5th January 2006, 21:55 | #1041 | Link |
0.2.3.1032 6 Jan 2006
Added a button to the Queue tab on the main form: "Add Shutdown". This adds a shutdown job to the end of the queue. Automatic shutdown can still be set using the checkbox in the Settings form. Fixed tri-state GUI display dependencies in x264ConfigDialog.cs Actually, the tri-state problem was a side-effect of not allowing showCommandLine() to run when the dialog is first being initialised. I just added a separate call at the end of the load process. Last edited by charleski; 5th January 2006 at 21:57. |
5th January 2006, 21:56 | #1042 | Link |
Mr. Sandman
?!? Where was the error ?!?
5th January 2006, 22:01 | #1043 | Link | ||
@jmk: Bug reports should really be posted on the bug report thread. Similarly with feature requests and the feature request thread.
As to the other bugs you mentioned, they don't happen for me, so you should post a more detailed explanation on the MeGUI Bug Report Thread. This thread is for developers. |
5th January 2006, 22:03 | #1044 | Link |
The tri-state stuff is only called by showCommandLine(), and this was disabled when the dialog is being loaded:
private void showCommandLine() { --> if (!loaded) --> return; if (!x264ConfigurationDialog.levelEnforced) EnforceLevel(this.CodecSettings); x264DialogTriStateAdjustment(); |
5th January 2006, 22:05 | #1045 | Link | |
clueless n00b
5th January 2006, 22:08 | #1046 | Link | |
5th January 2006, 22:13 | #1047 | Link | |
5th January 2006, 22:54 | #1048 | Link |
Pain and suffering
Using megui-x264-svn.exe:
- Selecting profiles HQ-Insane and HQ-slowest then hit config (or select these profiles in config) crashes. Code:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: InvalidArgument=Value of '6' is not valid for 'SelectedIndex'. Parameter name: SelectedIndex at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value) at MeGUI.x264ConfigurationDialog.set_CodecSettings(x264Settings value) at MeGUI.x264ConfigurationDialog.videoProfile_SelectedIndexChanged(Object sender, EventArgs e) at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e) at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m) at System.Windows.Forms.ComboBox.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- megui-x264-svn Assembly Version: 0.2.3.1032 Win32 Version: 0.2.3.1032 CodeBase: file:///G:/msys/1.0/home/user/pack/megui-x264-svn.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- _7rwuzjn Assembly Version: 0.2.3.1032 Win32 Version: 2.0.50727.42 (RTM.050727-4200) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. http://forum.doom9.org/showthread.php?t=101813 MeGUI-x264_generic_profiles_v20.7z Last edited by bob0r; 5th January 2006 at 23:30. |
5th January 2006, 22:59 | #1049 | Link | |
clueless n00b
5th January 2006, 23:27 | #1050 | Link |
Pain and suffering
Ah ok, i understand.
Coding an option to detect valid profiles can be touch i guess. Thanks (And yes svn only still is perfect, profiles do not come with the package, i only report what i see ) Edit: Moved the other report to the bug report thread, i just noticed it Last edited by bob0r; 5th January 2006 at 23:31. |
6th January 2006, 01:51 | #1051 | Link |
Ok, doom9 pointed out that the Oneclick code actively modifies the queue during processing, which makes it hard to insert jobs that require absolute placement without a lot of special handling. So I revised things back to using the settings shutdown code, but modified the window title so that the application's behaviour won't cause any nasty surprises. I also added in something to deal with the progress percentage appearing to hang at the end (really just a display issue).
0.2.3.1032 6 Jan 2006 Added a button to the Queue tab on the main form: "Add Shutdown". This adds a shutdown job to the end of the queue. Automatic shutdown can still be set using the checkbox in the Settings form. Revised: Removed the use of system jobs and added shutdown checkboxes to the Oneclick window and queue tab. Shutdown status is now displayed in the window title if it's enabled. Modified main window title to revert to name+version after the job queue has finished. Fixed tri-state GUI display dependencies in x264ConfigDialog.cs |
6th January 2006, 05:10 | #1052 | Link |
Mr. Sandman
x264 conditional compiling is broken again.
EDIT: Fixed and CVS updated. 0.2.3.1032a is "released". So please add any updates to the next version and make it 0.2.3.2
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th January 2006 at 05:28. |
6th January 2006, 09:11 | #1053 | Link |
clueless n00b
I have something for discussion: with the addition of XviD AVC, we'll have two AVC and two ASP encoders.. and we already have two AAC encoder (perhaps three once dimzon integrated behappy?). There are two approaches to handle the two codec/one format approach. One is to have everything available in the appropriate dropdowns. That makes it very easy to see what you get, on the other hand it's more cumbersome internally because you have an xyzSetting object with the settings for each type of codec.. The other alternative is to offer just the codec type (like ASP, AVC, AAC) and have the encoder selection done in the settings. This makes it easier to integrate additional encoders, on the other hand, it's no longer apparent at first glance what is being used. And I'm sure you can come up with more pros and cons for each approach. Which one do you prefer?
6th January 2006, 09:21 | #1054 | Link |
clueless n00b
and about the shutdown: I think it wouldn't be such a bad idea to remove that from the settings, and have it in the queue, in addition to allowing to set it in the automated encoding setup windows.. and that checkbox should be non persistent.. so that in case you do want to shut down after processing, you actively requested it each time. That most certainly would get rid of the accidental shutdown problem, and at the same time I don't think it's so much a hassle to actively set this flag if you really want the PC to shut down.. it's a rather big step after all.
6th January 2006, 10:19 | #1056 | Link |
0.2.3.1034 7 Jan 2006
Added a few fixes for conditional compilation 0.2.3.1033 7 Jan 2006 Small fix to ensure all the shutdown checkboxes reflect the current state correctly [Since this is a bug fix I kept it as 0.2.3.1xxx and added it as a release] Last edited by charleski; 6th January 2006 at 10:53. |
6th January 2006, 13:57 | #1058 | Link |
clueless n00b
btw, depending on how encraw comes along, we might also get tri-state in the xvid config dialog and certainly in the xvid avc dialog as well More fun for me and more opportunities to introduce new bugs...
6th January 2006, 15:42 | #1059 | Link | |
Mr. Sandman
@devs: when you're releasing a new build on SF ensure you check the "Preserve my pre-formatted text" just below the changelog...
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th January 2006 at 16:22. |
6th January 2006, 16:22 | #1060 | Link |
Mr. Sandman
CVS Update:
0.2.3.1036 (work in progress) Changed "Codec" in "Encoder" in x264, snow, xvid and lavc dialogs titles Fixed some conditional compilation warnings
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th January 2006 at 16:38. |
development, megui, not a help thread |
