28th May 2017, 11:41 | #41 | Link | |
But of course solutions like SolveigMM Video Splitter should handle such cases without re-encoding as well. |
30th May 2017, 22:38 | #42 | Link |
Yes, I tried it without B-Frames and VirtualDub will cut an AVI on a non keyframe, as long as everything from the cut point to a later keyframe is removed (or from the cut point to the end).
A quick test with MKVToolNix indicates it sticks to splitting on keyframes but it's not really an editor and I guess the assumption is all the segments should be playable. Still, cutting on any frame that way would require disabling B-frames or using the zero latency option, and the OP didn't indicate he was doing either. |
11th April 2018, 23:30 | #43 | Link | |
Usually I use MKVcleaver v0.7.0.2 (needs MKVtoolnix) to extract all streams from all MKVs (will make AVIs from h264 streams), and I use a batch for directStream muxing all videos and audios. Batch: https://sourceforge.net/projects/vir...urce=directory MKVcleaver: https://blogs.sapib.ca/apps/mkvcleaver/ |
12th April 2018, 01:28 | #44 | Link | |
the Interrogator
