14th October 2011, 14:48 | #4121 | Link | |
But... to each his/her own. Last edited by jdobbs; 14th October 2011 at 21:36. |
14th October 2011, 15:27 | #4122 | Link |
Aging Video Hobbyist
I'm surprised at this--I thought only eac3to handled those programs with many multiple m2ts files (I'm blanking on the terminology atm) whereby there are gaps in the audio that eac3to needs a 2nd pass to fix. tsMuxeR handles those too? I didn't know that.
14th October 2011, 19:33 | #4123 | Link | |
The only real problem I've seen is the longer-than-legal filenames TSMUXER tries to use on demuxing that forces you to output to an intermediate M2TS when the source path is exceptionally long or there are a lot of parts. Last edited by jdobbs; 14th October 2011 at 19:42. |
14th October 2011, 21:27 | #4124 | Link |
@laserfan
Hi! If I remember correctly, tsMuxer has been capable of processing Blu-rays based on .MPLS playlists, rather than simply joining .M2TS files, before eac3to made its initial appearance - and is used by other programs, such as BD-RB, multiAVCHD and others ;>} Last edited by setarip_old; 14th October 2011 at 21:38. |
15th October 2011, 04:55 | #4126 | Link | |
But I can't speak for your experience, only mine. Last edited by jdobbs; 15th October 2011 at 04:58. |
15th October 2011, 10:10 | #4127 | Link |
I don't say than eac3to is perfect, sometimes also fails.
My recommended workflow is use first eac3to to demux, if there are problems try with tsMuxeR.
16th October 2011, 01:12 | #4128 | Link |
Well, in this case, eac3to did fail... Harry Potter 7 Part 1's subtitles and audio pulls just fine, but the 264 files (720 and 1080) just don't play. In VLC, they won't play, and in windows media player, Just a black screen... I'm beginning to think that the AnyDVD HD failed to remove the protections on the image I created. I may try to pull it again...
19th October 2011, 05:49 | #4131 | Link |
I just learned that tsmuxer can perform trim/cuts.
I would like to use this feature to trim an srt file, and output a new srt file that has been trimmed with correct/adjusted timecodes. I was able to cut the .srt file using tsMuxeR GUI, but the output was .sup. Is it possible to cut and output .srt, or does tsmuxer only support converting srt to .sup? Also if tsmuxer only converts to .sup, but you happen to know of a program/script that can trim an srt file, please let me know. (hoping tsMuxer can do it because I can use the commandline app via batch files.) |
19th October 2011, 15:06 | #4132 | Link | |
http://www.videohelp.com/tools/Subtitle-Workshop |
26th October 2011, 01:39 | #4133 | Link | |
I was muxing H264 stream to M2TS and at about 70% progress point I received an error:
Thanks you very much. Last edited by Jolly Roger; 26th October 2011 at 01:42. |
4th November 2011, 05:32 | #4135 | Link | |
5th November 2011, 03:30 | #4136 | Link |
is the latest version still 1.10.6 as to be found on videohelp?
6th November 2011, 21:10 | #4138 | Link |
can tsmuxer recognize TextST files in blu-rays and demux / convert them to .sup?
21st November 2011, 11:34 | #4139 | Link |
B-pyramids
Hi everybody,
we are developers of BD Muxer (EasyBD) and we have problems with B-pyramids in x264. If anybody have technical info please send us to support@dvd-logic.com Thanks, Valery Koval. |
8th December 2011, 11:36 | #4140 | Link |
m2ts muxing with srt subs not showing in mpc-hc or media tank player
Ive tried to remux bd m2ts with srt, however on mpc-hc subtitles are not displayed even though i can select them, on media tank player that i own tvix hd n1 caffe subtitles are not available at all.
how can i fix this? i would like to have srt embedded in remuxed m2ts. no matter what i select bd or m2ts mux the results are the same. Ive also tried multiavchd to do the same task for me but no joy thanks! |
tsmuxer |
