4th March 2008, 14:16 | #21 | Link |
I'm trying to find fast/efficient YV12 lossless codec.
I havea already tested AlparySoft Lossless Codec v 2.0 b9570.40607 Now I found here Lagarith lossless codec (supporting RGBs, YUY2 and YV12). Latest version v1.3.14 With my test sample 93 frames 512*384 i'got ASLC 11153408 Lagarith 8089600 But after final encode and comparing encoded material (using ASLC and Lagarith) I found, that Lagarith do not give lossless encode with YV12 Here is MSU comparing graph |
4th March 2008, 21:40 | #22 | Link |
Angel of Night
Your comparison is broken. I assume you're using cartoons where every other frame is duplicated? You'll see that kind of pattern anytime you compare videos that are one frame off, for whatever reason. It's also possible but less likely that there's a colorspace conversion in there somewhere.
It is quite certainly lossless, though. |
4th March 2008, 22:01 | #23 | Link |
Avisynth Developer
To visually compare near identical files
A=AviSource("File_A.avi") B=AviSource("File_B.avi") Subtract(A, B) N=8 # Adjust sensitivity here Levels(128-N, 1.0, 128+N, 0, 255) StackHorizontal(A, Last, B) |
4th March 2008, 23:20 | #24 | Link | ||
I've tests with Alparysoft lossless codec Loco VBLE All with real lossless results. Only Lagarith gives some strange results for me. |
