21st September 2018, 04:37 | #27721 | Link |
I've run into this error and have reported it. I already have IMPORT_PREPARE_MKV=0 set. It doesn't happen often, but it happened yesterday. All I did was restart the project and all was well. Win7 just seems to love screwing with me.
21st September 2018, 06:15 | #27722 | Link |
Not...because nothing ever ends. Except a sentence. Neener, neener! Disappointed, I was expecting a graphic of some kind.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
21st September 2018, 06:20 | #27723 | Link | |
I've reported before also. Sometimes a restart of a project clears it here also. So, Windows 7 has feelings and is aiming it's A.I. at you to get some kind of ....."screw with you judgement" on you? Hmm..and here I thought only people do that. Well, okay, some people also point the Sky for that kind of "Heey, man, why me??" which is extremely silly to me. As JD has so eloquently typed before, "People often shoot themselves in the foot." but that's not verbatim. My thinkth I'll be correcth soonth...hehe.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 21st September 2018 at 06:24. |
21st September 2018, 09:19 | #27725 | Link | ||
Metric system vs imperial https://www.youtube.com/watch?v=EUpwa0je6_Y Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 21st September 2018 at 12:06. |
21st September 2018, 12:18 | #27727 | Link | |
Just because humans have 10 fingers doesn’t mean the universe has to bend to our will and make everything conform to our wishes. But, the bottom line is that this is all semantics. Call it whatever floats your boat, but even decimal numbers have no place in defining boundaries in computer science. If you want to use GiB... fine. But that just makes GB a useless term, and starts the discussion as to why adding an “i” somehow solved something. The real argument is whether “kilo”, “mega”, or “giga” should even be used in a binary context, but it’s too late for that. Last edited by jdobbs; 21st September 2018 at 12:57. |
21st September 2018, 18:11 | #27728 | Link |
BD Rebuilder v0.60.01
I have updated the first post in this thread with a link to the lastest release of BD Rebuilder (v0.60.01). Changes for this release:
- Added experimental support for UHD-BD. - Added FFMPEG to the package to facilitate 10 bit frame serving for UHD encoding. - Added a new hidden option UHD_LIMIT_ENCODE which limits encodes to 10 mins for each M2TS. Meant for testing a backup before starting actual extended UHD-BD encoding. - Added video file support when selecting a background image for menus. Now you can choose an MKV, MP4, or M2TS to provide a full motion video for the background. - Corrected an error in which subtitles that have been imported in SRT format and then output to SRT, where there were multiple subtitles, were not included correctly in ALTERNATE output. - Added a new hidden option SPECIAL_3D_MUX. If set to 1 the TSMUXER parameters for "insertSEI" and "contSPS" are excluded from the video command line in the meta file. Some have reported that this fixes pixelation that has been experienced. - Added an adjustment for audio overhead when muxing mono or stereo AC3 encodes (there is a more significant overhead in the M2TS muxtiplexing by TSMUXER for some reason). This prevents occasional oversizing on these types of sources. - Added a check to correct a TSMUXER error in which is misinterprets stereo AAC audio as mono. - Fixed errors related to creating extremely large batch queues. - Fixed an error in ALTERNATE processing in which keeping intact audio from an imported AAC source would cause "ERROR in attempt to mux (MKVMERGE)". - Corrected a problem in which IVTC while using DirectshowSource() could cutoff the video before the end of the stream. - Updated the ALTERNATE selection dialog so that bitrates can be changed for individual presets. - Increased the maximum number of files that can be imported simultaneously. - Added a 1 second delay after preparing a file during import. This is an attempt to correct what might be a "race" issue that has been reported but I couldn't repeat. - Updated the included version of MEDIAINFO to version 17.12 in order to support reporting of HDR parameters. - Updated the included version of X265-64.EXE to v2.8.68 10 bit version. - Other minor corrections and cosmetic fixes. |
21st September 2018, 21:46 | #27729 | Link |
@jdobbs
Thanks for the new version. It is a pity that the bug with making a dvd from a 50 fps source has not yet been solved. I hope that is still on your to-do-list and will be addressed in the next version. see #27362 #27377 #27378 #27381 #27383 #27384 #27385 in this thread. |
21st September 2018, 23:49 | #27730 | Link | |
22nd September 2018, 17:28 | #27733 | Link | |
22nd September 2018, 19:04 | #27734 | Link |
Hi all first thank you Jdobbs for last release, and I need to ask somebody could recommend some Bluray/MKV player for image capturing and testing? I mean, I have some backups encode with Bd Rebuilder but I need to compare the movies so I need some player that can let me navegate frame by frame and get the screenshot, IŽll really aprecciate it, thank you in advance
22nd September 2018, 20:14 | #27735 | Link | |
https://potplayer.daum.net/ https://www.videohelp.com/software/M...ic-Home-Cinema They cannot play BDMV folders (no menus) so you'll have to pick the right .mpls to play. |
22nd September 2018, 21:58 | #27737 | Link | |
23rd September 2018, 10:48 | #27739 | Link | |
screenshot+capture+option+mpc-hc screenshot+capture+option+potplayer https://aboutdevice.com/how-to-take-...ith-potplayer/ https://aboutdevice.com/take-snapsho...t-with-mpc-hc/ |
23rd September 2018, 21:42 | #27740 | Link | |
