17th February 2011, 18:25 | #9141 | Link | |
DVD-Guides.com Author
If you download eac3to plus some GUI you will see what the various options are and what audio it produces. What it does is decoding (not demuxing) the audio to wave format and then uses that to re-encode to AC3. If you ask me, the audio options are not so clear in Ripbot so I just use the Core option and keep the Core track in my mkv files, since I am just passing through via sp/dif to a DTS decoder that doesn't support HD. Staxrip has more complex audio configurations with exact eac3to settings.
DVD-Guides.com - your source for video guides |
17th February 2011, 19:15 | #9142 | Link | |
I dont care so should you
My Installer's || |
17th February 2011, 20:17 | #9143 | Link | |
hi Atak
i just try to decode a ".m2ts" file into "mp4". The program end the decoding without errors, but... in the output directory i have nothing!! here is the info on the ini file: Quote:
i'm confused... |
18th February 2011, 10:45 | #9145 | Link | |
18th February 2011, 11:59 | #9146 | Link |
Hi Atak
I’m getting this very annoying problem (I’m using vista home premium sp2 32-bit). This problem is happening with all of my bought dvds but i’ll use Pink Floyd: Live at Pompeii as my example. Here’s the file I ripped from dvd to mkv using MakeMKV Last edited by smokerdalejash; 18th February 2011 at 12:06. |
18th February 2011, 12:00 | #9147 | Link |
A 4891 kbps source, when I set 2 pass to 3000 kbps it completes fine with no problems at all(takes about 4-5 hours), but when I set it to what the source says it is capable of (4891 kbps) right at the end during the muxing part a “mp4box.exe has stopped working” error comes up
18th February 2011, 13:22 | #9148 | Link | |
In my case I don't really care about the file size so I leave the Core.
18th February 2011, 18:00 | #9150 | Link | |
Has anyone else received the MP4BOX.EXE error? I've been using this software for quite some time now and love it. Thanks again Atak! |
18th February 2011, 18:29 | #9151 | Link | |
18th February 2011, 19:25 | #9152 | Link |
Is the final file bigger than 4GB ?
18th February 2011, 22:48 | #9154 | Link |
nVidia & dgdecnv
Would really appreciate some help ...
Have a new GT460 card and dgdecnv license How do I get Ripbot to use these to speed up the whole process? I promise you I have spent a lot of time trying myself and searching this forum Thx PS: Without dgdecnv, I'm getting around 19 fps whilst encoding (BluRay rips) and the demuxing seems slow and in no way fully utilizes my 6 core CPU |
19th February 2011, 00:08 | #9156 | Link | |
MP4Box had some known bug with files over a size limit. Thought it may have to do with the file size as in your second attemp you use a higher bitrate, hence a bigger file.
19th February 2011, 01:32 | #9157 | Link | |
Great work Atak |
19th February 2011, 04:15 | #9158 | Link | |
You can always use mkv instead.
19th February 2011, 06:16 | #9159 | Link |
use the [code] tags and copy and past your log so we can view it.
My Installer's || |
