Old 25th March 2009, 21:53   #221  |  Link
Greif
interesting.... That's a new error, I'll have to inspect the code.
what OS & version of .net do you have installed?
HdBrStreamExtractor
Greif is offline   Reply With Quote
Old 26th March 2009, 03:04   #222  |  Link
~bT~
н∂-ƒαиαтι¢
^ that error is in the unpatched build. try the svn build.
Old 26th March 2009, 04:40   #223  |  Link
swaaye
Why does it want to extract MPEG2 streams into MKV only? Can M2V or MPG be an option here?
edit: nevermind me. I was using an old version.
swaaye is offline   Reply With Quote
Old 29th March 2009, 16:21   #224  |  Link
saint-francis
too much lurking
saint-francis's Avatar
Small bug. If you keep the tool open and run several operations in a row, eventually the drop down boxes start to list the options multiple times.
saint-francis is offline   Reply With Quote
Old 30th March 2009, 23:53   #225  |  Link
Greif
@saint-francis: that's an easy fix. thanks for letting me know
I'll update the code and release a new version soon.
HdBrStreamExtractor
Old 31st March 2009, 11:39   #226  |  Link
Furiousflea
Vista x64\.Net Framework 3.5 SP1
Cheers,
Furiousflea is offline   Reply With Quote
Old 4th April 2009, 03:34   #227  |  Link
lifespeed
Good work!
I love your interface to eac3to! It makes playing Blu-ray on PCs only a few mouse clicks. Without the MKV format (or a special soundcard) we don't get the good sound.
lifespeed is offline   Reply With Quote
Old 5th April 2009, 21:33   #228  |  Link
kurt
sidekick
kurt's Avatar
feature retrieving with *.ts files does not work. no stream list appear ...
[21:31:56] Retrieving features
[21:31:56] Arguments: "C:\Marc\casino_royale_sample.ts"
[21:32:23] TS, 1 video track, 1 audio track, 1 subtitle track, 0:00:59, 24p /1.001
[21:32:23] Der Index lag außerhalb des Bereichs. Er muss nicht negativ und kleiner als die Auflistung sein.
Parametername: index
[21:32:23] mscorlib
[21:32:23]    bei System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
   bei System.ThrowHelper.ThrowArgumentOutOfRangeException()
   bei System.Collections.Generic.List`1.get_Item(Int32 index)
   bei eac3toGUI.HdBrStreamExtractor.backgroundWorker_OutputDataReceived(Object sender, DataReceivedEventArgs e)
[21:32:23] mscorlib
[21:32:23] mscorlib
[21:32:23] Feature Retrieval Completed
no problems with mkv files...
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline   Reply With Quote
Old 11th April 2009, 15:39   #229  |  Link
kikker
Thanks for your work on this project. There isn't a more elegant simple way to break up and save the streams on BD that I can find at least.
Is there a way in the options for the SUP streams to output the language as the name of the file, i.e. ENGLISH.sup, FRENCH.sup, etc.? Thanks!
kikker is offline   Reply With Quote
Old 11th April 2009, 16:36   #230  |  Link
Greif
Yes, I can add the language to the filename. I'll put it on the list.
HdBrStreamExtractor
Old 12th April 2009, 10:12   #231  |  Link
ACrowley
Your Gui wont work anymore here
I get this Error too on some Files/Folders. Sometimes it works, sometimes not..
[10:10:18] Retrieving features
[10:10:19] Arguments: "C:\AV Tools\T E S T SAMPLES\Mpeg2_AVC TS\Eminem.TS.Mpeg2.Sample.ts"
[10:10:37] TS, 1 video track, 1 audio track, 1 subtitle track, 0:00:50, 60i /1.001
[10:10:37] "Eminem Live From New York City", Showtime 1 (ST1)
[10:10:37] Der Index lag außerhalb des Bereichs. Er muss nicht negativ und kleiner als die Auflistung sein.
[10:10:38] mscorlib
[10:10:38] bei System.ThrowHelper.ThrowArgumentOutOfRangeException()
[10:10:38] Der Index lag außerhalb des Bereichs. Er muss nicht negativ und kleiner als die Auflistung sein.
[10:10:38] mscorlib
[10:10:38] mscorlib
[10:10:39] Feature Retrieval Completed
I use Vista x64 SP1 with latest Updates /latest eac3to
Your Gui still cant use demuxed Audio Tracks ? i can load them correct and the eac3to Infos will appear, but your gui doesnt offer any conversion/option in the Features Window ?
ACrowley is offline   Reply With Quote
Old 12th April 2009, 15:06   #232  |  Link
Greif
Which type of files are you working with? The GUI doesn;t support audio files only video/container files.
HdBrStreamExtractor
Old 12th April 2009, 18:27   #233  |  Link
kikker
Version 0.5 doesn't seem to parse the features of several m2ts files I have with the latest eac3to, but the latest SVN works perfectly.
Old 12th April 2009, 19:03   #234  |  Link
Greif
I've been meaning to promote the svn release to 0.6. I'll do that soon.
HdBrStreamExtractor
Old 12th April 2009, 19:38   #235  |  Link
ACrowley
TS /M2TS
will the Gui support Audio Files ? I mean this is imho a essential basic Feature of eacto to process single Audio Tracks ?
Old 12th April 2009, 20:10   #236  |  Link
Greif
The focus of this GUI is for extracting streams from HD-DVD and Blue-Ray discs. I can look into adding audio file support but I can't promise anything.
HdBrStreamExtractor
Old 14th April 2009, 15:37   #237  |  Link
tedybear
15:32:35] a02 The ArcSoft and Sonic decoders don't seem to work, will use libav instead.
how to use arcsoft decoder?
tedybear is offline   Reply With Quote
Old 14th April 2009, 15:50   #238  |  Link
~bT~
н∂-ƒαиαтι¢
Old 14th April 2009, 16:28   #239  |  Link
tedybear
"making the ArcSoft DTS decoder work in eac3to:
Sometimes the ArcSoft DTS decoder doesn't work even after you've installed the full retail software. This can usually be fixed by manually adding the ArcSoft "Bin" folder (e.g. "C:\Program Files\Common Files\ArcSoft\Bin") to your environment path. If you don't know how to do this, google "environment path"."
can anyone please explain?
Old 14th April 2009, 16:43   #240  |  Link
rack04
Explain what? How to install the full retail software? How to do a Google search?
rack04 is offline   Reply With Quote
eac3to, hdbrstreamextractor
