Old 9th December 2007, 17:43   #81  |  Link
Zaim7890
DTS Master Audio
elektra it used to work b4, i uninstalled it cuz the app stopped workin, now reinstalled it now pro encoder wont show?
Zaim7890 is offline   Reply With Quote
Old 12th December 2007, 17:27   #82  |  Link
Zaim7890
DTS Master Audio
anyone used (VST-SRS Circle) with Sony Acid pro 6?
Old 13th December 2007, 12:50   #83  |  Link
Elektra999
DTS Pro Series
Elektra999's Avatar
I donīt know...
I do not use ACID Pro v6
Addict to the audio multichannel
Elektra999 is offline   Reply With Quote
Old 13th December 2007, 16:35   #84  |  Link
Zaim7890
DTS Master Audio
Originally Posted by Elektra999 View Post
I donīt know...
hmm, ok thanks
Old 13th December 2007, 21:20   #85  |  Link
Zaim7890
DTS Master Audio
what abt Sony Vegas pro 8. how can u use the VST SRS Circle pro Decoder. could u make a guide oh how to use ^^ ^^ ^^
thanks
Old 14th December 2007, 07:37   #86  |  Link
faiqj
Can anybody guide how to further enhance the 5.1 channel files made with sound forge by adding some additional effects on the different speakers may be at rear channels or front.
faiqj is offline   Reply With Quote
Old 14th December 2007, 21:16   #87  |  Link
Elektra999
DTS Pro Series
Elektra999's Avatar
thanks
Yea
I believe that yes
- Chosse File / Proyect 5.1 Surround, Best, 16bits, 48.000
- Import track audio stereo
- Click Green icon, Remove 3 the plug-ins; Track Noise Gate, Track EQ and Track Compressor.
Note; Not to touch the Surround Panner, for default it is to 0dB.
- To Add, SRS Circle Surround, and in the button Center BacK, presss in Off.
- Chosse File / Render As... export audio...AC3 Pro, WAV's, etc...
Old 17th December 2007, 01:30   #88  |  Link
Zaim7890
DTS Master Audio
Yea
I believe that yes
ah, kwl, thanks, i tryed the above but when i play back i can here the voice in all 5 spkrs?
but then i left the 3 plugins that were already there, could they be causing that ^^. (Track Noise Gate, Track EQ and Track Compressor.)
- To Add, SRS Circle Surround, and in the button Center BacK, presss in Off. u mean turn rear centre off right?
thanks alot for ur help
Old 8th January 2008, 21:01   #89  |  Link
faiqj
Lot of people discussed and shared for making stereo to dolby digital surround but I am unable to find any topic that how to burn ac3 dolby digital pro files to cd or dvd audio which software to use which can burn the original files without converting them to any other format. Pls help
Old 15th January 2008, 03:28   #90  |  Link
Zaim7890
DTS Master Audio
Originally Posted by faiqj View Post
use DVDAudioCreator. for AC3 files
Old 16th January 2008, 18:46   #91  |  Link
faiqj
Thanks Zaim. One more thing I observed that surround files made with sound forge, that the most of the sound coming from center channel with the medium level in the front channels but you hardly notice if rear channels have some sound. Did anybody notice that or if there is any solution that you could raise the volume at rears to listen some sound from the rear channels.
Old 19th January 2008, 01:10   #92  |  Link
Zaim7890
DTS Master Audio
hi Elektra999, in soundforge using SRS Circle sur VST, can you do just 5.1 insead of 6.1?
i tryed Vii but the seperation of the sound isnt as good as the SRS is.
Old 23rd November 2008, 17:37   #93  |  Link
7saigon5
Sound Forge with SRS circle surround 6.1 project
Hello
Sony Sound Forge 9a, with AC3 Encoder Dolby Surround EX 6.1
00. Menu / Options / Preferences / Audio, Select ASIO4ALL / Apply / OK.
01. Menu / File / Open track stereo.
02. Menu / Process / 32bits float / OK.
03. Menu / Process / DC Offset / Preset (Remove DC offset scan entire sound file) / OK.
04. Menu / File / Properties.
Apply / OK.
05. Click (green - arrow)
to look for plug-in appropriate: Circle Surround / VI.I,… Add / OK.
06. ClicK (arrow - Image) Processing selecction.
It will begin to process, in minutes, we will have 6 wav mono.
Track 1 = FL
Track 2 = FR
Track 3 = Center
Track 4 = Surround Center
Track 5 = SL
Track 6 = SR
Track 7 = LFE, but we did not create it, since, in Audio Service we will mark Enable LFE
07. Menu / File / Save Ass...
- Dolby Digital AC3 Pro
- Click Custom
OK and Save
DOLBY SURROUND EX 6.1
I have tried SF 9 with SRS CS pro VST to create 6 mono Wav to encode in LtRt in stereo and I wanna know how can I save the discreate mone multiple of there 6 channels in SF 9?
Regards,
7saigon5 is offline   Reply With Quote
Old 24th November 2008, 22:47   #94  |  Link
7saigon5
This is cool!But how did u separate the SC(surround center) to be encoded in the DTS Pro series for 6.1 channels?Please give instruction how to.Thanx!
Old 25th November 2008, 01:33   #95  |  Link
tebasuna51
tebasuna51's Avatar
Save as multichannel wav file, instead ac3, and use WaveWizard to split in monowavs.
Old 25th November 2008, 16:39   #96  |  Link
7saigon5
Thanks brother!
Old 27th November 2008, 16:05   #97  |  Link
Elektra999
DTS Pro Series
Elektra999's Avatar
- Chosse File / Properties / Proyect in mono,...
- Select channel (SC) number 4 (SRS Circle Surround, proyect) / Edit and press Copy.
- Paste in proyect mono.
- Chosse File / Save Ass... mono / 16 bit,....
Old 3rd December 2008, 16:40   #98  |  Link
7saigon5
Thanx!But when u wanna encode these monos channels in Lt Rt then you just bring the SRS encoder up and press the process button right?
Old 7th December 2008, 14:47   #99  |  Link
raquete
i have seen people posting against the rules calling for cracks.
advice: read the rules.
@ moderators:
edit, delete posts(include this here) but please, don't close this important guide.
raquete is offline   Reply With Quote
