3rd October 2007, 16:14 | #3081 | Link |
Ludo Kopele
Somebody totally messed up the last update 2.6.1018. The MKV muxer where it says output there's an open button instead of save. When you leave the auto made name in the field it gives and error and closes. Peace
3rd October 2007, 16:40 | #3082 | Link |
Mr. Sandman
eh... im not at home though... so hope some dev is around to fix it...
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 3rd October 2007 at 17:13. |
3rd October 2007, 19:39 | #3083 | Link |
I can't do anything useful with 2.6.1018 - autoencode doesn't queue anything up & I can't use the bitrate calculator & manual enqueue as the bitrate calculator always throws an exception. Ouch.
Is there a way to rollback to an earlier version? If I manually edit autoupdate.xml I can get the updater to reoffer the current latest on the stable or dev servers, but I can't see a way to select a specific earlier build. Are they actually on the servers? Ah yes, a few are & in anycase I have a couple cached. I guess I'm reverting to 1017 for now. Today's the first time I've used Megui for xvid encodes & I was getting worried it wasn't usable - it's a relief to discover it's all broken instead |
4th October 2007, 03:08 | #3084 | Link |
Mr. Sandman
well, it's a dev build... however there's an update_cache where you can get the .1017 binaries...
i think i will remove .1018 from the autoupdate as soon as im back home...
4th October 2007, 06:32 | #3086 | Link |
Learning
you can also manually download core_0_2_6_1017.zip from http://megui.org/auto/ and put the contents in megui directory.
4th October 2007, 13:16 | #3088 | Link |
Mr. Sandman
done.
4th October 2007, 17:31 | #3089 | Link |
Ludo Kopele
Oh yeah and more (actually two) things. As of update .1017 the update window doesn't show the latest version of the updates, only the existing one. It's not that big of a deal but it's a good thing to know what you are downloading. And why don't you include the nero aac audio encoder in the update window. We have to download it manually form the nero site to use it. Same thing with the avi-mux and another program called besplit(i don't know what's that used for). Peace
4th October 2007, 18:26 | #3090 | Link |
Mr. Sandman
i already said that "version not shown" bug was posted in the bug tracker AND we can't redisrtribute the nero AAC encoder coz the encoder license.
5th October 2007, 06:40 | #3091 | Link |
0.2.6.1019 - (Kurtnoise) [One Click Encoder] : fix output filename according to the container selected in the Advanced Settings. - (Kurtnoise) cosmetic - Move "cleanup" to EncodingMode instead of CodecString. - (Kurtnoise) [Bitrate Calculator] : fix a runtime error. - (berrinam) Fixed AutoEncode to queue jobs again - (berrinam) Fixed #1805580 (Automatic output filename assumes .mp4 output in muxer) - (berrinam) Fixed Bitrate Calculator to support multiple audio tracks; this fixes crash when opening it without input - (berrinam) Fixed #1805603 (Automatic update not showing the Latest version number) |
5th October 2007, 10:29 | #3097 | Link |
Oh, I don't know if I mentioned this before, but the update_cache folder now makes it possible to distribute networked installs. It's not ideal, because megui will still access the web for the update.xml file, but it will get all the data files from the local cache.
To make such an installer, you simply need to package all of the zip files on a relevant update server (dev server if you're making dev releases; stable server if you're making stable releases) in the installer, and put them somewhere sensible during the install process. MeGUI checks the registry key, HKEY_LOCAL_MACHINE\SOFTWARE\MeGUI\update_cache, for the update cache's folder, so the installer should set that key in the registry to point to the folder the installer put the files. |
5th October 2007, 11:17 | #3098 | Link |
phjbdpcrjlj2sb3h
Just thought everyone in here would like an update on how popular MeGUI is becoming.
Usage for July, Aug, Sept: 95gb, 110gb, 135gb In particular, for september:
5th October 2007, 12:57 | #3099 | Link |
Mr. Sandman
wow! i didnt expect that popularity...
more stats are available at the megui project tracker on SF: http://sourceforge.net/project/stats...i&type=tracker 400-500 downloads/day...
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 5th October 2007 at 13:05. |
5th October 2007, 15:59 | #3100 | Link |
Ludo Kopele
Why did you guys made the same mistake with .1020 . Again all the muxing windows has the open button instead of the save button
development, megui, not a help thread |
