7th May 2008, 12:32 | #3541 | Link |
Curious BetaTester
is there a problem ffdshow-tryout svn1954 being compiled with gcc-4.0.4
make[1]: Entering directory `/home/User/svn/ffdshow-tryout/ffdshow-tryout/src/imgFilters' gcc -c -mno-cygwin -mdll -fno-rtti -mthreads -pipe -D_WINGDI_ -DUCLIBCPP -D_GLIBCPP_HAVE_MBSTATE_T -D_WIN32_IE=0x0500 -DARCH_IS_IA32 -DARCH_IS_32BIT -DHAVE_MMX -mmmx -msse -mfpmath=sse -w -DNDEBUG -UDEBUG -DFFDEBUG=0 -I. -I.. -Iuclibc++ -Ibaseclasses -I../baseclasses -IimgFilters -I../imgFilters -Implayer -I../mplayer -Isettings -I../settings -Isettings/filters -I../settings/filters -Icodecs -I../codecs -Isubtitles -I../subtitles -Iconvert -I../convert -Idialog -I../dialog -IaudioFilters -I../audioFilters -Icygwin -I../cygwin -Iffmpeg -I../ffmpeg -Iacm -I../acm -Ifilters -I../filters -Imuxers -I../muxers -I/dx/Include -L/dx/MingLib -ldx9 -O3 -march=i686 -fomit-frame-pointer -MMD -o ffdshow_imgfilters_all.o ffdshow_imgfilters_all.cpp gcc.exe: -ldx9: linker input file unused because linking not done make[1]: *** No rule to make target `../ffmpeg/libavcodec/i386/skl_dct_sse.o', needed by `.all'. Stop. make[1]: Leaving directory `/home/User/svn/ffdshow-tryout/ffdshow-tryout/src/imgFilters' make: *** [lib] Error 2
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
7th May 2008, 14:50 | #3542 | Link |
Try this (untested) patch:
Index: Makefile =================================================================== --- Makefile (revision 1954) +++ Makefile (working copy) @@ -4,7 +4,8 @@ SRCS_C=ffdebug.c -SRCS_NASM=cpuid.asm memcpy.asm subtitles/fontRenderer.asm convert/colorspace_rgb_mmx.asm +SRCS_NASM=cpuid.asm memcpy.asm subtitles/fontRenderer.asm convert/colorspace_rgb_mmx.asm \ + imgFilters/Skal/skl_dct_sse.asm imgFilters/Skal/skl_fdct_mmx.asm include makefile.inc @@ -58,9 +59,8 @@ baseclasses/baseclasses_all.o \ ffmpeg/libavcodec/golomb.o \ audioFilters/TaudioFilterConvert.o audioFilters/dotproduct.o \ - imgFilters/simple_idct_mmx.o ffmpeg/libavcodec/i386/skl_dct_sse.o \ - ffmpeg/libavcodec/i386/skl_dct_sse2.o ffmpeg/libavcodec/i386/skl_fdct_mmx.o \ - ffmpeg/libavcodec/i386/skl_fdct_sse2.o + imgFilters/simple_idct_mmx.o imgFilters/Skal/skl_dct_sse.o \ + imgFilters/Skal/skl_fdct_mmx.o lib: $(MAKE) -C baseclasses
MPC-HC 2.2.1 |
7th May 2008, 17:01 | #3543 | Link |
Curious BetaTester
thanks but still same error
8th May 2008, 13:28 | #3544 | Link |
李姗倩 Lǐ Shān Qiàn
Queue Enabled->MPC Sub Bad Sync : Last Good 20080127
I think the embedded sub in MKV is out of sync (by about 0.5 sec?) in mplayerc_20080308 mplayerc_20080414 from Guliverkli2, if the internal MKV splitter is used, and if Queue is enabled in ffdshow. mpc 20080127 build works ok, so this could be a pb of MPC. (Edit: I mean, if MPC's internal sub renderer is used in VMR9. And output color space is RGB32 btw) Tested ffdshow tryouts official beta4 and the newest nightly (ffdshow_rev1953_20080504_xxl.exe) Test clip where softsubs and hardsubs should have the same timing http://ffdshow.faireal.net/tmp/Hard_vs_Softsubs.mkv 48kb Last edited by Liisachan; 8th May 2008 at 13:30. |
8th May 2008, 19:24 | #3545 | Link |
Confirmed. The only change to MPC in that period that is related to the above is this one:
http://guliverkli2.svn.sourceforge.n...ev&revision=44 I don't see any obvious bugs in that revision. Maybe someone else is able to spot it.
MPC-HC 2.2.1 |
8th May 2008, 20:55 | #3546 | Link |
李姗倩 Lǐ Shān Qiàn
Thanks for confirmation. if anything, this change is fishy, but since MPC works ok if queue is not enabled in ffdshow, perhaps this is not a pb of MPC, but rather related to the hack used by ffdshow queue...
9th May 2008, 03:05 | #3547 | Link |
This is for EVR custom and MPCHC but it might be related to sub desynchronizing issue http://mpc-hc.svn.sourceforge.net/vi...v&revision=460.
9th May 2008, 11:45 | #3548 | Link |
The regular version of MPC does not have that code.
I will mess around with rev44 to see if I can fix the problem. But it may take a few days as I've many other things to do.
MPC-HC 2.2.1 |
9th May 2008, 13:31 | #3551 | Link |
李姗倩 Lǐ Shān Qiàn
Thank you, clsid!
Additional info: - Enable VMR9 Mixer mode and I see this problem. If uncheck that , the problem is gone. So I tend to think now this is MPC's problem. - both internal and Haali's MatroskaSplitter have the same problem, so Splitter is not related. I have this same problem on 2 PCs. One has nVidia quadro fx 500, the other nVidia GeForce 8400GS. |
11th May 2008, 20:46 | #3555 | Link |
Does ffdshow create thumbnails for avi files? Cause I notice when I encode a new avi file that ffdshow appears and goes away real fast and my thumbnail is created. I was wondering why it doesn't work for ogm or mkv files?
11th May 2008, 23:38 | #3556 | Link |
Thumbnail generation is done by a shell extension of Explorer. It is possible to activate it for any file extension using a simple registry tweak:
Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\.flv\ShellEx\{BB2E617C-0920-11D1-9A0B-00C04FC2D6C1}] @="{c5a40261-cd64-4ccf-84cb-c394da41d590}"
MPC-HC 2.2.1 |
12th May 2008, 10:52 | #3558 | Link |
small cosmetic bug
on the "Preset autoload conditions" window, it says : - On one of the conditoins match (OR) small request (for Haruhiko i think) In the Subtitles settings, could we have a feature to temporarily disable FFDshow internal subtitle support if Directvobsub is detected in the graph? I tried to do this by setting 2 profiles. In the first one, i have "Subtitles" enabled. In the second one, I disabled "Subtitles" and enabled the following condition: "on a DirectShow filter presence" = DirectVobSub Then enabled "Automatic preset loading" but it just doesn't work, Subtitles are always enabled regardless if DirectVobSub is present in the graph or not.. (the 2nd profile is never automatically loaded) See you, TSR Last edited by TheShadowRunner; 12th May 2008 at 11:30. |
12th May 2008, 19:31 | #3559 | Link | |
13th May 2008, 02:14 | #3560 | Link |
I was wondering, in the ffdshow audio decoder, when input sample format is not equal output sample format and also at the same time there is a few mixer operations inbetween, is the mixing performed before the sample format conversion or after ?
and what can help indicate that results are bit-identical ? I am using madflac to decode and selected uncompressed in ffdshow audio decoder to use the mixer to convert 5.1 into 2.0, but I am unsure as to what happens in the ffdshow decoder to know what is best, to loose some data in the extra channels or go through sample format covertion, knowing the signal flow would help me decide what is better |
