4th February 2009, 18:13 | #761 | Link |
Tested the build 315 on my Sony NTSC BDZ-T90 SAP and got great result, all was as expected!
Thank you deank so much! I'll delete the build 277 soon. My authoring settings are; [x]create top menu [x]static menu(lite) [x]custom menu custom name - [x]show in intro |
4th February 2009, 18:15 | #762 | Link |
Programmer (or just 教务长)
In few minutes I'll put build 316.
It will issue warning if custom background image is too complex. This build allows more complex backgrounds. Sorry, but until I create a real muxer - there will be limitations on the custom background complexity. Dean *** If someone is downloading FULL version, stop and wait. It will be updated in 30 minutes. *** LITE VERSION IS UPDATED Please share your experience. Last edited by deank; 4th February 2009 at 18:41. |
4th February 2009, 18:54 | #763 | Link |
FinalCut´ter
Custom menu now perfect with arrows here on mac via crossover. SAP: PS3 PAL. Background jpeg 1 MB.
tested with 2.1 v314 and 2.1 v316 Great work, very great Last edited by kenguru2005; 4th February 2009 at 19:17. |
4th February 2009, 19:56 | #765 | Link |
*** There are reports on some players which refuse to play optical media with AVCHD structure if BD structure is also present. I'll add an option in multiAVCHD to select if "create multiBD" output should not contain non-AVCHD folders, i.e. CERTIFICATE\* BDMV\AUXDATA BDMV\BDJO BDMV\JAR BDMV\META BDMV\BACKUP\BDJO It seems that some SAP FW programmers decide to rely on their existence and if such folders are found, disc is treated as BD, not AVCHD, so missing files in these folders make some players just stop. I will also try to make multiAVCHD process AVCHD folders with multiple multi-title-playlists correctly and making output compatible with Panasonic TVs with SD cards input, capable of playing AVCHD. Dean Last edited by deank; 4th February 2009 at 20:16. |
4th February 2009, 22:01 | #766 | Link | |
This would be the only thing still to add . Otherwise this prog is PERFECT, no other word for that You`re the best!!!! Last edited by miloka; 4th February 2009 at 23:02. |
4th February 2009, 23:13 | #767 | Link |
Location: The Great North (the better half of North America)
deank, I have a few questions about multiAVCHD. I'm thinking about bakcing up some movie trilogies to a single BD-R, I'd like to keep the HD audio too. I'd also like to mix and match movies too.
1. Can the movies on one disc have different audio codecs, i.e. One with LPCM and two with TrueHD? 2. If all three need subs are they displayed as three individual movies, or is movie #2 a continuation of movie#1 (and same for movie#3) in regards to runtime. Will srt time stamps need to be adjusted for movie#2 and #3, or can the original .sup file be used? The way I hope to do this is have each movie be it's own m2ts with their own codecs, then load individually, will your app keep the three movies separated when final muxing takes place? Thanks, |
5th February 2009, 02:24 | #770 | Link |
I tried the custom menu and while I can select the videos. The background is not what it is supposed to be.
http://www.apah20.dsl.pipex.com/pics/avchd.jpg |
5th February 2009, 06:19 | #772 | Link | |
FinalCut´ter
5th February 2009, 07:55 | #773 | Link | |||||
You should never have seen this background. Check your log for RED lines around the point multiAVCHD creates custom menu. Something may be wrong with your background file. Quote:
Dean |
5th February 2009, 08:03 | #774 | Link |
suffice to say that my CUSTOM menu works!!!
I'm using my own CUSTOM background, and the picture is shown perfectly. I'm using the AVCHD folder on HDD, connected to USB Port of my PS3. Arrow shown, Custom Titles (I tried up to 5) works. Selecting "DOWN" button on PS3 on the Arrow, after title no. 5, it shows arrow going down to no. 6 (no title there) but fine for me. The Arrow keeps going down and down, but again, fine for me. I'm using 312, and haven't update it yet.
HD n00b Last edited by robshot; 5th February 2009 at 08:04. Reason: additional info |
5th February 2009, 08:07 | #775 | Link | |
Also, is movie #1 00000.m2ts, #2 00001.m2ts, and so on? Last edited by odin24; 5th February 2009 at 08:14. |
5th February 2009, 12:37 | #778 | Link |
Build 319:
----------- Navigational arrows will go only where supposed to when RC buttons are used * UP/DOWN move arrows thru title list.. no more strange jumps to unexpected title line * LEFT/RIGHT move arrows to NEXT PAGE nav button in the lower right corner. It will work only if you have more than 14 titles. Also few bugs are fixed (important!) Last edited by deank; 5th February 2009 at 12:41. |
5th February 2009, 12:42 | #779 | Link | |
FinalCut´ter
