22nd December 2017, 21:55 | #22 | Link |
Some software, NVEncC is one, doesn't support full depth input from Avisynth and forks (+ included)
In this case Vapoursynth is fully supported, more universal support it appears It seems to be more actively supported Only way to determine if AVS+ will do what you need is to try short clips and see However if you think you will one day support hardware encoding (2x + frame rate encoding for 4k) it might be worth considering |
23rd December 2017, 17:08 | #24 | Link | |
Elit Amans
Merry Christmas and Happy Holidays! //LD |
23rd December 2017, 23:33 | #25 | Link | |
24th December 2017, 09:56 | #26 | Link |
So, it doesn't work for me unfortuanetly. I tried some original streams, made a BD Folder structure with TSMuxer, and then applied TSM2UHD to the Folder. After it finishes I tried Playback with DVD Fab Media Player (which works fine for everything I tried), but Playback gives me heavy stuttering and "jumping". Don't know what I could be making wrong here...
Thanks for your work and merry Christmas! |
24th December 2017, 11:17 | #27 | Link |
Life's clearer in 4K UHD
Does the actual '00000.m2ts' stream play okay?
24th December 2017, 15:08 | #29 | Link |
Sounds more likely to be a TSmuxer GUI muxing issue...
24th December 2017, 17:06 | #30 | Link | ||
I mentioned the bitrate issue twice in the README: Quote:
If it isn't a burned disc... than I'm at a loss. TSM2UHD does nothing, repeat nothing, that could modifies the playback itself. It only sets flags in files so that they are recognizable to a UHD-BD player. As SeeMoreDigital mentioned, it is more likely to be a TSMUXER issue... which would be a lot harder to fix. If you find out more, let me know. Last edited by jdobbs; 24th December 2017 at 18:00. |
24th December 2017, 18:14 | #31 | Link | |
That's why I assumed the bitrate couldn't be the cause of the error. Just for the fun of it I copuld try burning the folder and see what my Sony x800 does with it I'll re-check my settings in TSMuxer as well, perhaps I did something wrong there. And I'll be checking with some own footage I created myself. I'll report if I find out anything new of course! |
26th December 2017, 13:31 | #32 | Link |
So I did some more tests and I simply can't get it working... Even tried some of my own UHD stuff which definitely doesn't exceed bitrate limits and I'm getting the same picture errors. So I guess I'm really doing something wrong with TSMuxer - but I don't know what to change.
Can you recommend any settings which worked for you?? Perhaps I need to adjust VBV buffer size?? |
5th January 2018, 16:03 | #37 | Link | |
pretty sure, it's tsmuxer issue. mpls file has problem. I try with blade runner uhd.After process tsm2uhd, i check it with bdinfo. 1. movie length is changed original : 1:57:31.377 result : 1:51:41.486 2. hdr is romoved original : MPEG-H HEVC Video 0 kbps 2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020 / result : MPEG-H HEVC Video 0 kbps 2160p / 23.976 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / SDR / BT.2020 / 3. i burn into disc and play it on lg up970. It's stuttering, no hdr and video and sound not sync. Last edited by no-one; 5th January 2018 at 16:18. |
6th January 2018, 15:24 | #38 | Link |
Please read the README.TXT file. I've now had to repeat this about four times.
You generally CAN'T KEEP AN ORIGINAL STREAM. The original stream is encoded at a bitrate that is TOO HIGH for a BD-25 or BD-50. For example, if the original came from a BD-100, the bitrate can be almost twice as high as a BD-50 can accomodate. You're going to get stuttering, etc, because the spinning of the disc can't keep up with the encode rate. Everyone -- please don't make me have to explain this again! I have no idea how HDR can be removed. You're telling me the stream is unchanged from the original --- so I don't see how that is possible. It might be that TSMUXER is removing some indicator, I don't know. Nothing TSM2UHD does removes it. Last edited by jdobbs; 6th January 2018 at 15:28. |
6th January 2018, 16:21 | #39 | Link |
TSMuxer does not recreate the "extension data" HDR in the mpls playlist file, after mux, this is the missing part that you find in the original, you can find it at the end of the mpls file:
"ExtensionData": [ { "ID1": 3, "ID2": 5, "data_block": [ 0, 0, 0, 32, 1, 0, 0, 0, 16, 0, 0, 0, 51, 194, 134, 196, 29, 76, 11, 184, 132, 208, 62, 128, 61, 19, 64, 66, 15, 160, 0, 50, 3, 232, 2, 90 I tried the Blu-ray movie worked with TSMuxer and TSM2UHD on Hdisk, read with PowerDVD 17, the movie is recognized regularly and is fluid, without obviously HDR, for audio desync i think it always depends on an incorrect management of the TSMuxer timeline audio/video and the treatment of Gops i-frames. |
6th January 2018, 16:33 | #40 | Link | |
