30th April 2010, 11:02 | #8022 | Link | |
My Samsung 1600 is one of those players that does NOT accept -ROM. |
30th April 2010, 20:56 | #8024 | Link | |
Samsung BD-P1600 and BD-9
I too have a sammy bd-p1600, and have created many coasters, attempting bd-9's. unless you tick "strick acvhd" in the setup, you are going to get a set of files that when burned won't play. There is a certain set of files that comprise a avchd bd-9. any more or less files and they won't play. I am not at home, so I can't give you the exact file names and order. ALSO: you are correct. A sammy BD-P1600 will not play A DVD +R DL as a -rom file. You must be able to change the book type on your drive. Go into IMG burn and change the setting for "AUTO book type change" as this will change it automatically to ROM, and that's bad for you. As far as disks go, I have had no better luck with one type over the other. I use them all, TDK'S, Memorix, Vertbatium, Sony, Ridata, Quantum. When the programs are working and giving me proper output, I can burn w/ around 95% working disks. In my 10 plus years of burning CD, DVD, BD disks I have found and follow these two things: 1. Only use LG burners. PERIOD. 2. Burn SLOW. Repeat: SssLllOooWww. Music and data cd's 4x max. DVD and Br's 2X max. my 2 cents. YMMV. stu |
30th April 2010, 21:10 | #8025 | Link | ||
BUT the results were STUNNING. Acutally I have come to expect that from BD-RE. The quality of the output of JDobbs' program is AWESOME. My 2 cents. Stu |
1st May 2010, 03:49 | #8028 | Link | |
It would help, though, if I knew what settings you were using (languages, setup options, etc) so I can run it the same way. Last edited by jdobbs; 1st May 2010 at 03:52. |
1st May 2010, 10:23 | #8029 | Link | |
jdobbs i have also many problems with this season.Bd RB works perfectly until end of conversion but the BD25 don't play the episdode, because of the angle i think. Forgive my english. |
1st May 2010, 10:27 | #8030 | Link |
Hi jdobbs, I know you like to forget me sometimes however I would like to know what you think about the Batman Returns BD sample I sent you last week. Just to know if I will have to do it manually and especially as I think if you find the issue on this sample, you should remove any field order issue remaining. Thanks for your answer, and I promise to not beg you too much!
1st May 2010, 14:59 | #8032 | Link | |
TR TR TT RT TR TT RT TR TT RT TR TT RT TR TT TR TT RT TR TT RT TR TT RT TR TT RT TT RT TR TT RT TR TT RT TR TT RT TR TT TR TT RT TR TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT RT TB TB TB TB TB TB TB TT Last edited by jdobbs; 1st May 2010 at 16:17. |
1st May 2010, 22:02 | #8033 | Link |
Former Kanenite
Well what the deuce. My settings should be the same as they've always been, except quality. I always had BD-25 set but after updating for the first time in months I see you added a new default setting (auto) so I just left it.
[Options] RESIZE=0 MODE=0 PRIORITY_CLASS=0 TARGET_SIZE=23000 ENCODE_QUALITY=0 VERBOSE_STATUS=1 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=1 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 ONEPASS_ENCODING=2 AUTO_QUALITY=1 [Paths] SOURCE_PATH=E:\BLU-RAY RIPS\STAR_TREK_S1D7\ WORKING_PATH=F:\FULL DISC\ |
1st May 2010, 22:20 | #8034 | Link | |
2nd May 2010, 03:37 | #8035 | Link | |
And finally, If you don't see BFF, maybe as you say a possible bug somewhere could false your analyse on these kind of footage. It's a very high probability as other interlaced footages from AVC and MPEG2 (that I think is good too) contained on a M2TS files seems to be well interpreted all the time. I can't really say much about how to better analyse it by code, I even don't understand how you grab these TBR letters, but I just can tell you that with my eyes, it's well BFF (at least Stargate) or RFF with much more BFF. More enough to remove any jerky playback effects, and I don't know how mediainfo is relevant, but he is always agree with what I see. If it could help you, know that mediainfo have a dll, maybe you could try to understand how this tool arrive to well analyse these files. To finish, Mediainfo tells me Interlaced/BFF on the source, Interlaced/BFF on the MKV you generate, Interlaced/TFF on the encoded m2ts. I understand hardly all of this and I would like to help you more. Last edited by SoniG; 2nd May 2010 at 03:44. |
2nd May 2010, 03:49 | #8036 | Link |
@SoniG
The flags I'm showing you come straight from the original M2TS VC-1 stream's flags in the picture headers -- and I verified them by hand. So there isn't room for argument as to what the stream says (at least in the first 500 pictures). How someone might interpret them I guess is debatable... but I don't see how it could in any way be interpreted as BFF since there isn't a single BFF in the lot. If it is a 29.97fps progressive sequence that is flagged as interlaced, it really wouldn't matter if it was BFF or TFF -- as there would be no chronological difference between the two. But that would be really odd for an originally progressive picture to be split out into a field-picture stream. Last edited by jdobbs; 2nd May 2010 at 03:59. |
2nd May 2010, 04:20 | #8037 | Link | |
2nd May 2010, 10:07 | #8038 | Link |
Season 1 or 2 ? Season 2 contains multi-angle and all the disks don't works in BD25 full backup with all languages et subtitles. My BD85 stop playing when episode start. I compare the structure with bdedit and there is some differences in clip and playlist. multi-angle make problem ?
2nd May 2010, 14:04 | #8039 | Link | |
