Old 8th July 2015, 15:56   #1  |  Link
gheller
Wondering how to tweak decode brightness/contrast/levels on VirtualDub
Hey all!
Having trouble with some video I'm importing into VirtualDub created on a DVD recorder. It's a VOB and I'm using fccHandler's MPEG plugin to read the file. In the preview window which is an overlay with hardware decoding the video looks fine, but in the output window where software decoding is used, the video is darker. I can use virtualdub filters to increase the brightness, but at that point the dark end of the spectrum has already been lost, and along with it, all detail in any dark scenes. Is there any way for me to tweak the settings for the software MPEG decoder so it behaves more like the hardware decoder and doesn't lose the darks? If not, are there settings stored in the .VOB file I could mess with that might also fix the problem, and if so, where are they stored?
--Gabe Heller
gheller is offline   Reply With Quote
Old 8th July 2015, 16:39   #2  |  Link
shekh
Hi, wrong levels are typical from misinterpreted color range. I am not sure about VOB format, but if the range is specified in the file, and ffmpeg handles it, then my plugin should work correctly: http://sourceforge.net/projects/vdcachingdriver/
Otherwise you can add internal filter "alias format" and select color range (and color space) manually.
Old 8th July 2015, 20:49   #3  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
Very interesting, shekh. I see this driver is included with your VirtualDub FilterMod project, which incorporates the driver seamlessly - and has some nice new plugins (Gaussian blur! Histogram overlay! LAB color correction! Motion blur! Perspective warp!) and other features (deep color! alpha support!)
raffriff42 is offline   Reply With Quote
Old 8th July 2015, 21:21   #4  |  Link
gheller
Yay! Seems to work!
I had to upgrade to a more recent version of Virtualdub that has the alias filter, and experiment with the settings a bit. Setting the 'component range' to "full' seems to do the trick. Thanks a bunch!
Old 8th July 2015, 22:14   #5  |  Link
shekh
What? If you mean internal filters, these are untouched from official VirtualDub.
Old 14th July 2015, 00:56   #6  |  Link
Mounir
You better use avisynth with avspmod and also dgindex to create a .d2v for the vob
you can tweak the levels with y levels and tweak the brightness, contrast, saturation with tweak
MPEG2Source("Myvideo.d2v",
ylevels(0,1.000,255,16,235)
tweak( cont=1.1, sat=1.0,coring=false)
Mounir is offline   Reply With Quote
brightness, dvd, fcchandler, mpeg, virtualdub
