21st November 2013, 01:12 | #1242 | Link |
I don't think that TDecimate is particularly CPU intensive and therefore I don't think multi-threading would help much. The only time I've found TDecimate to be slow is when using really large Cycle/CycleR values, but that is a different problem, I think.
21st November 2013, 01:58 | #1243 | Link | ||
Tritical mentioning openmp there's also another good idea in that message that's been unrealized.
Here's some 1080i to 720x404 on FX8320 results: tfm() 51.15 fps, 50-60% cpu tfm().tdecimate() 36.64 fps 40-50% cpu setmtmode(2,4).tfm() 66.29 fps 95-100% cpu setmtmode(2,4).tfm().tdecimate() 29.79 fps 30-40% cpu nnedi3() 59.51 fps 95-100% cpu Sorathread/threadrequest used between tfm() and tdecimate() can give ~5% fps and cpu increase that's the only increase I've been able to achieve. Openmp was a huge increase in nnedi3, if it gave half the returns with tivtc it would be a much welcome increase. If tfm().tdecimate() used 100% cpu in this case is 70-80 fps a good estimate?
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 21st November 2013 at 07:42. |
3rd December 2013, 23:04 | #1244 | Link |
I haven't been able to find another source where tfm(mode=3) helps yet but I did find one where it causes missing frames.
Also after some testing it doesn't seem like tdecimate is the bottleneck but rather tfm(). Using telecide() or uncomb() with tdecimate() greatly increases fps and cpu usage.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
26th January 2014, 20:27 | #1245 | Link |
I realize the TIVTC package hasn't been updated in a long time, but I'm going to make a feature request anyhow...
It would be nice when if TDecimate mode=5, hybrid=2 (2nd VFR pass) was more verbose with display=true. Something similar to what TDecimate does for mode=0, hybrid=3. I do the first pass with TFM and TDecimate and make the necessary output files and feed them into the 2nd pass. Easy enough, but on the 2nd pass I have no easy, displayed for me on the video, visibility into the metrics calculated in the first pass that determine what frames are dropped or when it switches in or out of video/film mode. As a result it's hard to visually tune the vidThresh or dupThresh parameters. Last edited by Stereodude; 26th January 2014 at 20:30. |
27th January 2014, 01:20 | #1247 | Link | ||
28th January 2014, 00:29 | #1248 | Link | |
I wonder ... is there an "overlay" plugin that could that this output file, which has the frame number as the first parameter, read it, and then display the parameters onto each frame? |
28th January 2014, 01:27 | #1249 | Link | |
13th March 2014, 08:41 | #1250 | Link |
TFM(clip2=nnedi3()) a=last crop(0,0,0,-height/6).TDecimate(mode=3,clip2=a,hybrid=2,mkvout="timecodes.txt") Also getting crc errors 5 of 5 times with Code:
#pass1 TFM(clip2=nnedi3(),output="matches.txt").TDecimate(mode=4,output="metrics.txt",hybrid=2) #pass2 TFM(clip2=nnedi3(),input="matches.txt").TDecimate(mode=5,input="metrics.txt",tfmin="matches.txt",mkvout="timecodes.txt",hybrid=2)
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 13th March 2014 at 10:45. |
16th March 2014, 18:20 | #1251 | Link |
CRC error usually means your metrics do not match your file or something like that.
Try removing the hybrid=2 in your first pass? If its just metrics it shouldn't be used anyway, if I understood the manual correctly. Or perhaps it has something to do with the way you are using nnedi3 as your clip2? edit: I tested out your commands, running a first pass in Vdub (analyze video) And then a 2nd pass as a rendered output. Didn't get any CRC errors with the source clip I used.. Maybe its your source filter? Are you using DirectShow or something? It's possible you might not be getting frame accurate input that is being altered in some way? Last edited by osgZach; 16th March 2014 at 19:06. |
16th March 2014, 21:36 | #1252 | Link |
Did the first command (1 pass vfr) work for you?
According to readme, hybrid is ignored in mode=4 so that shouldn't be an issue but can be removed. I usually use DSS2 but changing to lsmash had no effect, the error had identical crc's. If tfm(output=matches.txt) and tdecimate(tfmin=matches.txt) are removed it works. Readme says tfmin is required for mode 5 but it runs without however the output is still interlaced. When working with 60p sources I never use tfm and vfr works fine then. Somehow 2 pass is working now, I removed clip2=nnedi3() which didn't work on the first try but did on the second try. Now timecodes don't match the video.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 16th March 2014 at 22:20. |
19th March 2014, 14:16 | #1253 | Link |
Well like I said, yes both passed worked fine for me.. exactly as you had posted them. If you were referring to something else ( different mode) I didn't test that.
I'm not familiar with Lsmash or DSS2, but generally when I am working with telecined content my sources are DVD's so I always index with DGindex and decode w/ the .d2v output and dgdecode. If the source file isn't mpeg/can't be indexed I'd try getting it into an intermediate AVI container. If it needs to be decombed/deinterlaced you could just bob it with a good filter like QTGMC, or TGMC_mod, with a .SelectEven() and then save that output. Then run 1stpass stats for Tdec on the intermediate AVI, then run your 2nd pass to another output (intermediate for more filtering, or straight into your output like x264, etc) to see if you could get your VFR that way? I haven't tested this, but I would assume it would work to some acceptible degree Last edited by osgZach; 19th March 2014 at 14:19. |
20th March 2014, 22:49 | #1254 | Link |
I was able to get 2 pass vbr working. The mismatched frame count of timecodes file and video was an issue of calling mp4fpsmod, it works fine in an mkv.
With single pass after stripping the function I was able to get an understandable error, instead of a crash. It needs linear access but I haven't manage to get that. Tried ffvideosource(seekmode=-1 and 0) directshowsource(seekzero=true,seek=false) both are supposed to give linear access. Couldn't find a way to get it with lsmash or dss2, my preferred source filters. Any ideas?
23rd March 2014, 22:01 | #1256 | Link |
It must have been an issue with the source. This worked fine on a few other sources:
DSS2("source.mpg",preroll=60, lavd="hm1") TFM(clip2=nnedi3()) a=last crop(0,0,0,-height/6).TDecimate(mode=3,clip2=a,hybrid=2,mkvout="timecodes.txt")
1st April 2014, 00:24 | #1257 | Link |
Since development seems to have ceased years ago, I don't know how much this will help. I came across a clip that tivtc removes the wrong frames but decomb and madvr ivtc remove the correct ones. It's a typical 3:2 pattern http://180upload.com/jeqngmb3uy7p. It is a little crude, basic cable, best not to listen to at work or around kids.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 1st April 2014 at 01:42. |
1st April 2014, 00:29 | #1258 | Link | |
1st April 2014, 06:05 | #1259 | Link |
Mediafire filter doesn't comply with fair use, uploaded it to another site and updated it. It's only talk of human anatomy.
15th August 2014, 07:45 | #1260 | Link |
I use this script
DirectShowSource ("F: \ Asi - Against Destiny \ ASI \ Asi - Against Destiny Ep 2 RoSuB HD.ts", fps = 25.000, convertfps = true, audio = true) .ConvertToYV12 () Video format is .ts video resolution is 1920x1080i and want to conver it in 1920x1080p and I want to delete Interlaced Any idea? |
tdeint, tivtc |
