28th May 2012, 17:56 | #11141 | Link | |
.NET Web App Dev
That is a great option for non-DXVA compatible video.
Intel i7 5820k / 16 GB DDR4 / NV 970 / 4K ASUS Windows 8.1 |
28th May 2012, 18:08 | #11142 | Link |
The copying process uses around 0.8% CPU on my system. Can't say thats alot (a total usage of around 2%, for demuxing and other tasks)
What CPU do you have? It will probably be rather inefficient on AMD CPUs, because the highly optimized copy function won't work there.. May also depend on your GPU, i didn't really measure CPU usage with an AMD GPU, maybe i should. Considering it needs to copy around 100mb/s of image data (twice, actually), 1% of usage seems ok.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 28th May 2012 at 18:18. |
28th May 2012, 20:44 | #11145 | Link |
Unavailable
I think LAV Audio could use the BASS dll(s), more or less in the same way it already can use Arcsoft's DTS DLL. Of course, the final decision is in Nev's hands, and he might even refuse a patch that he happens to regard as "irrelevant".
28th May 2012, 21:42 | #11147 | Link | |
If you want to use some rare codec that nobody else seems to care about, then don't complain if the free software you use to decode it doesn't meet your satisfaction. Report the problem, offer to provide some samples, and then thank the developer for his time and efforts (which he is being very generous with just by offering the software to begin with). What I'm seeing here is like asking someone for money, and then insulting them if they don't give you the exact amount you asked for. It's just rude and ungrateful.
Windows 7 x64 i7 870 16GB RAM AMD 6870 |
28th May 2012, 21:44 | #11148 | Link | |
Have MO3, IT, XM, S3M, MOD, etc... support in one audio decoder will be great. But is it really worth the efort?
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
29th May 2012, 01:03 | #11150 | Link | |
latest build with the improvement below.
29th May 2012, 01:10 | #11151 | Link | |
.NET Web App Dev
Options to trade quality for performance are a must, and should be outlined as such. Your current options do not highlight which options are better for performance and which ones are worse. (If possible separate settings for separate resolutions - SD, 720, 1080 4K?) From using LAV, I can conclude that the only three things missing are performance options (and help), DVD support, and linked MKV support. LAV works well otherwise with my systems. I apologize if I don't understand the discussion ATM.
Intel i7 5820k / 16 GB DDR4 / NV 970 / 4K ASUS Windows 8.1 Last edited by Hera; 29th May 2012 at 01:13. |
29th May 2012, 01:33 | #11152 | Link | |
29th May 2012, 01:46 | #11153 | Link | ||
29th May 2012, 02:10 | #11155 | Link |
MPC-HC Developer
I sometimes upload here https://www.dropbox.com/sh/pr337z98gka7q2m/JLgkv2KBhe
29th May 2012, 06:56 | #11157 | Link | ||
Swallowed in the Sea
29th May 2012, 07:56 | #11158 | Link |
Unavailable
Well, the new LAV Audio uses just 1% or 2% more CPU-time than ffplay or Mplayer, so that's OK. But it still "eats" too much paging file (around 60MB), whereas ffplay consumes only 19MB, and the external MPC-HC audio decoder uses 22MB.
29th May 2012, 09:53 | #11159 | Link | |
