31st January 2008, 21:00 | #621 | Link |
I dont care so should you
Is there a way to choose output path???
My Installer's || |
31st January 2008, 21:26 | #622 | Link | |
31st January 2008, 21:28 | #623 | Link |
Oh my God LOL I am Blind
LOL Sorry
My Installer's || |
31st January 2008, 21:37 | #624 | Link |
You almost killed me with this question.
Regarding installers I suggest to rename RipBot264 v.1.8.7.exe to RipBot264v1.8.7-setup.exe
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 31st January 2008 at 21:47. |
31st January 2008, 22:07 | #625 | Link |
No Prob I just finished making the installer script that has the Avisynth, ffdshow, and Haali, options in it... So now there is a heavy and a lite
The lite one will be Called as you said "RipBot264v1.8.7-setup.exe" The Heavy one will be called "RipBot264v1.8.7-Full-setup.exe" unless otherwise desired Ok I made that small correction and they are being uploaded it will be about 15 min to 30 Min...
My Installer's || Last edited by Ajax_Undone; 31st January 2008 at 22:11. |
31st January 2008, 22:52 | #626 | Link |
http://www.megaupload.com/?d=H2J6UXZ0
http://www.megaupload.com/?d=JAYZYY68 The top is the Full and the bottom is the Regular Because I think these type of updates get annoying I will be posting them in my Signature from now on...
My Installer's || Last edited by Ajax_Undone; 1st February 2008 at 19:22. Reason: Updating links |
1st February 2008, 00:06 | #627 | Link | |
1st February 2008, 01:08 | #629 | Link |
I had to fix it! Try now it should work...
My Installer's || |
1st February 2008, 01:12 | #630 | Link |
Atak_Snajpera yes i know i need to reencode, in xvid4psp you open your MP4 for example, than u can select COPY both video and audio and then i choose .srt file and select convert. He makes the job really fast! like 300FPS. the result it's exactaly the same but with .srt hardsubbed. (don't get me wrong, about talking about other software here) just saying because i really like yours its more user friendly, and just saying it would be interesting to see the feature.
1st February 2008, 01:28 | #631 | Link | |
1st February 2008, 17:50 | #633 | Link |
with 1.8.7 I have problem to import audio(AC3). the getInfo.avs is always looping. Invalid ac3.1 file.. (ac3 2 channels)
here a sample (10megs) http://www.mediafire.com/?cqtdgbx5jhf |
1st February 2008, 19:33 | #634 | Link | |
problem with sound
I am basically using this program to take some 1080P m2ts file and make it 720P, choosing and leaving the AC3 stream alone.
Because Ripbot demuxes itself to C i cannot let it demux my whole file so I use tsremux to make a ts file for the picture and a ac3 file for the sound. Then I use ripbot to do the work with these two files. For the audio the only thing I choose is the AFTEN 5.1. On a smaller test file with AVC/AC3 this produces a file which when I play ffdshow audio shows that it has an audio stream but I cannot hear it. If I choose to let let ripbot do the whole job including the demuxing then it plays perfectly. But ffdshow shows exactly the same information. Here is the job information of the job that does not work. Can you please help. Quote:
1st February 2008, 20:35 | #635 | Link |
hi, can someone help me out please, in this .bat file how can i add the option to use avisynth (or other method) to hardsub using a .srt?
@echo off set progdir=C:\GotSent set basename=%~n1 set fullpath=%~dp1 @REM Run mkvextract "%progdir%\MKVToolnix\mkvextract.exe" tracks %basename%.mkv 1:video.h264 2:audio.ac3 @REM Convert AC3 audio to 2 channel wav "%progdir%\ffmpeg\ffmpeg.exe" -i audio.ac3 -ac 2 audio.wav del audio.ac3 @REM Convert wav to AAC LC "%progdir%\neroaacenc.exe" -lc -q .9 -if audio.wav -of audio.aac del audio.wav @REM Create the ini file for h264info del "%progdir%\h264info\h264info.ini" echo [Paths] > "%progdir%\h264info\h264info.ini" echo InputPath=%fullpath%video.h264 >> "%progdir%\h264info\h264info.ini" echo OutputPath=%fullpath%video-4.1.h264 >> "%progdir%\h264info\h264info.ini" @REM Run h264info "%progdir%\h264info\h264info.exe" del video.h264 @REM Add the converted audio/video into the final mp4 "%progdir%\MP4Box\MP4Box.exe" -add video-4.1.h264 -add audio.aac -fps 23.976 temp.video @REM Added a temp.mp4 and then moved to the real mp4, otherwise WMP11 doesn't see the new file move temp.video %basename%.mp4 @REM Final cleanup del video-4.1.h264 del audio.aac |
1st February 2008, 23:30 | #637 | Link |
All new installers do not have to be uninstalled before the next update... Just install them over the old!
My Installer's || |
3rd February 2008, 07:19 | #638 | Link | |
EDIT: Atak_Snajpera I worked out the problem that I was having with avisynth after, it was to do with k-lite mega codec pack not installing a few extra codecs needed. Last edited by DJ_Price; 3rd February 2008 at 07:23. |
3rd February 2008, 07:48 | #639 | Link |
Installer="Regular"= All of what is contained in the Zips that are ready to extract on the first post + An uninstaller, build, and Licence Info...
Installer="Regular+DDl"= All of what the above listed has with option to download and install AviSynth, Haali Media Splitter, and FFDshow... Installer="Full"= all of the "Regular" + Pre Downloaded installers of AviSynth, Haali, and FFDshow ready to install... By the way in interest of keeping it simple and saving space I might be killing off "Full" and its permanent replacement will be "Regular+DDl"...
My Installer's || Last edited by Ajax_Undone; 3rd February 2008 at 09:21. Reason: Add Links |
3rd February 2008, 09:40 | #640 | Link |
I noticed that I cannot open *.mov files. Is this on the roadmap for this program... Because I have about 12 videos that are *.mov type videos and wanted to make them x.264 *.mkv...
My Installer's || Last edited by Ajax_Undone; 4th February 2008 at 03:24. |
