9th April 2011, 21:07 | #1423 | Link | |
Let me know how well it works with wmv.
9th April 2011, 21:32 | #1424 | Link |
Tested for you, WMV and ASF seems to work fine, with the exception of not working with AR flag's.
On another note, with OGM the seek issue is fine now, but with LAV Splitter and ffdshow for decoding xvid/divx it plays at around 16fps and not 25fps, other decoders seem fine, so not sure if this is a LAV bug or a ffdshow bug. EDIT, latest build has no OGM issues anymore MPEG-PS works very well now for me with the exception of EVO with VC1, hopefully the work you have done on VC1 will help that, does anyone have a current build available for me to test
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) Last edited by VipZ; 9th April 2011 at 22:35. Reason: OGM update |
9th April 2011, 21:53 | #1425 | Link |
WMV HD works fine, to get HD Audio, it was needed to check enable Jitter in FFDShow Audio, and now no need
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
9th April 2011, 21:57 | #1426 | Link | |
Also my suggestions 1 change your LAV VC-1 settings to auto (what decoder are you using ?) 2 Reset MPC-HC's settings 3 Reset you Video drivers then if you have ATI, disable all settings in Video section except "Use automatic deinterlacing" & "Pulldown detection"
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 9th April 2011 at 22:02. |
9th April 2011, 22:11 | #1427 | Link |
Unfortunately ArcSoft Audio Decoder HD (TMT5) downsamples HD audio to 48/16..or em I wrong?
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
9th April 2011, 22:16 | #1428 | Link | |
Using some custom build, or official 0.21? I recently fixed a problem that caused exactly this, hoping that i didnt break something else in the process.
9th April 2011, 22:33 | #1429 | Link | |
OGM is now working fine with ffshow in this build, no more issues that I see WMV still has AR flag issue. EVO, The updated build does show a difference now under ffdshow (libav), the video no longer stutters, simply plays too fast and out of sync. MPC DXVA remains the same, synced but stutters, no other filters connect to this, I don't test with PowerDVD/TMT, I try keep away from commercial decoders. I always disable the ATI options already and MPC-HC's settings have been reset. LAV VC1 set to Auto, others also don't improve the results. If this file is remuxed to a m2ts it plays perfectly, if there is any way to force decoding to 23.976 I think it would play fine. Here is a screenshot showing the change from stuttering to smooth at around half way, this is total random and not position specific. http://i53.tinypic.com/2ares0.jpg
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) Last edited by VipZ; 9th April 2011 at 22:39. |
9th April 2011, 22:44 | #1430 | Link | |
Intel UHD Graphics 750; Win 10 22H2 |
9th April 2011, 22:49 | #1431 | Link | |
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) |
9th April 2011, 23:08 | #1434 | Link |
Do you have some VC1 in EVO sample somewhere?
9th April 2011, 23:33 | #1435 | Link |
Here you go, http://www.mediafire.com/?pwb6cb01dk41661
I didn't choose Doom as that worked sometimes and sometimes not, Dukes of Hazard always seems to have the issue. I hope the way I split it is ok, comes up same as full EVO.
10th April 2011, 00:50 | #1437 | Link | |
I think its one issue that's occurs on all EVO's if a solution is found to one, it should hopefully apply to all.
10th April 2011, 01:32 | #1439 | Link |
It looks like ffmpeg just isn't too happy about EVO files in general. Remuxing the file with ffmpeg causes the file to show the same symptoms of choppyness, and all EVO files i saw are misdetected with a wrong frame rate (which probably causes the problems in the first place). Sadly there is no easy way to fix these terribly broken timestamps and maintain A/V sync.
Considering that HDDVD is dead, and EVO isnt really used anywhere else, i also have no real hope for improvements on ffmpegs side.
10th April 2011, 03:39 | #1440 | Link |
A EVO VC-1 Interlaced Sample - http://www.mediafire.com/?d4h51794if31aba
