27th July 2002, 19:48 | #41 | Link | |
@1loser
Nearly the whole thread is about this new version. Have a look on the first page of this thread in the middle you find it as attachment of a DVD2SVCD post. Have much fun Toffy |
28th July 2002, 06:34 | #42 | Link | ||
Note (plus Bach's original post)
Persevere! |
28th July 2002, 10:36 | #43 | Link |
If I use this Modified version of DVD2SVCD what bitrate setting will correspond to the average bitrate when using CCE 2.5 by itself for the second pass? When I use CCE WITHOUT using DVD2SVCD I can predict the final size by calculating the bitrate with fitCD and using it for the average but DVD2SVCD has MIN and MAX average. I'm not sure if either of these will give me a predictable size. Can the author of DVD2SVCD please reply?
28th July 2002, 19:41 | #44 | Link |
Here a assumption from me about this method and the question asked what the purpose of this method was: Better quality or smaller filesize (or both).
I peronally think that with this method you could expect the same results when you're encoding with CBR 2530 rate. Only the size will be a lot smaller. Am I right here? When you use the same settings with CBR 2530 encoding then I get the same quality results but a bigger output file. (Didn't tested it though) |
29th July 2002, 10:41 | #45 | Link |
The idea with this method is like Normalization in audio. Your encoding quality will never be worse than ???? (depending on your offset Q value) and the big advantage is that it will fill up xx numbers of CDs needed to maintain that quality. So as Bach have said, a movie of 2 hours might fit snuggly onto 2 CDs maintaing the quality you would expect instead of 3 cds.
So, the number of discs used are not predictable, but all cds used will be filled to the max.
Cheers, dvd2svcd |
29th July 2002, 20:44 | #47 | Link | |
30th July 2002, 16:12 | #48 | Link |
Error with cce
Hi, i am trying the new roba method by i donīt get it to work
i got the message "is not a valid floating point value" Can anybody could help me This is the log of dvd2svc Drive is harddisk, no need to authenticate - OK. -------------------------------------------------------- - 7/29/2002 10:55:16 AM - DVD to SVCD Conversion - DVD2SVCD ver. 1.1.0 build 1 Pre 22 -------------------------------------------------------- Initializing Initializing finished. -------------------------------------------------------- - 7/29/2002 10:55:20 AM - DVD2AVI -------------------------------------------------------- Creating DVD2AVI INI file: - C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.INI Variable settings: iDCT_Algorithm: 32-bit SSE MMX Executing DVD2AVI. Executing DVD2AVI. Commandline: "C:\Program Files\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\VCD3\DVD2AVI_Project_file] -IF=[D:\VCD\vts_04_1.vob,D:\VCD\vts_04_2.vob,D:\VCD\vts_04_3.vob,D:\VCD\vts_04_4.vob,D:\VCD\vts_04_5.vob] Framerate: 29970 DVD2AVI processing done. -------------------------------------------------------- - 7/29/2002 11:31:18 AM - Free on drive C: 23290.88 mb - AUDIO Extraction -------------------------------------------------------- Found AC3 stream id: 0x82 Filename: C:\VCD3\Extracted_audio_1.ac3 Audio1 delay: 27 ms Audio extraction finished. -------------------------------------------------------- - 7/29/2002 12:11:40 PM - Free on drive C: 23079.12 mb - AUDIO conversion -------------------------------------------------------- Converting Audio to MP2. Filename: C:\VCD3\Extracted_audio_1.ac3 Executing BeSweet. Commandline: "C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\VCD3\Extracted_audio_1.ac3" -output "C:\VCD3\Encoded_audio_1.mp2" -logfile "C:\VCD3\Encoded_audio_1.log" ) -azid( -L -3db -c normal -s surround -g max ) -ota( -d 27 ) -2lame( -e -b 192 -m s ) Audio conversion of C:\VCD3\Extracted_audio_1.ac3 finished. Audio conversion finished. -------------------------------------------------------- - 7/29/2002 12:25:55 PM - Free on drive C: 22973.24 mb - Converting Pictures -------------------------------------------------------- Converting: C:\Program Files\DVD2SVCD\DefaultChangeCD.bmp Finished converting pictures -------------------------------------------------------- - 7/29/2002 12:26:04 PM - Free on drive C: 22972.45 mb - Video Encoding using Cinema Craft -------------------------------------------------------- - Editing AVS script file Executing Cinema Craft Encoder. StreamSectors: 1539589576 AudioSectors: 113336832 VideoPAPO: 22093416 ScanOffsetBytes: 166310 SeqAligningBytes: 10569950 DVDBytes: 0 VideoEndHeader: 8 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 600.00 PureMPEGStream: 1393423059.73 Seconds: 4659.36 CalcMPEGStream: 1393423059.73 Frames: 138592 CDSize: 740.00 Number of CDs: 2 Cut point 735.00 Variable Settings: Frames: 138592 Anti Noise Filter: Off Passes: 2 Image Quality: 17 VAF file creation: On Video Encoding Mode: RoBa Multipass VBR (a mix between 1-pass and multipass encoding) Min. bitrate: 300 Max. bitrate: 2530 Q. Factor: 30 Avg. Bitrate: 2230 Aspect Ratio: 16:9 (borders added, encoded as 4:3) ---AVS Begin--- LoadPlugin("C:\PROGRA~1\DVD2SVCD\SIMPLE~1\SIMPLE~1.DLL") LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\mpeg2dec.dll") mpeg2source("C:\VCD3\DVD2AV~1.D2V") SimpleResize(480,360) AddBorders(0,60,0,60) ResampleAudio(44100) ----AVS End---- Closing program CCE Max Speed: 0.460 Video Encoding finished. Executing Cinema Craft Encoder. StreamSectors: 833239988 AudioSectors: 112607096 VideoPAPO: 11162988 ScanOffsetBytes: 166310 SeqAligningBytes: 10569950 DVDBytes: 0 VideoEndHeader: 4 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 300.00 PureMPEGStream: 698733639.73 Seconds: 4629.36 CalcMPEGStream: 698733639.73 Frames: 138592 CDSize: 800.00 Number of CDs: 1 Cut point 795.00 StreamSectors: 1665085576 AudioSectors: 113336832 VideoPAPO: 24037416 ScanOffsetBytes: 166310 SeqAligningBytes: 10569950 DVDBytes: 0 VideoEndHeader: 8 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 600.00 PureMPEGStream: 1516975059.73 Seconds: 4659.36 CalcMPEGStream: 1516975059.73 Frames: 138592 CDSize: 800.00 Number of CDs: 2 Cut point 795.00 Variable Settings: Frames: 138592 Anti Noise Filter: Off Passes: 2 Image Quality: 17 VAF file creation: On Video Encoding Mode: RoBa Multipass VBR (a mix between 1-pass and multipass encoding) Min. bitrate: 300 Max. bitrate: 2530 Q. Factor: 30 Avg. Bitrate: 2230 Aspect Ratio: 16:9 (borders added, encoded as 4:3) ---AVS Begin--- LoadPlugin("C:\PROGRA~1\DVD2SVCD\SIMPLE~1\SIMPLE~1.DLL") LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2Dec\mpeg2dec.dll") mpeg2source("C:\VCD3\DVD2AV~1.D2V") SimpleResize(480,360) AddBorders(0,60,0,60) ResampleAudio(44100) ----AVS End---- '06:3' is not a valid floating point value |
31st July 2002, 01:33 | #49 | Link | |
Is it possible to incorporate another change in DVD2SVCD for the robshot method that will speed encoding up. For my first pass I use a simple resize and NO filters to create the vaf file. My second pass may look like this:
LoadPlugin("C:\Program Files\DVD2SVCD\MPEG2Dec\MPEG2DEC.dll") LoadPlugin("C:\Avisynth\temporalSoften2\TemporalSoften2.dll") LoadPlugin("C:\Avisynth\TomsMoComp\Avisynth\TomsMoComp.dll") LoadPlugin("C:\Avisynth\unfilter\UnFilter.dll") mpeg2source("arista25.d2v") ConvertToYUY2() TomsMoComp(1,15,1) BicubicResize(448,448,0.6,0.6,0,0,720,480) UnFilter(40,40) TemporalSoften2(2,5,5) AddBorders(16,16,16,16) ResampleAudio(44100) In my opinion the vaf file will be the same whether the filters are added or not so why add them on the first pass. Of course the experts here will probably disagree with that statement. Quote:
31st July 2002, 06:32 | #50 | Link | |
First pass: LoadPlugin("C:\Program Files\DVD2SVCD\MPEG2Dec\MPEG2DEC.dll") LoadPlugin("C:\Program Files\DVD2SVCD\SimpleResize\SimpleResize.dll") mpeg2source("arista25.d2v") ConvertToYUY2() SimpleResize(448,448) AddBorders(16,16,16,16) ResampleAudio(44100) Second pass: LoadPlugin("C:\Program Files\DVD2SVCD\MPEG2Dec\MPEG2DEC.dll") LoadPlugin("C:\Avisynth\TomsMoComp\Avisynth\TomsMoComp.dll") LoadPlugin("C:\Avisynth\unfilter\UnFilter.dll") LoadPlugin("C:\Avisynth\temporalSoften2\TemporalSoften2.dll") mpeg2source("arista25.d2v") ConvertToYUY2() TomsMoComp(1,15,1) BicubicResize(448,448,0.6,0.6,0,0,720,480) UnFilter(40,40) TemporalSoften2(2,5,5) AddBorders(16,16,16,16) ResampleAudio(44100) |
31st July 2002, 07:39 | #51 | Link | |
Here's an excerpt from the CCE users guide:
So you see, what you say just cannot be, or you just have been extremely "lucky". How did you compare the two VAF files?
Cheers, dvd2svcd |
31st July 2002, 18:32 | #52 | Link | |
31st July 2002, 22:39 | #53 | Link | ||
31st July 2002, 23:17 | #54 | Link |
Well, Bachs attitude may suck, but I understand it, you don't seem even to try to understand that what you're doing can't be done. My guess to why this might work for you is that you probably have patched CCE with the CRC patch to avoid CRC errors. No matter what you will stop this nonsense at once, because you are misleading other users. Feel free to contact Cinema Craft and get confirmation.
Both, cool it or I will lock this thread (which will be a pity).
Cheers, dvd2svcd |
1st August 2002, 02:08 | #55 | Link |
@1loser Hey man there is nothing wrong with being wrong. The thing we dont like around here is when someone is wrong and wont admit that mistake and still wants to shove useless information on to our users. This community is all about new idea's and the discussion of new or even old ideas. We have a place in this community for people that throw around idea's so with that said i hope you dont take that as an attack as I'm not attacking your intelligence but on that note you are sounding really "silly" right now and your views make no sense. Thats my 2cents.
http://biw.rult.at or #biw on efnet |
2nd August 2002, 02:44 | #56 | Link |
One other viewpoint to this vaf-reusing.
Even if adding filter is changing more or less every picture that will be compressed, there ought to be some correlation between the old and the new movie. Every frame in the picture is in the same place so the relative compressness between the easy and the hard part of the movie should stay the same. I believe that the original idea to this was to get a known quality corresponding to the choosen Q-Factor. If one is only intressed with better quality but maybe not exactly the same every time, I think that it would be intressting to make some tests using 1loser's split filter method before saying it is nonsense. What I meen is that even if a academical and teoretical view say it is nonsense it maybe a good aproximation. |
2nd August 2002, 15:40 | #57 | Link | |
I encoded "Jackson Brown Going Home" twice. 1) using 2 different avs scripts (no filters on the first pass and simple resize) than reusing the same vaf file but adding all filters and using a bicubic resize for the second pass. 2) using the same script (with all the filters in place and bicubic resize on the first pass). The results where about the same. I'm not really sure if one was better than the other, each person would have to judge for themselves. I'm not recommending this method to anyone because it's NOT the proper way to encode video and that's what this forum is all about. At the time I made my first post I didn't realize it was only possible because I was using the CRC patch. The ONLY point I wanted to make is that it was infact possible because I've done it about 20 times with results that I PERSONALLY thought were good but I know VERY little about video encoding and that's why I'm hear to learn how to do things in the proper manner. I just want to stress this point, I don't recommend using the patch so you can use this method and I already removed the patch from CCE. Update: I had to add the check sum patch back because even when I keep the avs file and ALL the settings the same I get the check sum error at 35 % completion. That's why I used it in the first place. Maybe if I did a fresh install of windows XP I wouldn't have that problem anymore Last edited by 1loser; 2nd August 2002 at 22:10. |
7th August 2002, 09:53 | #58 | Link |
This are my test results with RoBa for the movie Patch Adams PAL time 1.50:29
2 Audio Tracks 160 Kbps and 1 Subtitle. Bitrate Max. 2530 Min. 300 Max. Avg. 2230 Cd Size 800. 4 pass, Image Quality Priority 24, Anti Noise Filter 2, Q.Factor 30, Bias 20 [X]Linear Quantizer Scale, [X]ZigZag Scanning Order, [X]Progressive Frame, Intra DC Decision 10. In the AVS script Bicubicresize is used and no other filter. The Average Bitrate used was 1680 and it came out 2 800 CD. The quality is really awesome, when i look in my pc there's a little more "Mosquito noise" than a normal 5 pass, but on my tv is not really notable. So good, good thing. |
