16th August 2008, 20:36 | #161 | Link |
I get an error opening an individual EVO file from gui on planet earth hddvd:
Error opening Media Key File ...HVDVD_TS/AACS/MKBROM.AACS ERROR: LOADMKB, errnr: -1 aacskeys ERROR: LOADMKB, errnr: -1 Failed retrieving keys from source Why is it looking for MKBROM in HVDVD_TS/AACS instead of AACS? Edit: Happens when I selected a single file as source, instead of the root of the hddvd or bluray. When selecting root, all works fine. But this presents a problem if you only want to stream one file via command line. Can anything be done differently, am I missing something? Last edited by chavonbravo; 16th August 2008 at 23:34. |
16th August 2008, 22:28 | #162 | Link |
Another question, as I already answered myself above, has anyone gotten streaming to work with this in linux? Mplayer and xine both don't work for me. Mplayer gives an error about not being able to seek backwards, and xine can't find a demux plugin. Playing from file works fine, but I'd really rather get this working by streaming.
Edit: okay, keep on answering myself. Mplayer needs a cache, so add a -cache 8192 to command line and it works. Xine is still a no go, which is what I'd prefer. Last edited by chavonbravo; 16th August 2008 at 23:06. |
17th August 2008, 16:06 | #163 | Link | |
20th August 2008, 05:16 | #165 | Link |
No, its not. Well, not yet. I wanted to release it someday, but not in its current stage. But i haven't touched it for almost a year now, there was no real reason to do so, the community was far behind the MKB revision and DumpHD was getting obsolete. However, the recent events changed that situation and i have the feeling i could invest some work again to make it "releasable". Now all i need is some time (and a working computer) .
20th August 2008, 06:27 | #166 | Link |
Well, after some manual java bytecode editing, modifying a constant, and adding a method to the class, got this working. Here is same 0.4 package with a different dumphd.jar that works with selecting a single file as well as the root directory of the disc.
(much better for streaming) p.s. The value used in AACSDecrypter.class that is passed to GetKeys should be aacsdir.getParent() instead of srcDir.getPath(). This will work better, KenD00. Hope you do release the source some day. It's much easier to modify that than what I had to do. This works GREAT, thanks, I finally have bluray/hddvd working as I'd like. |
22nd August 2008, 02:26 | #167 | Link | |
20th September 2008, 19:29 | #168 | Link |
DumpHD 0.45
I don't believe it myself, but after one year here comes a new version of DumpHD . The main new features are Blu-Ray Recordable support and a changed file mode. From the changelog:
2008-09-20: 0.45 - Experimental Blu-Ray Recordable support (with multiple CPS Units, BDMV, BDAV with Aux Directories and Thumbnails) - Updated Key Database to version 1.3, new entry types: M (Media Key), B (Binding Nonce), P (Protected Area Key) - DumpHD can now calculate the VUK / PAK if only the Media Key and Volume ID / Binding Nonce is given - Replaced single file mode with multiple files mode (works only in CLI mode) - ACAPacker now works with direct key retrieval too The single file mode has been replaced by the multiple files mode, now you always have to select the root directory from the disc. To not process the whole disc, specify the files to process on the command line, they will be processed in the listed order. This feature does not work from the GUI yet, it's main purpose is to use it for streaming output. I have updated the download links in the first post, download the new version from there. |
20th September 2008, 20:24 | #169 | Link |
Hey guys, just tried DumpHD. But I get the following error:
..... The given Host Certficate / Private Key has been revoked by your drive. ERROR: SENDHOSTCHAL: SK: 0x5, ASC: 0x6F, ASCQ: 0x00, errnr: -2 aacskeys ERROR: SENDHOSTCHAL: SK: 0x5, ASC: 0x6F, ASCQ: 0x00, errnr: -2 Failed retrieving keys from source
Bye |
20th September 2008, 21:03 | #170 | Link | ||
Posts: n/a
Now you can: 1. get a valid certificate(pub key)/private key pair 2. patch your firmware to bypass authentication 3. obtain the volume id by logging the communication between a licensed software player and your drive (sniffing) 4. use utilities like DumpVID 5. ask somebody who has the same disc, google, ... I recommend to patch your drive but this option is only a few drives (LG, Plextor,...) |
20th September 2008, 21:09 | #171 | Link | |
Bye Last edited by CiNcH; 20th September 2008 at 21:47. |
20th September 2008, 22:17 | #172 | Link | |
Posts: n/a
DumpVID is i think hammering the drive with requests for the volume id. After the authentication process is complete the drive may be asked for the volume id and DumpVID tries to be the first to ask that question. The drive will only answer that question once. This is not player dependent but keep in mind that these software players hack your kernel so your system won't behave the way it should be. You can try anti-rootkit tools to remove some of these hacks. These hacks are usually only active when the player runs. Also switching to an amd64 operating system might help. |
20th September 2008, 23:41 | #174 | Link |
Uhm, no. The drive gives you the VID and anything else as many times as you ask it but only if your AGID is valid. And thats the problem, the software player invalidates it after it got its stuff, so the time frame is very small and if the hammer interval is too long you miss it.
You better stuff it directly into aacskeys so that it gives you the Volume Unique Key. Then you enter that one into the KEYDB.cfg (see that file for the format of the entries). |
21st September 2008, 00:28 | #175 | Link | |
Bye |
21st September 2008, 19:43 | #176 | Link |
There is no advantage, there is just no other way. If aacskeys does not work automatically you always have to make a database entry yourself. Of course, i could implement a way that if only the VID is present DumpHD passes this to the library, but this process is still not fully automatic because someone has to enter the VID into the database before. Beeing a lazy guy i burdened this step onto the users shoulders, if the user is able to acquire the VID manually he should also be able to acquire the VUK manually .
29th September 2008, 13:37 | #177 | Link |
problem with new dumpHD version 0.45
@KenD00:
i've tried running the new version of dumpHD (v 0.45) and the shell script doesn't work to run the program. i get the following error: $ ./dumphd.sh bash: ./dumphd.sh: /bin/bash^M: bad interpreter: No such file or directory I am in the correct directory and have the proper permissions set on the file. the shell script for version 0.4 did work on my machine. I am running linux, 64-bit. I am able to get the program (with GUI) running by executing the DumpHD.jar file but it is unable to load the aacskeys library, which the previous version is able to do. I get this error message: DumpHD 0.45 by KenD00 Opening Key Data File... OK Initializing AACS... OK Loading aacskeys library... FAILED no aacskeys in java.library.path Direct key retrieval disabled, only keys from the database will be used I don't know the java library path but version 0.4 of dumpHD never had any problem with this that i had to deal with. Thanks to KenD00, arnezami and Oopho2ei for all the software and support. |
29th September 2008, 13:48 | #178 | Link |
2 things :
1 - It's not ./dumphd.sh but sh ./dumphd.sh. 2 - You need a copy of libaacskeys.so and (not sure) aacskeys files taken from aacskeys source directory (another project). 'Z Last edited by TomZ; 29th September 2008 at 16:11. |
