll and nscrt.dll)
* Coding Technologies encoder 8.0.3
* Build Oct 10 2009, 16:03:17
Input file must be WAV PCM!
F:\>"C:\Users\Jeffrey\Desktop\RipBot264v1.15.1\tools\avs2yuv\pipebuf.exe" "C:\Users\Jeffrey\Desktop\RipBot264v1.15.1\tools\avs2yuv\avs2yuv.exe" "F:\temp\RipBot264temp\job1\job1.avs" - : "C:\Users\Jeffrey\Desktop\RipBot264v1.15.1\tools\x264\x264_x64.exe" --crf 22 --stats "F:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 215595 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "F:\temp\RipBot264temp\video.264" - : 2
Avisynth error:
(F:\temp\RipBot264temp\job1\job1.avs, line 6)
x264 [error]: could not open input file `-'
F:\>"C:\Users\Jeffrey\Desktop\RipBot264v1.15.1\tools\mp4box\mp4box.exe" -tmp "F:\temp\RipBot264temp" -add "F:\temp\RipBot264temp\video.264":name="TRANSFORMERS_2_D1_AC Title3" -fps 23.976 -add "F:\temp\RipBot264temp\audio.aac":lang=eng -mpeg4 -chap "F:\temp\RipBot264temp\job1\chapters.txt" -new "F:\Video\TRANSFORMERS_2_D1_AC Title3.mp4"
Cannot find H264 start code
Error importing F:\temp\RipBot264temp\video.264:name=TRANSFORMERS_2_D1_AC Title3: BitStream Not Compliant
Elapsed Time: 00h:00m:01s
The strange thing is it was working the first time, but had a stupid autoupdate that restarted the PC. After that I was unable to do anything. I tried to just rerun the job, but it said it was already complete, but there was no file where it said it was. So I changed destination folder and it started again, but got the abover error. I have updated what I can and uninstalled and reinstalled AviSynth. Not sure what else to do.
thanks
Any help on this would be great. Thanks
jeffreynya is offline   Reply With Quote
Old 22nd May 2010, 15:57   #7720  |  Link
How did you rip the BluRay?
