16th September 2018, 13:51 | #27701 | Link |
I quoted you because you are the one that posted it. I'm just adding that if the disc is attempted to be played, it either will or it won't. One way to find out which way BDRB should be used.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 19th September 2018 at 11:28. |
20th September 2018, 05:24 | #27703 | Link |
[20:39:24] Importing: BOOK_CLUB_FILES - [20:39:27] Importing video file: (1 of 6) - Preparing MKV for processing... - Collecting audio/video streams from source... - Integrating into pseudo-BD structure... - [21:10:16] Importing video file: (2 of 6) - Preparing MKV for processing... Run-time error '70': Permission Denied. I have been importing the MKV files I made and moved to a different drive/partition. After selecting the MKV files MADE with BD-RB, it imports fine until here.. Other times it imports all 6, and then wants to rerender a BD-50. I just started checking this. But it's not new to get this error with other stuff. Usually I exit BD-RB, delete Temp, Import and WORK...and all goes well from there. 118GB free (not GiB--I'm poking a lot of fun at the goofy GiB thing) free...so, plenty to work with. Any ideas for the error?
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
20th September 2018, 13:22 | #27704 | Link |
That's just about it. It means that either you don't have privileges to the file, or (more commonly) it is locked and being used. Check and see if there is a file called MEDIAINFO.TXT in the TEMP folder and whether it has information in it.
It could (possibly) be a race error. Try setting IMPORT_PREPARE_MKV=0 in the INI file and see if that has an effect. MKV files don't necessarily have to be "prepared", but I added it because I ran into a lot of MKV files that were incorrectly muxed. |
20th September 2018, 16:43 | #27705 | Link |
Doh, I forgot about IMPORT_PREPARE_MKV=0. Using now... I remember you discussing that "a long time ago" and others crossing paths with MKV's like that.
Extras passed..now I'll redo with movie with them. If it happens again I'll post the contents of that file. I'll mark that setting as very important, haha! "Locked or Denied, shhaaaa, not even!"
20th September 2018, 19:12 | #27707 | Link | |
1kg = 1000 grams 1kW = 1000 Watts 1km = 1000 meters 1kHz = 1000 hertz 1kb = 1000 bits 1kB = 1024 bytes (WTF!?!) You must be one of those people thinking that only scientist use metric system...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th September 2018 at 19:16. |
20th September 2018, 20:38 | #27709 | Link |
@Atak_Snajpera
Wrong. You're 2nd to last line (1kb = 1000 bits) doesn't exist at least not in the PC world. 8 bits = 1 byte. 16 bits = 2 bytes... (notice how the value doubles) each time, thats because in the pc world software works by multiples of 2, ascending. 1000 doesn't fit in that line 2-4-8-16-32-64-128-256-512=>1024<== Perfectly normal, it's the same reason why you "lose" space after formatting, (you don't really loose it as it was never there to begin with). Disc / drive manufacturers work by the thousand, yes, but that's not a valid value at the OS level (see line above). Manufacturers calculate per thousands, yes, the OS doesn't (it calculates by 1024). 1 GiGaBytes = 1.000.000.000 bytes, the OS works in GiBiBytes, 1 GiB = 1.07374182 or 0.931322575 gibibytes. Which is why a 1 TeraByte calculates to approx 931 GibiBytes after formatting |
20th September 2018, 20:51 | #27710 | Link | ||
I see the same trend in audio codecs where for example 384kbps means 384000 bits instead of 393216 bits. Use ffmpeg and you will see what I mean. Binary units exist for a reason and people should finally start using them. 1 KiB = 1024 bytes 1 Kib = 1024 bits https://en.wikipedia.org/wiki/Kilo- Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th September 2018 at 21:08. |
20th September 2018, 23:02 | #27711 | Link |
Update: BR-RB has imported 2 extras fine now, including the one in the log, and the movie. I'm now getting the menu settings set as I want. I didn't make a note of them before. Appreciate the minder, Dobbs.
Another note though, for fun, I attempted the process the outcome like a normal BD, and removed 1 extra...and with the BD-50 set, as well as DO NOT ENCODE forced, I clicked backup (Full) and BD is rerendering everything. Hmmm.. I thought that to be odd since it's 47GB. Had I set BD-25 I would expect that.
20th September 2018, 23:11 | #27712 | Link | |
Science is okay, but has much as it claims to be so awesome, it's also not a Religion I'll join 100%. Hehe. Science is cool, but it still does more guessing than I care for. When I was small, I knew there was a planet that was destroyed in our Solar System. But when I talked to "Science" people about it all I would get back is "that hasn't been confirmed, we don't have 'proof'.". After a bit "Whatever, facts and evidence aren't everything." was my thought. Still is. I'll leave it at that for now.
21st September 2018, 00:12 | #27713 | Link | |
[Edit] Lot's of comments I guess I should have read before answering. Last edited by jdobbs; 21st September 2018 at 00:24. |
21st September 2018, 00:19 | #27714 | Link |
@AmigaFuture
I certainly can't agree with you there. Science and Math are the language of the universe -- and the universe really doesn't care about any of our opinions. Science never "guesses". If it is a guess... it isn't science. It only becomes science when it has been tested and proven. Last edited by jdobbs; 21st September 2018 at 00:21. |
21st September 2018, 01:20 | #27715 | Link | |
21st September 2018, 01:22 | #27716 | Link | |
21st September 2018, 01:54 | #27717 | Link | |
People who don't know the name Science, is their adventuring Scientific? Science is only a definition. Or personal exploration to discover/create more? Science has discovered Reincarnation if a fact. Something I already knew, but.. Anyway, it's a deep and fun subject for sure. I don't require science for answers; but sometimes the validation is fun.
21st September 2018, 01:55 | #27718 | Link |
Yeah, I already nailed being a jackass....(in some opinions...heehaw, heehaw!).
21st September 2018, 02:00 | #27719 | Link | |
I wonder if the "new math" is where the GiG and MiB thing is coming from? Hmm... Lots of people where I live are having a very difficult time getting it accepted. I haven't checked into it, so I'm guessing.
