12th July 2012, 18:13 | #1141 | Link |
Posts: n/a
Yeah, let me know if you see any regressions.
There's a few GUI bugs fixed in that too. Also in the conversion dialog I've gotten rid of the accelerators on the store/restore/reset buttons. This way alt-o will work properly for the okay button on that dialog now. |
13th July 2012, 13:38 | #1142 | Link |
PgcEdit daemon
CLI bug: This command doesn't work.
BDSup2Sub++.exe --language fr -o "11 Subtitle (PGS), French.sub" "11 Subtitle (PGS), French.sup" BDSup2Sub++ 1.0.0 RC3 OPTION: Set language to French (fr) Converting SUB/IDX Loading C:/Users/rol/Desktop/BD3D2AVS_projects/My_BD/00485_m2ts/11 Subtitle (PGS), French.sup Selected language 'French (fr)' by filename ERROR: Cancelled by user! Note that the same bug occurs even without the --language option. But it works if the output file is not specified: the GUI opens and loads the input file. It seems that the CLI code is broken when -o is specified. Here is the SUP stream (but IMO, the same bug happens with any stream, although I have not verified). Also, I wonder why the message "Selected language 'French (fr)' by filename" appears, since the language code has been passed via the CLI. (Not important if you can confirm that the CLI option takes precedence.)
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 13th July 2012 at 13:51. |
13th July 2012, 15:15 | #1143 | Link | |
Posts: n/a
Ok, fixed version is here.
Let me know if you see any other regressions. |
16th July 2012, 21:00 | #1145 | Link |
PgcEdit daemon
Not tested much. In particular, I have still not tested the option to move the subpics horizontally or vertically, but I should have some time to test it tomorrow. Also, I have not tested the GUI. But IMO, you can probably release 1.0 soon, or immediately if you wish.
16th July 2012, 23:03 | #1146 | Link |
I have tested only GUI and RC4 work great, the problem with black background it seems that disappeared but i need test a little more.
Also sometimes I have crash with long subtitles, some memory leaks I suppose. You need a little more optimize memory for BDN xml/png sometimes crash or consumes all my pc memory (4GB) and I canīt do anything on pc while process subtitles, if I do RC4 crash or freeze. Sorry for my english, I hope you understand it. Last edited by mood; 16th July 2012 at 23:06. |
16th July 2012, 23:14 | #1147 | Link | |
Posts: n/a
How many PNG files? I've loaded BDN+PNG with over 1500 subpictures and it doesn't do anything remotely like that. Can you possibly post the BDN+PNG files zipped up so I can see what is happening? |
16th July 2012, 23:34 | #1148 | Link |
Posts: n/a
Okay, so I just double checked and I loaded a XML+PNG with 1200 PNG files and the RAM usage went up to 18 megs and when rewriting it back out as a BDSUP it peaked at 22megs.
Edit to add: Can you tell me some more specifics of what you did exactly when it ate up all your RAM and crashed? And the exact file you can get it to reliably reproduce with is vital. Because I loaded the XML+PNG, scrolled through about a hundred subpictures than wrote it out as BDSUP and like I said, it barely went up in RAM usage from after being loaded. |
17th July 2012, 00:08 | #1149 | Link | |
Here is XML+PNG, this have more than 2500 png. http://www.mediafire.com/?jzjji88404w96ki Sometimes work without problem, sometimes crash or freeze. |
17th July 2012, 14:12 | #1150 | Link |
PgcEdit daemon
Hum tested this:
bdsup2sub++.exe --move-x origin --move-x-offset 10 -o "11 Subtitle (PGS), French_left.sub" "11 Subtitle (PGS), French.sup" Windows error info: Code:
Problem signature: Problem Event Name: APPCRASH Application Name: bdsup2sub++.exe Application Version: 0.0.0.0 Application Timestamp: 50002c55 Fault Module Name: bdsup2sub++.exe Fault Module Version: 0.0.0.0 Fault Module Timestamp: 50002c55 Exception Code: c0000005 Exception Offset: 006ffc4c OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
17th July 2012, 15:05 | #1151 | Link |
PgcEdit daemon
Another thing. When I load the sup file via the GUI (or with just the input file as CLI argument), the backgrounds of the subtitles are transparent. But when I convert it from the command line, it is black, even without any additional argument (except --language, necessary due to the previous bug). I have deleted the ini file, just to be sure, but the result is identical. It seems to not use the same defaults when it is launched from the CLI. (Or it has a bug with the transparency when it is launched from the CLI, but that's strange.)
17th July 2012, 15:22 | #1153 | Link |
Posts: n/a
r0lz, try this and see if you still see either of your issues. There was a missing check to make sure alpha and langIdx were actually set properly before trying to set the override (though I did have a check for the luma threshold override). Otherwise it'd set an erroneous value which is probably your issue with both the crash and the alpha. It wasn't a problem before because it was setting it immediately when detecting the options, but I forgot to check since I moved the alpha, langIdx and luma threshold overrides to just before the writesub call.
To mood, I still can't reproduce your issue. Even with doing a move caption the RAM usage only goes as high as maybe 100 megs. I'll run it again through Valgrind tonight with your XML+PNG to see if I can find other issues with memory leaks that maybe I'm not seeing without it since you are seeing a magnitude more memory usage than I can get it up to. Last edited by SassBot; 17th July 2012 at 15:25. |
17th July 2012, 15:35 | #1155 | Link |
PgcEdit daemon
Not sure I've tried the latest version, but anyway, the two bugs are fixed (in one shot!)
Thanks. I will retry with the new download, just to be sure... [EDIT] Confirmed. No problem any more.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 17th July 2012 at 15:39. |
17th July 2012, 15:53 | #1158 | Link |
PgcEdit daemon
OK, green light for me.
17th July 2012, 16:20 | #1160 | Link |
PgcEdit daemon
Wait! It seems that the --move-x origin --move-x-offset -10 doesn't work. After having converted the same sup file with --move-x-offset -10 and --move-x-offset 10, they are identical. The pos in the GUI has not changed.
