13th October 2016, 21:54 | #4321 | Link | |
Relative encoding time (to x265 1.9+217; less -- faster): enc.time| description 100.0% | x265 1.9+217 107.8% | x265 1.9+223 108.4% | x265 2.1+21 106.3% | x265 2.1+21 --limit-tu 1 105.2% | x265 2.1+21 --limit-tu 2 --limit-tu 1 & --limit-tu 2 produce the same output in my test. Raw data in attachment. |
14th October 2016, 03:00 | #4322 | Link | |
14th October 2016, 14:19 | #4324 | Link | |
Example of 10-bit encoding with options "-p slower --crf 16": original sample www.msystem.waw.pl/x265/uhd177.y4m x265 1.9+217 www.msystem.waw.pl/x265/u217.mkv x265 1.9+223 www.msystem.waw.pl/x265/u223.mkv x265 2.1+21 --limit-tu 1 www.msystem.waw.pl/x265/u1.mkv x265 2.1+21 produces the same output as 1.9+223. In this sample there is no details, it is only for check of smooth move. The move in u217.mkv is simply wrong. In movies at full resolution the effect is only on small objects -- big objects are moving smoothly but small objects not, it is unnatural. From version 1.9+223 is much better (with --limit-tu 1 or 2 is also better). |
14th October 2016, 14:52 | #4325 | Link | |
However the other samples are hard to make a difference given the source's resolution, I mean 340x160 feels like we're back at the stone age. Could use a 720p source to begin with. |
14th October 2016, 16:31 | #4326 | Link | |
14th October 2016, 16:39 | #4327 | Link | |
Also, we should be using at LEAST mod8 resolutions, right ? and at that low resolution, the upscaling artifacts can be quite distracting, and a major source of visual defects that'll vary between players. That said, there is tons of SD-only content in this world, and defects are easier to see in SD and encoding is certainly faster. I'd be happy to have test results at 640x360, certainly. |
15th October 2016, 01:03 | #4328 | Link | |
A while ago I talked about problems at crf 24 due to the number of b-frames with higher quality presets. This test clip reveals the same kind of problem I witnessed. Encoding this clip at crf 24 preset slow with version 2.1+2-c0d91c2b4048 the judder on the lead vehicle is truly spectacular. As I reduce b-frames count using 2, then 1 and 0, the results get better. 1 is far from perfect, but the reduction in judder with each reduction in b-frame count is pretty clear. 0 produces no judder on the vehicles, but there is some judder on the clouds of dust. I think that judder is actually just blocking artefacts as the problem extends into the ground. I haven't played with --limit-tu yet. |
15th October 2016, 17:41 | #4329 | Link |
x265 v2.1+22-c97805dad914 (MSYS/MinGW, GCC 6.2.0, 32 & 64bit 8/10/12bit multilib EXEs)
16th October 2016, 11:53 | #4330 | Link |
Hi! I would like to (re-)encode my original very high bitrate 1080p h.264 movies to x265 to save space on my nas. My goal is to maintain the picture quality nearly as well as possible, but to save a good amount of space at the same time. At the moment i use the newest x265 version 2.1+21 and Staxrip.
I use a Windows 10 Machine with 2x 14 Core Intel Xeon E5 2683v3 CPUs. So far I made good experiences with the following settings for the first CPU: "--crf 18 --preset veryslow --output-depth 10 --pools "+,-" --pmode --pme --no-sao" and: "--crf 18 --preset veryslow --output-depth 10 --pools "-,+" --pmode --pme --no-sao" for the 2nd CPU. Would you suggest other settings or do you have tweaks to optimize my result? In the end, i would be happy with a picture quality of 80-90% compared to a optically lossles encoding. Encoding time is not a primary sector. Thank you! |
16th October 2016, 17:39 | #4331 | Link |
I would take out --pme option it offer little to no benefit
From docs Parallel motion estimation. When enabled the encoder will distribute motion estimation across multiple worker threads when more than two references require motion searches for a given CU. Only recommended if x265 is not already saturating CPU cores. --pmode is much more effective than this option, since the amount of work it distributes is substantially higher. With –pme it is not unusual for the overhead of distributing the work to outweigh the parallelism benefits.–pme will increase utilization on many core systems with no effect on the output bitstream.
If you fail to plan; you plan to fail, would you not agree? Think about it. |
17th October 2016, 15:57 | #4332 | Link | |
I agree with HWK drop --pme, it isn't worth it. Also, I'd drop --pmode as well. I have actually seen fps drop with it. I'm running dual e5-2683 v4 16 cores. I also use --no-strong-intra-smoothing, helps to keep things a littler sharper. If you are running x265 v2.1+20 or newer you can use --limit-tu 1 or 2. It'll speed up your encoding with virtually no quality loss. You could also try --limit-refs 3 since you are running very slow preset it sets that to 1. Based on my testing the option that gives the best quality increase is --rd 5/6, they are the same right now. Which Very Slow defaults to rd 6, so you've already got it. So you spend\waste a lot of time with limit-refs < 3 and limit-tu 0. Edit: Just noticed that --rskip is removed in veryslow as well. I'd suggest enabling that as well. Last edited by brumsky; 17th October 2016 at 16:02. |
20th October 2016, 13:07 | #4333 | Link |
New CLI options:
--[no-]opt-qp-pps Discard optional HRD timing information from the bistream. Default enabled --[no-]opt-ref-list-length-pps Discard optional HRD timing information from the bistream. Default enabled x265 2.1+25-0e9e52640546 |
20th October 2016, 13:31 | #4334 | Link |
Pig on the wing
As it's been a while since I last tried x265 - are there any new recommended encoder settings to test to compare with x264 and --tune film? I've got three seasons of Star Trek TOS to encode and the HD transfers are quite far from perfect at least in the first season. It might be useful to see if x265 will produce better output around the same bitrate. I usually downsize (with some sharpening to compensate) and encode at 720p with CRF 18 using x264 and the preset veryslow.
20th October 2016, 16:52 | #4335 | Link |
Can anyone give some inside into the whole hdr processing?
I thought --master-display ... and --max-cll ... were used to add the timing informations that --opt-qp-pps and --opt-ref-list-length-pps remove,... |
20th October 2016, 17:03 | #4336 | Link | |
Don't mix up HRD with HDR - HRD stands for Hypthetical Reference Decoder, and its a different metadata block. Its generally related to various compliance checks, VBV etc. Not sure decoders typically even read this, which is why they may opt to remove it by default.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 20th October 2016 at 17:05. |
20th October 2016, 19:11 | #4337 | Link | |
--preset medium --output-depth 10 --merange 38 --rd 5 this will be about the same speed or a little bit faster than x264 very slow. It'll also be at least as good in picture quality. And it'll produce a file that's about 60% as large. --merange 38 is for 720p encodes. If you encode 1080p material, then remove this option as the default motion search range is configured for 1080p. --output-depth 10 will prevent the encoder from introducing banding. Don't use if you are trying to play back your encodes on something other than a PC. The documentation here is useful: http://x265.readthedocs.io/en/latest/cli.html There is no tuning for film. In my opinion at crf 18 you're going to lose some noise and some acuity in your source material (just like with x264) but you'll find x265 is extremely consistent, much better than x264. Finally, presets in x265 change over time. It's still effectively in alpha, since not all published options are actually implemented. e.g. --rd 6 is actually the same as --rd 5. |
20th October 2016, 20:04 | #4339 | Link | ||
