29th May 2012, 09:15 | #1281 | Link |
QuickSync Decoder author
New version released 0.33 beta
Version 0.33 beta is out with the following changes:
* Support for H264 frame doubling/tripling flags. * Added forced DI mode - currently disabled. * Added forced filter order - currently disabled. * FFDShow rev4455 I'm working on adding GUI to ffdshow and then all new features will be enabled. Downloads * For the latest cutting edge FFDShow builds download my builds Intel QuickSync Decoder SourceForge home page * FFDShow-tryout site * LAV Splitter builds
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
29th May 2012, 13:13 | #1283 | Link |
Forgot to upload, it's there now
29th May 2012, 15:29 | #1284 | Link |
egur: download and install ffdshow_rev4455_20120529_egur.exe
my mkv video (like the sample i just gave before) still playing fast than audio when using intel quicksync decoder but it works, no delay like previous version when change decoder to libavcodec. maybe intel mediasdk caused that? because last time when i was using sandy bridge hd 3000 with old graphic driver (v2476), i can watch that video flawlessly. with ivy bridge and driver v2696, it happen like that Last edited by cybersans; 29th May 2012 at 15:34. |
29th May 2012, 16:31 | #1285 | Link | |
29th May 2012, 17:23 | #1286 | Link | |
i'll try to downgrade my driver to 2618 or 2598 to see any changes. |
29th May 2012, 18:31 | #1288 | Link |
@cybersans
Can you summarize your system setup including rendere, player, OS, drivers, use of external GPU, Lucid Virtu so I can try to reproduce. Please don't skip any details. Also 2618 is quite old, try 2656.
29th May 2012, 19:28 | #1289 | Link |
2696 seems to cause quite some regressions with timings.
My problem with timestamps that get modified for no reason also only started happening in 2696 (i want them untouched, not modified at all) (only when fps in the bitstream is zero, eric might remember the report that we worked around now)
29th May 2012, 21:10 | #1290 | Link |
New version released 0.33.1 beta
Version 0.33.1 beta is out with the following changes:
* Support for H264 frame doubling/tripling flags. * Added forced DI mode. * Added forced filter order * FFDShow rev4457 with new QuickSync config! This version has the same QS decoder with upgraded ffdshow. Control most QS decoder options, including video post processing via a new ffdshow configuration dialog. Look for a new entry just below "decoder options". Visit the configuration once for your new settings to stick. Downloads * For the latest cutting edge FFDShow builds download my builds Intel QuickSync Decoder SourceForge home page * FFDShow-tryout site * LAV Splitter builds
29th May 2012, 21:22 | #1292 | Link | |
I'm not aware of plans to support 4:2:2 or 4:4:4 - I just don't know. Luckily these are rare.
29th May 2012, 22:31 | #1294 | Link |
I mean luckily.
The human eye is less sensitive to chroma changes than it is to luma changes. Given an arbitrary bitrate, it would be better spent on higher resolution and/or more bits compressing the 4:2:0 frames than compressing 2-4 times more chroma data. 4:2:2 is usually used as an intermediate almost lossless fashion for video editing using ultra high bitrates. Keeping this much video data is problematic and has very little benefits. It might make sense for DVDs as their resolution is small, but for HD it makes little sense. Better quality can be achieved (better) by: * Higher resolution - up to a point * More bits/pixel - look better on high brightness/contrast displays, less banding. * Wide gamut (xvYCC) - more accurate colors, not suitable for Windows based systems as all pixels are converted to RGB and the extra colors are gone. * No interlacing * High frame rate (60p).
29th May 2012, 23:03 | #1295 | Link |
I have to disagree, at least partially.
4:4:4 can have huge image quality advantages over CSS, here I made a comparison: http://forum.doom9.org/showpost.php?...56&postcount=7 The picture with CSS looks partially totally unsharp, many details are killed. Real world films may not be affected that much, especially since it seems to be modern to wash out the colors with stupid filters. Who really likes this? It's not like it was behind the Iron Curtain, where color was too expensive *lol*. But especially red tones seem to be degraded by CSS. Furthermore, with 10bit x264, 1080p60 I444 can be achieved with pretty common bitrates. 35mbit may be enough, I'll try it out. |
30th May 2012, 02:12 | #1296 | Link | |
fyi, 2656 caused "COM Surrogate has stopped working" when you viewing image (jpg/bmp/png etc) with windows image viewer. you can do a search using a keyword "com surrogate intel driver 2656" and many people experienced the same problem too so v2618 is the previous version which i found stable with my system 2. windows media player 12 3. windows server 2008 r2 converted to "workstation look alike" 4. your latest ffdshow build. 5. just IGP as primary GPU, lucid virtu disabled and no pci-e GPU. |
30th May 2012, 13:23 | #1297 | Link |
Nev,
The time stamp problem doesn't appear in driver 2761 anymore. Also found some small issues, so I'll release another version very soon.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. Last edited by egur; 30th May 2012 at 13:26. |
30th May 2012, 13:35 | #1298 | Link |
Great.
You wouldn't happen to know when that one will be available to the public? (or at least to me )
30th May 2012, 14:57 | #1300 | Link |
I don't know driver release dates, I'm not part of the graphics group. Sorry.
I've recently asked internally to share the production drivers that are available to OEMs and several ISVs, I'll update if there's any news in front.
ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player |
