Old 14th July 2011, 18:48   #181  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by SEt View Post
I suggest changing SetCacheHints return value to something like intptr_t for obvious reasons.
Does this mean that (most) plugins need to be recompiled?
I tried the new build but I get only 25% CPU utilization on my quad-core (upon playback in VDubMod). The previous build maxes out the CPU with the same script.
Old 14th July 2011, 19:29   #182  |  Link
SEt
Oops, I forgot to auto-add distributor to regular scripts. Redownload who got earlier version.
No recompilation unless they need to identify as caches, and it just underwent even greater change from void to int.
SEt is offline   Reply With Quote
Old 14th July 2011, 20:36   #183  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, the new build works just fine.
Old 14th July 2011, 22:37   #184  |  Link
Didée
Sorry if I'm a bit thick, but this does mean exactly ... what?
What's the scenario where a filter "needs to identify as cache"?
Old 14th July 2011, 23:00   #185  |  Link
SEt
For example ffdshow interface for avisynth is good candidate for such cache identification when "Buffer back/ahead" is turned on - no need to insert another cache after it and waste memory.
Old 15th July 2011, 05:16   #186  |  Link
yup
SEt
Your build based on Avisynth 2.6 Alpha 3?
yup.
yup is offline   Reply With Quote
Old 15th July 2011, 05:45   #187  |  Link
Boulder
Pig on the wing
Boulder's Avatar
The build is from the latest CVS sources so the code is as fresh as possible.
Old 16th July 2011, 20:16   #188  |  Link
levi
Another threading bugfix + updated to CVS version of Avisynth.
Thanks Set! This rocks! Any chance we could see a 64 bit compile?
levi is offline   Reply With Quote
Old 16th July 2011, 21:29   #189  |  Link
SEt
Maybe. I'm not very interested in 64-bit build now as I have only 6GB of ram and if you really want you can run some time-critical 64-bit code in 32-bit process too.
Old 19th July 2011, 18:11   #190  |  Link
SEt
Updated to fix two ImageSource() errors. (Discussed here and here)
Old 20th July 2011, 18:31   #191  |  Link
Büke
Parallelization across seperate processes
How about a plugin that loads any avs script into multiple processes, processes about 300 frames in each process, with 30 frames overlapping, sequentially combining the results in the master avs for final processing and encoding.
Additionally, the plugin can restart the processes to clear memory leaks.
Büke is offline   Reply With Quote
Old 20th July 2011, 22:00   #192  |  Link
Mini-Me
AFAIK, coding this as an Avisynth plugin would be exceedingly difficult or even impossible, given how Avisynth works. However, it's manageable for an outside piece of software...and while I haven't tested it myself, Chikuzen has written a Python script for AvsPMod that works very similarly to what you're describing.
Mini-Me is offline   Reply With Quote
Old 21st July 2011, 05:13   #193  |  Link
Büke
Why would it be so difficult? Interprocess hosting and communication is often done nowadays in the audio plugin world (VST, etc.) for crossing 32-64 bit barriers, for extended memory and stability, and it is done with quiet the low latency, too.
The master plugin needs an exe host counterpart listening for commands from the scheduling master, loads and hosts the given avs, caches the requested frames and sends them back in raw format, it can even use portions of TCPServer() code.
Now I think about it, the overlapping frames are not even necessary, since Avisynth can deliver random access frames as requested by the script and plugins on demand. Runtime scripts often do not (and should not) use progressive global state variable manipulation, as most are made to be randomly seekable. This means, the processes can process less frames in parallel, such as 10-100, and maintain low memory overhead.
Macro parallelization via master controlled sub-processes is a real generic solution to this problem of utilizing all cores, it can even be built into Avisynth natively. The sub processes can even introduce additional compatibility for cross 32/64 bit hosting, and stability by restarting crashing job segments with alternate settings/scripts.
Having this done natively or via a a plugin such as ImportParallel(string AVSFile, int "ProcessCount", int "FrameCount", ...) all in memory will be a lot faster and transparent than using splitting scripts in other languages and using slow disk caches.
Old 21st July 2011, 05:22   #194  |  Link
SEt
This is unrelated to this thread. I request moderators to split the posts.
Regarding the suggestion, I think another hack is not what avisynth needs today. It needs clear and mandatory rules for plugins how to deal with multithreading.
Old 21st July 2011, 05:41   #195  |  Link
Büke
Why is this a hack? It is a real solution, that has been proven in other domains.
A host's mission is to make things easier for plugin authors, who would rather focus and specialize on the complexities of the algorithms, rather than their parallelization or optimization, or user interface, etc, etc.
Are you suggesting that new rules be put out and all plugins be rewritten, and new ones with additional complexities?
If the plugin authors were interested in multi-threading more than the core algorithm, they would have done this in majority of the plugins, including the native filters already..
More practical, and less dogmatic, is what I say.
Old 21st July 2011, 22:41   #196  |  Link
SubJunk
Thanks a lot for the update, SEt!
SubJunk is offline   Reply With Quote
Old 22nd July 2011, 09:04   #197  |  Link
jpsdr
Some 64bits pluggins can have sometime speed increase of 30%.
I've noticed, on QTMG for example, an increase speed of around 15% under 64bits.
My personnal thought, at the actual stage is :
The way MT is implemented on avisynth seems not to be very stable, so, the best way actualy to have a stable multithreading would be to not use MT version of avisynth, split your work and start several task. For exemple, launching 6 Vdub task on 6 files.
Using not MT version of avisynth keep garanty stability, and running several tasks make all your core work.
I think, it could be more interesting to focus on single threading 64bits port, because good 64bits port can provide good improvement in speed.
I've noticed it with the unfornutaly dead project of the 64 bits version begun by JoshyD.
Old 29th July 2011, 03:51   #198  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Does anyone else suffer from I/O operations sometimes getting very slow when encoding something using SetMTMode? I noticed the behaviour already in the old build and just got it with the new build. Creating a d2v file was getting along very slowly until I paused x264 which was using 95-99% of the CPU. The x264 process was running at idle priority so it should not cause such things. The MT'd Avisynth v2.5.8 doesn't have this issue, or at least I never noticed it.
Old 29th July 2011, 10:49   #199  |  Link
leeperry
Kid for Today
X2,
but how can you MT w/ the new build? I'm currently using MT 0.70 w/ the 2009.09.19 2.6 build. MT 0.70 doesn't work w/ the new build, and neither does this version of MT: http://forum.doom9.org/showpost.php?...postcount=1093
I use avisynth in realtime in ffdshow, I do need MT.
Old 31st July 2011, 19:49   #200  |  Link
levi
X2,
Did you try this one:
http://code.google.com/p/avisynth64/...0.rar&can=2&q=
