26th March 2004, 01:23 | #281 | Link | |
26th March 2004, 01:27 | #282 | Link | |
26th March 2004, 02:43 | #287 | Link |
Every time I press the "Prepare" button (DVD-RB 0.24) for any DVD I've tried, with any settings I've tried, I get an error that says:
"Run-time error '5': Invalid Procedure call or argument" I'm surprised this hasn't yet been addressed. Last edited by Elnoyle; 26th March 2004 at 02:49. |
26th March 2004, 02:53 | #289 | Link | |
26th March 2004, 03:25 | #291 | Link | |
26th March 2004, 04:31 | #293 | Link |
@jdobbs
You know what? DIF4U labeled the video as NO PULL. Does RB perform pulldown no matter what? That might be a problem. Also, I noticed that the speed of CCE is dramatically less when launching from DIF4U (DOCCE4U) than with your app so some "filter" or setting is different. Not quite sure what just yet. I'm sorry, I really wish I knew more about CCE, AviSynth and all that goes along with it. Up until your app I just followed the Doom9 guide on the Big3 unless it had to be demuxed by VOBID, then I'd use a one click app. -redfive Last edited by redfive19; 26th March 2004 at 04:34. |
26th March 2004, 10:15 | #294 | Link | |
VSOP
PS. Darn how silent this place was this morning. But then, some of you guys might be needing some sleep I imagine. DS Last edited by JvD; 26th March 2004 at 10:56. |
26th March 2004, 13:16 | #297 | Link | |
26th March 2004, 13:23 | #298 | Link |
EXACTLY RIGHT!!! Here's a copy of the AVS from DIF4U
----------------------------------------------------- DOITFAST4U AVS SCRIPT import("x:\DoItFast4U\new.avs\addaudio.avs") LoadPlugin("x:\DoItFast4U\new.avs\mpeg2dec3.dll") Mpeg2Source("VTS__01_P06.I-TFF.16~9_1.d2v",idct=0) LoadPlugin("x:\DoItFast4U\new.avs\decomb.dll") FieldDeinterlace() AddAudio() ConvertToYUY2(interlaced=true) ---------------------------------------------------- #------------------ # AVS File Created by DVD Rebuilder # VOBID:01, CELLID:03 #------------------ mpeg2source("Z:\BURN\DVDREBUILD\D2VAVS\V01A.D2V") trim(9150,16319) ConvertToYUY2(interlaced=true) AddAudio() ---------------------------------------------------- BTW, I just checked my final product in my dvd player and I have none of the jitteriness (I am not trying to compare the Big3 to your app!!!). So it seems FieldDeinterlace and decomb filter are the only things different (I don't count trim since I did not do a CELLID demux with DIF4U). Any plans to add them in the future? I wonder if I can add them manually from now on if such a case arises again. Would that mess up the rebuilding process? -redfive |
26th March 2004, 14:23 | #299 | Link |
@redfive19: You can add anything to the avs scripts that are valid commands. You need to be in the 3 step process, and edit them before you click the "Encode" button. I knew there had to be some type of filtering going on, and now that you know what it is, you can modify the scripts accordingly. This is one of the reasons jdobbs made it easy to modify scripts. Remember this program is in early beta phase right now. Hopefully this stuff is detected later on. Sorry for not responding sooner.
Stiff |
26th March 2004, 15:59 | #300 | Link |
@stiff
Dude I totally understand and I completely appreciate jdobbs' work. I am very excited to see the future of this app. The only reason I posted asking if it was going to be added was because this is a bug report thread. I figure he should know that I finally figured out what the heck was wrong!!! From now on, my process will be (and I know it sounds laborious but I'd rather do it this way): 1. Let DIF4U create the avs scripts based on field type. 2. Import that info (if applicable) into DVD RB's avs scripts. (I think I can find/replace/add in multiple AVS files with UltraEdit or NoteTabPro) 3. Press encode from DVD RB. 4. Complete the rest of the process as normal. I think this whole experience has prompted me to learn more about field order, avi synth, and CCE. I probably would have known what the problem was sooner if I had studied these things before hand! Thanks for all your help. -redfive |
