10th March 2010, 00:59 | #7221 | Link | |
Start all over again with the uninstall first of the three programs jdobbs recommends, Avisynth, haali, and ffdshow. Reboot. install those three programs again. Unzip a fresh BD-RB, "Look in the BD-RB folder. There is a .BAT file called "REG_MSCOMCTL.BAT" -- simply right click onit and run it as administrator." Then, if that does not work, right clicking on BD_Rebuilder.EXE and select "Run as Administrator" |
10th March 2010, 01:30 | #7223 | Link |
Just a point for clarification. Default settings in BD-RB aren't set to "normal" -- you're confusing BD-RB defaults with those in X264. BD-RB v0.32.07 overrides the X264 default, and will not even allow you to set it to "normal" because it would be non-standard for Blu-Ray. It is always either "none" or "strict" depending upon the setting of the B_PYRAMID hidden parameter.
10th March 2010, 01:37 | #7224 | Link |
@RichardB
Rarely does X264 ever crash. If it appears to be crashing in BD-RB -- you can pretty much assume that it is a problem with the CODEC that is frame-serving to it -- and that's almost always because some other package has "fiddled" with your software versions or settings. |
10th March 2010, 01:41 | #7225 | Link | |
10th March 2010, 03:41 | #7226 | Link |
Hi !
Okay, I'm completely confused. There seems to be a disagreement on this forum as to what the file structure should be regarding the correct DVD Rebuilder output. As I have said, my CERTIFICATE folder contains my BDMV Folder along with my BACKUP folder and a bunch of little files. When I try to drag over THE_DARK_KNIGHT folder in its entirety IMGBurn won't accept it! BTW.. below is the report frrom IMGBurn, when it first failed when DVD Rebuilder instructed it to write . I 22:43:03 ImgBurn Version 2.5.0.0 started! I 22:43:03 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7600) I 22:43:03 Total Physical Memory: 6,151,264 KB - Available: 4,531,136 KB W 22:43:03 Drive H:\ (FAT32) does not support single files > 4 GB in size. W 22:43:03 AnyDVD can interfere with ImgBurn's ability to verify accurately, please ensure it's disabled! I 22:43:03 Initialising SPTI... I 22:43:03 Searching for SCSI / ATAPI devices... I 22:43:04 Found 1 BD-ROM/HD DVD-ROM and 1 BD-RE! What next? Unless you guys have any suggestions for me.. I'll try to do the whole process (Ripping, Rebuilding and Writing) over again. Richard |
10th March 2010, 04:21 | #7227 | Link | |
Okay - Always a nice idea - 'Redo from start'. It works although the REG_MSCOMCTL.BAT file wouldn't execute complaining of a missing DLL but at least, i'm pass the point where x264 would crash.. Let you know in 5 hours in a half if everything went fine = ) |
10th March 2010, 05:09 | #7228 | Link | |
10th March 2010, 05:35 | #7230 | Link | |
10th March 2010, 18:15 | #7233 | Link |
I am having problems with "full backup" mode. The few discs I have tried consistently fail with the same message "error in attempt to multiplex," but when I do "movie only" mode it works fine. For the movie CHE I tried it twice in full backup and it gave me same error in two different places. Any help would be greatly appreciated.
[23:10:35] BD Rebuilder v0.32.07 (beta) - Source: CHE - Input BD size: 46.31 GB - Approximate total content: [03:55:04.198] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [23:10:38] PHASE ONE, Encoding - [23:10:38] Extracting A/V streams [VID_00264] - [23:10:52] Reencoding: VID_00264 (1 of 6) - [23:10:52] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,825 frames - [23:10:52] Reencoding: VID_00264, Pass 1 of 1 - [23:15:21] Video Encode complete - [23:15:21] Reencoding audio tracks (if req'd) - [23:15:25] Multiplexing M2TS - [23:15:38] Extracting A/V streams [VID_00266] - [23:16:08] Reencoding: VID_00266 (2 of 6) - [23:16:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 21,370 frames - [23:16:08] Reencoding: VID_00266, Pass 1 of 1 - [23:29:38] Video Encode complete - [23:29:38] Reencoding audio tracks (if req'd) - [23:29:42] Multiplexing M2TS - [23:30:20] Extracting A/V streams [VID_00267] - [23:31:17] Reencoding: VID_00267 (3 of 6) - [23:31:17] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 41,611 frames - [23:31:18] Reencoding: VID_00267, Pass 1 of 1 - [00:03:18] Video Encode complete - [00:03:18] Reencoding audio tracks (if req'd) - [00:03:25] Multiplexing M2TS - [00:05:03] Extracting A/V streams [VID_00268] - [00:06:15] Reencoding: VID_00268 (4 of 6) - [00:06:15] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 46,531 frames - [00:06:15] Reencoding: VID_00268, Pass 1 of 1 - [00:38:23] Video Encode complete - [00:38:23] Reencoding audio tracks (if req'd) - [00:38:30] Multiplexing M2TS - [00:40:32] Extracting A/V streams [VID_00269] - [00:42:13] Reencoding: VID_00269 (5 of 6) - [00:42:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 47,977 frames - [00:42:14] Reencoding: VID_00269, Pass 1 of 1 - [01:08:42] Video Encode complete - [01:08:42] Reencoding audio tracks (if req'd) - [01:09:00] Multiplexing M2TS - [01:10:18] Extracting A/V streams [VID_00262] - [01:44:54] Reencoding: VID_00262 (6 of 6) - [01:44:54] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 194,751 frames - Bitrate: 13,733 Kbs - [01:44:56] Reencoding: VID_00262, Pass 1 of 2 - [01:44:57] Reencoding: VID_00262, Pass 2 of 2 - [03:37:53] Video Encode complete - [03:37:53] Reencoding audio tracks (if req'd) - [03:39:32] Multiplexing M2TS - Error in attempt to multiplex: MUX_00262.meta - Can't create file C:\USERS\BRIAN\DOCUMENTS\BDREBUILDER\WORKFILES\TMP\BDMV\STREAM\00000.m2ts [03:39:33] - Failed to build structure, aborted [00:01:44] BD Rebuilder v0.32.07 (beta) - Source: CHE - Input BD size: 46.31 GB - Approximate total content: [03:55:04.198] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [00:01:45] PHASE ONE, Encoding - [00:01:45] Extracting A/V streams [VID_00264] - [00:02:26] Reencoding: VID_00264 (1 of 6) - [00:02:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,825 frames - [00:02:26] Reencoding: VID_00264, Pass 1 of 1 - [00:07:05] Video Encode complete - [00:07:05] Reencoding audio tracks (if req'd) - [00:07:09] Multiplexing M2TS - [00:07:24] Extracting A/V streams [VID_00266] - [00:08:58] Reencoding: VID_00266 (2 of 6) - [00:08:58] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 21,370 frames - [00:08:58] Reencoding: VID_00266, Pass 1 of 1 - [00:22:30] Video Encode complete - [00:22:30] Reencoding audio tracks (if req'd) - [00:22:34] Multiplexing M2TS - [00:23:05] Extracting A/V streams [VID_00267] - [00:26:12] Reencoding: VID_00267 (3 of 6) - [00:26:12] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 41,611 frames - [00:26:12] Reencoding: VID_00267, Pass 1 of 1 - [00:57:48] Video Encode complete - [00:57:48] Reencoding audio tracks (if req'd) - [00:57:55] Multiplexing M2TS - [00:59:31] Extracting A/V streams [VID_00268] - [01:03:12] Reencoding: VID_00268 (4 of 6) - [01:03:12] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 46,531 frames - [01:03:12] Reencoding: VID_00268, Pass 1 of 1 - [01:34:46] Video Encode complete - [01:34:46] Reencoding audio tracks (if req'd) - [01:34:54] Multiplexing M2TS - [01:37:06] Extracting A/V streams [VID_00269] - [01:38:33] Reencoding: VID_00269 (5 of 6) - [01:38:33] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 47,977 frames - [01:38:33] Reencoding: VID_00269, Pass 1 of 1 - [02:05:03] Video Encode complete - [02:05:03] Reencoding audio tracks (if req'd) - [02:05:21] Multiplexing M2TS - Error in attempt to multiplex: MUX_00269.meta - Can't create file C:\USERS\BRIAN\DOCUMENTS\BDREBUILDER\WORKFILES\TMP\BDMV\STREAM\00000.m2ts [02:05:22] - Failed to build structure, aborted [14:25:57] BD Rebuilder v0.32.07 (beta) - Source: CHE - Input BD size: 32.63 GB - Approximate total content: [02:15:22.739] - Target BD size: 7.72 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [14:25:58] PHASE ONE, Encoding - [14:25:58] Reencoding: VID_00262 (1 of 1) - [14:25:58] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 194,751 frames - Bitrate: 7,312 Kbs - [14:25:58] Reencoding: VID_00262, Pass 2 of 2 - [21:21:51] Video Encode complete - [21:21:51] Reencoding audio tracks (if req'd) - [21:23:20] Multiplexing M2TS [21:30:47]PHASE ONE complete [21:30:47]PHASE TWO - Rebuild Started - [21:30:47] Rebuilding AVCHD file Structure [21:37:42] - Encode and Rebuild complete [21:37:42]JOB: CHE finished. Last edited by jdobbs; 10th March 2010 at 21:06. |
10th March 2010, 19:04 | #7234 | Link | |
10th March 2010, 21:10 | #7236 | Link |
That error is coming back from TSMUXER when it attempts to multiplex. For some reason that app doesn't appear to have access to that folder -- or at least is getting an error when trying to create it.
That's really odd... maybe an access rights issue? |
10th March 2010, 21:28 | #7237 | Link |
I doubt it, but maybe I should try putting my workfiles in a different directory, i.e. not my user folder? However, I have made succesful full backups very recently with the same setup and the movie only mode worked on the same movie.
10th March 2010, 21:51 | #7238 | Link | |
"c:\pathto\bd_rebuilder\tools\tsmuxer.exe" "C:\USERS\BRIAN\DOCUMENTS\BDREBUILDER\WORKFILES\mux_00262.meta" Maybe it will give a clue as to something that might be happening. (I'm not sure what you BD Rebuilder path is). |
10th March 2010, 22:28 | #7239 | Link | |
