Old 4th January 2010, 15:05   #11121  |  Link
hoborg
Originally Posted by tetsuo55 View Post
ATI: DBP is limited to L4,1 size, and there is a hard limit of 11 ref frames on all os's
Are you sure?
This sample is 5.1 with 3 ref frames and no problem on my ATI 4550, DXVA working fine under WinXP:
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L5.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Muxing mode                      : Container profile=Unknown@5.1
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 42s 125ms
Bit rate                         : 6 437 Kbps
Nominal bit rate                 : 6 700 Kbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.129
Stream size                      : 32.3 MiB (95%)
Writing library                  : x264 core 60 r901M 58d7d06
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=6 / rdcmp=psy / brdo=1 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=6700 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=1 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
I was thinking there is limit in 5.1 and 5 ref fremes on ATI
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline
Old 4th January 2010, 15:08   #11122  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Media Player Classic HomeCinema (x86/x64), svn 1486
Supported languages: BR, BY, CN, CZ, DE, EN, ES, FR, HU, IT, KR, PL, RU, SE, SK, TR, UA
Changes log
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline
Old 4th January 2010, 15:28   #11123  |  Link
fastplayer
Feature requests
Any chance that the menu bar can be toggled on/off like all the other UI elements?
What would be cool too if that thin border around the video could be removed when having MPC's window maximized.
fastplayer is offline
Old 4th January 2010, 15:33   #11124  |  Link
clsid
Do the "renderer settings" (from EVR CP) apply to the new Sync Renderer? If not, these options should be disabled in the GUI to avoid confusion.
MPC-HC 2.2.1
clsid is offline
Old 4th January 2010, 16:00   #11125  |  Link
ar-jar
I've tried to disable everything that doesn't apply both in Options and the Renderer options menu. One option that i have knowingly omitted to disable is "Wait for flushes". It doesn't do anything today in Sync Renderer. It is bundled with the other GPU flush alternatives in the original code. So Resizer, D3D fullscreen, EVR Buffers should apply to Sync Renderer as well (have to check the Reinitialization... option now that you mention it...) I will fix these later. -A
ar-jar is offline
Old 4th January 2010, 16:19   #11126  |  Link
ar-jar
Originally Posted by matthew_eli View Post
I tried to increase sync offset, but the problem still persist...I think that it's something related to resizeing: the tearing, of course is more visible at full screen and if I use bilinear (PS2.0) the problem becomes more evident. I already tried turn on GPU fluhes. This is a sample:
http://uploading.com/files/7c4649d1/sample1.avi/
Thanks
I tried your sample. It works fine (no tearing) on my XP machine with a low end gfx board, bicubic and a sync offset of 17 ms. In some cases this renderer is a bit more prone to tearing than the EVR custom because the latter has more elaborate GPU control code. I will try to add that code to the Sync Renderer too. -A
ar-jar is offline
Old 4th January 2010, 17:05   #11127  |  Link
73ChargerFan
73ChargerFan's Avatar
Happy New Year!
73ChargerFan is offline
Old 4th January 2010, 17:26   #11128  |  Link
tetsuo55
MPC-HC Project Manager
Originally Posted by hoborg View Post
Are you sure?
Video
That sample has an incorrect header, in fact its simply L4.1 (the header is a bad way to check for level compliance)
tetsuo55 is offline
Old 4th January 2010, 17:56   #11129  |  Link
gngn
the hedgehog
gngn's Avatar
On xp+nvidia there is a hard limit of 11 ref frames, on vista/7 there is no limit (16)
on XP+nvidia with new drivers (i think anything newer than 186.08) the limit is 14 Reframes, for SD as for HD sources: http://forum.doom9.org/showthread.ph...99#post1310899 , http://mpc-hc.svn.sourceforge.net/vi...&revision=1220
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73
latest MPC-HC (MVS2010 SP1, GCC 4.7.1)
VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on
gngn is offline
Old 4th January 2010, 19:01   #11130  |  Link
hoborg
Hm, i have more such samples, that is strange...
I bet there was an update ~1 yeas ago in ATI drivers allow play 5.1 up to 5 ref. frames on ATI 4xxx GPUs.
BTW, can you provide "correct" 5.1 sample with 1-4 ref frames to test?
My HTPC.
hoborg is offline
Old 4th January 2010, 20:28   #11131  |  Link
kikker
So, I just reinstalled W7 32bit with a fresh install of MPC-HC. Previously, I was running W7 RC. For whatever reason, I no longer need to have MPC's Video Decoder to have DXVA enabled. By unchecking h264 for both DXVA and ffmpeg, I allow Microsoft's built-in h264 decoder to load, as clearly shown in the filter list. Much to my surprise, CPU load remains under 8% on my paultry 2.2 GHz CPU with DXVA running flawlessly. How in the world is this happening? The RC version of W7 certainly didn't operate this way, as the MS decoder would completely choke on 1080p.
kikker is offline
Old 4th January 2010, 20:47   #11132  |  Link
avivahl
Microsoft's built-in h264 decoder has DXVA enabled...
avivahl is offline
Old 4th January 2010, 21:00   #11133  |  Link
kikker
Well, oddly it never allowed DXVA from within MPC-HC on my previous W7 RC install. I assumed that only WMP could take advantage of DXVA using MS's h264 decoder. It appears now that any DS player can use it.
kikker is offline
Old 4th January 2010, 21:16   #11134  |  Link
avivahl
I never used the RC, but maybe they limited the decoder there. On the RTM (final) release it does indeed work w/ any DirectShow based player.
avivahl is offline
Old 4th January 2010, 22:10   #11135  |  Link
hdboy
I have win7 rtm 32 bit and nvidia 7600gt and later 9800gt. 1486 is the first MPC build on xvidvideo.ru that gives me playback on a mix of 1080p mkv and blue ray m2ts without stutter on my TV hooked up as secondary monitor. Previously, I had to set my TV as primary monitor (not convenient at all) or use D3D full screen (which has its own drawbacks). So a big THANK YOU to ar-jar and all the devs
hdboy is offline
Old 4th January 2010, 22:13   #11136  |  Link
tetsuo55
Like i said you need to completely ignore that line that says "level whatever"
The real levels are technical limits.
Read more about them here: http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
tetsuo55 is offline
Old 4th January 2010, 22:40   #11137  |  Link
Tessier
Using an Intel GMA500 with W7 (without Aero) most h.264 720p and several 1080p clips play correctly using EVR Custom renderer (Microsoft decoder).
However, some 1080p clips play with low frame rate in full screen - but the are ok in windowed mode and even in D3D fullscreen mode. Is there an explanation for this (bad drivers maybe)? Is it possible (and does it make sense?) to modify the D3D fullscreen mode so it has an effect only if mpc-hc is sent into fullscreen?
Tessier is offline
Old 4th January 2010, 23:46   #11138  |  Link
mikelebron
Not true... at least on my system from Beta 2 the Microsoft Decoder utilized DXVA (low CPU) for H264... VC1 is a different story...
Im now running RTM with the same results..
Im a IGP Nvidia 9400.. it may depend on your video card support
mikelebron is offline
Old 4th January 2010, 23:55   #11139  |  Link
Nitrius
After getting some new computer parts; motherboard, cpu, ram, and graphics card, and reinstalled Win7 Ultimate x64, i've had a problem with playing HD .mkv files and subtitles. Getting the message that "atikmdag stopped responding, and the graphic driver restored itself successfully". When this happens, the screen goes black, still hearing the sound though, and when it's finished "restoring" it self, the player get's minimized, though the computer is mainly not responsive, so i have to use the task manager to quit MPC HC.
This only happens when i add subtitles to the videos i watch. And only with .mkv and HD files, or that i know of, haven't tested other file types and subtitles yet.
The computer i had before was:
Asus P5K-E
Intel Q6600 @ 3GHz
ATI 4980 1GB
This worked fine.
After the upgrade:
Asus Rampage II Extreme
Intel i7 920 @ 4GHz
ATI 5870 1GB
This works, but having problems with .mkv hd files and subtitles.
DXVA enabled ofc.
So do DXVA and subtitles have a problem with the newest cards from ATI, or is there something else weird with my new computer?
Nitrius is offline
Old 5th January 2010, 00:05   #11140  |  Link
Mixer73
This is exactly my configuration and I haven't had a chance to test ar-jar's work yet, can you give your configuration please?
Mixer73 is offline
dxva, h264, home cinema, media player classic, mpc-hc
