25th March 2009, 23:11 | #821 | Link |
Oh, from what I can tell, dvd vob needs ifo to get it's color palette and stream language. Without the ifo file it relies on the player's color palette and stream languages are unknown.
With BD a standalone (m2)ts file displays subs fine, it also contains stream language (tsmuxer detects) but MPC-HC sets the stream languages as unknown. Last edited by turbojet; 25th March 2009 at 23:15. |
25th March 2009, 23:27 | #822 | Link |
MKVToolNix author
Found the problem. The next release will have it fixed.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
26th March 2009, 22:38 | #824 | Link |
Here's a 1080p sup muxed with 1080p blank video in an m2ts if you still needed it.
Sorry it took so long, forgot about it, and thanks for looking at supporting it. Last edited by turbojet; 2nd April 2009 at 05:25. |
26th March 2009, 23:06 | #825 | Link |
MKVToolNix author
Thanks again for providing the files.
30th March 2009, 07:51 | #826 | Link |
Ubuntu French Roast
Not sure if this has been reported already, but when I import a MKV file that has a colon in its File/segment title, the colon gets replaced with a "c" in the box under the "Global" tab.
Copy Protection: A clever method of preventing incompetent pirates from stealing software and legitimate customers from using it. |
30th March 2009, 09:14 | #827 | Link |
2009-03-29 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge, mkvetract: new feature: Added support for TrueHD audio (read from raw streams with or without embedded AC3 frames, MPEG program streams). Thank you for adding support for TrueHD streams. Direct muxing from a evo file fails with Error: common.cpp/safemalloc() called from file src/common/mpeg4_common.cpp, line 1039: malloc() returned NULL for a size of 229756 bytes. Demuxed streams work fine. evo sample |
30th March 2009, 09:17 | #828 | Link | |
MKVToolNix author
30th March 2009, 11:45 | #830 | Link |
MKVToolNix author
MLP is not TrueHD, even though it is almost identical. I've purposefully not added support for MLP.
30th March 2009, 12:19 | #831 | Link |
Of course you could store MLP content as A_MLP (all else similar to TrueHD muxing)... The purpose of this would be to make demuxed MLP audio tracks (coming from DVD-Audio) seekable. Demuxed MLP audio tracks are not properly seekable in demuxed form due to being VBR.
Not sure how important this is, though. I think TrueHD support is *much* more important! However, I've heard, the libav guys will very soon have a fully functional MLP encoder. That might increase need for MKV MLP muxing? |
30th March 2009, 15:56 | #832 | Link |
MKVToolNix author
True. Here's a build with MLP support on top of the TrueHD support and a fix for the loss of the last TrueHD/MLP frame during muxing: http://www.bunkus.org/videotools/mkv...-102-setup.exe
30th March 2009, 22:54 | #834 | Link |
MKVToolNix author
Please use http://www.bunkus.org/videotools/mkv...-103-setup.exe for TrueHD/MLP tests -- earlier builds had the sample rate and number of channels swapped for TrueHD/MLP tracks read from EVOs.
2nd April 2009, 08:25 | #837 | Link |
MKVToolNix author
The only type of DTS audio that's not supported yet that I am aware of is DTS Express. I don't have plans to implement support for it in the near future.
