2nd November 2012, 06:46 | #44 | Link |
If you are talking about tweaking finesharp I found the defaults to be the best for my eyes but I only spent about 30 minutes tweaking.
If you are talking about setting it up to be used during playback: - install ffdshow - configure ffdshow to decode the video (if using a different decoder set ffdshow to decode raw video) - get avisynth 2.6 mt dll and put it in ffdshow directory - in mpc-hc external filters page, add ffdshow, set to prefer, and move it to the top or just below the preferred decoder - go to avisynth page in ffdshow and uncheck 'add ffdshow video source' - set buffer back/ahead to 0 back/4-20 ahead (I buffer 6 ahead) - paste this into the avisynth page of ffdshow setmemorymax(64) SetMTMode(2) ffdshow_source() FineSharp() SetMTMode(1) GetMTMode(false) > 0 ? distributor() : last |
2nd November 2012, 09:00 | #45 | Link | ||||||||
This was exactly what I was looking for. Thanks a lot!
This version? Quote:
2nd November 2012, 16:46 | #47 | Link |
MaskTools2
I found this download link at the top right of this page http://avisynth.org/mediawiki/MaskTools2. There are 4 .dll files in the extracted main folder: 'mt_masktools-25.dll' 'mt_masktools-25-x64.dll' 'mt_masktools-26.dll' 'mt_masktools-26-x64.dll' Which of these do I copy paste in ?? directory? RemoveGrain Do I use this http://avisynth.org/mediawiki/Removegrain site and 'v1.0 pre-release' download? Repair Can t find this one...... avisynth 2.6 mt dll Can t find this one either...... |
6th November 2012, 01:35 | #49 | Link |
How can I get it to process only the right half of the image so I can more easily see what effect it is having? The option in ffdshow is disabled (cannot be checked). Thanks.
Win 7 x64, AMD Phenom II X6 1075T, nvidia 430GT, mpc-be x86 |
6th November 2012, 03:29 | #50 | Link | |
can you explain this equation better for a noob like me, please? specifically: what are b and c (what do they represent)? If the answer above doesn't touch upon this, I also want to know: If I downscale from 1080p to 480p or 540p, is this equation the same as if just scaling down to 720? thanks for all the expert advice |
6th November 2012, 04:23 | #51 | Link | |
6th November 2012, 21:02 | #52 | Link | |
r = (width()/2,0,0,0) stackhorizontal(l,r.finesharp()) Or l.finesharp if that strikes you fancy, I don't know I'm not your mother. Admittedly I haven't tested this yet, so it might break spectacularly, but it seems right. Certainly the right idea. |
7th November 2012, 03:50 | #53 | Link | |
r = crop(width()/2,0,0,0)
15th November 2012, 00:24 | #55 | Link |
dont think this does much if anything at all of worth if your already using madvr and the lav package with ffdshow raw video filter in mpchc, please correct me if im wrong
heres a reply from 6233638< "One of the results posted looked interesting, but generally sharpening is detrimental to image quality in my experience, and I would certainly not want to be sharpening while upsampling the image" whats youre oppinions on this? Last edited by sexus; 15th November 2012 at 00:26. |
15th November 2012, 01:38 | #56 | Link |
Okay. Hereby you are corrected. > whats youre oppinions on this? Frankly? Sounds like self-profiling by coming up with a definitve statement, in a matter that's way too diversified to make such definite statements. Anyway, I've no clue who this 6233638< is.
15th November 2012, 03:42 | #57 | Link |
well hes a member like all of us 6233638 , he is , anyhow so you say theres more to this than meets the eye , please id like to hear everyones oppinions on this , maybe id even go for it if its deffinitely worthwhile , thanks in advance
15th November 2012, 04:24 | #58 | Link |
It is easy to see if it is worthwhile, just try it!
I usually don't like extra sharpening either but some sources do look much better with it. There really is no "for everything anywhere" option. This is another area where it is up to the user to decide what they like. I don't think using MadVR+LAV or not has anything to do with it. Lanczos vs whatever EVR uses isn't that different. |
