17th March 2007, 06:34 | #1361 | Link | ||
i think i've figured out the problem or part of it. didnt really read this the first few times but when i open up automkv, Vista gives the error "COM surrogate has stopped working." Heres the details of the error. Problem signature: Problem Event Name: APPCRASH Application Name: DllHost.exe Application Version: 6.0.6000.16386 Application Timestamp: 4549b14e Fault Module Name: ffvfw.dll Fault Module Version: 0.0.0.0 Fault Module Timestamp: 3eafd738 Exception Code: c0000005 Exception Offset: 00027742 OS Version: 6.0.6000.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 8d13 Additional Information 2: cdca9b1d21d12b77d84f02df48e34311 Additional Information 3: 8d13 Additional Information 4: cdca9b1d21d12b77d84f02df48e34311 so i would be led to believe that there is some incompatibility between ffvfw.dll and Vista, right? any ideas/thoughts? EDIT: uninstalled ffdshow, and the windows error stopped occuring upon opening automkv, but still getting the exact same behavior when i try to encode. so i guess that had nothing to do with it Last edited by schizosmurf; 17th March 2007 at 10:32. Reason: did further testing |
17th March 2007, 10:19 | #1363 | Link |
HDConvertToX author
@nx6
ADDED: In nex update if a file named "noneroAacEnc.here" is present in \exe\besweet folder , AutoMKV will not ask to download @weaver4 this audio have some problem, on next update will be no more loop and "should be encoded ok" @dlflannery no, sorry, i have mispelled something i wnat to invoke the mkvmaudio.avs (with soundout plugin) with ffmpeg.exe like "ffmpeg.exe mkvmaudio.avs". I don't want to use ffmpeg for audio but soundout a big thanks anyway for your support !!!! @nx6 as i wrote "usually" isn't needed. a crf encoding is aimed , again usually, to a unknow file size, so the autoresize is a little non-sense. Autoresize has a reason to be used in conjuction with CRF AND Hit media Size @schizosmurf automkv on start don't load any dll... (and i haven't installed vista)... trying to upgrade ffdshow ?? or running automkv in winxp compatibility mode ? BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
17th March 2007, 10:22 | #1364 | Link | |
HDConvertToX author
isn't as megui that use the delay function of mkvmerge when muxing BHH
17th March 2007, 10:57 | #1365 | Link | |
Emperor building empire
@buzzqw
I've been encoding 'Band of Brothers' with video-only... hoping to generate the soundtrack with BeSweet in VBR (Streaming quality) and then mux them together... Encoding with video-only (using ConstantQuality-CRF) has allowed me to better guage filesize and the Quantizer required to fit everything (including extras) onto 1 4.5 GB DVD. I've downsized the resolution by 50% and I'm still hoping to downmix some of the extras into MONO... it's getting a bit tight... With a quantizer of 24 and comparable VBR-audio... the quality is far from perfect but still pretty incredible... Perhaps the right way may well be to drop the resolution to 640x368 (instead of 720x400) and use a 20 quantizer... I like the idea of 1 Disc fits all... though I'm also working on a 2 disc, full resolution (1024x576) version. The complete series is over 10 hours and 34GB... so I guess "H264 is a serious over-achiever". I've got a few hrs of encoding on the run... so I'll have to check later... OK... so what you're saying is "BeSweet audio boost, etc is all good... but you can't automate the process into a single job". Pascal Last edited by delacroixp; 17th March 2007 at 13:06. Reason: Factual errors |
17th March 2007, 11:51 | #1366 | Link |
I encoded a movie with the new build 0.78c and the audio volume is quite low...how come? Is there sth I can do to fix it?
I encoded audio with Nero AAC at a constant bitrate of 160kbps stero... EDIT: I played the .ac3 file in the temp folder and the volume is normal...probably sth wrong with the downmixing? dont' know... Last edited by vgiozo; 17th March 2007 at 11:59. |
17th March 2007, 14:38 | #1367 | Link |
HDConvertToX author
@vgiozo
have you update first to 0.78a and then to 0.78c? the 0.78a fixes problem with "normalize" fuction (volume boost) @delacroixp maybe my english isn't enough, with besweet is impossible to catch audio from files avi/ogm/mkv/mp4 the two only way to grab audio from those file are 1) demux audio: to worry and dangerous, even more tools will be needed 2) processing with directshowsource and feed varius encoder with this audio if you are able to use besweet with avs (without using fake avi), tell me BHH
17th March 2007, 15:01 | #1368 | Link | |
@buzznq
Dr DivX 2 OSS uses a system of sampling to gauge the necessary audio boost and then implement the change... also good but not quite perfect. Pascal |
17th March 2007, 15:10 | #1369 | Link |
HDConvertToX author
@delacroixp
feel free to use whatever program you want @vgiozo got the strange case... aacgain.exe is fuctional with quality encoding (-q ) but isn't fuctional with -CBR... strange... i will search for a solution! EDIT better answer: is unable to normalize HE_AAC/SBR files BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 17th March 2007 at 15:25. |
17th March 2007, 15:45 | #1370 | Link |
Ok, Thanks for the info...
So if I encode the movie and use quality mode in audio processing, the volume will be normal? I'll try and report back... I had encoded another movie which had ac3 6ch audio with 0.78a and the same thing had happened, but did not notice low volume with movies that had ac3 2ch...that's why I thought of sth going "wrong" with the downmixing procedure, but I cannot support this guess... I 'll reencode and report back...thanks for the great support... |
17th March 2007, 18:01 | #1371 | Link |
The problems that I was having with being unable to encode audio and the looping problem seem to be related to an old version of avisynth on my computer. I updated it and it started working. Apperantly 0.76 would work with the version avisynth I had and 0.78 wouldn't.
Sorry....my bad. |
17th March 2007, 18:06 | #1372 | Link |
Hello
I tryed to encode with Automkv 0.78c: profile x264 HQ-slowest, mp4, couding tech acc 64 kbits, 704 width resolution. ON version 0.72 all works great. But on 0.78c video doesn't want to encode. Maybe all that happen becouse use of AviSynth 2.5? Sorry for my English. |
17th March 2007, 18:22 | #1373 | Link |
Hey the program has been runnning fantastic and I loved it under XP but now I am running vista and I have problems. It does the Indexing fine I think, but any step where it opens the cmd window (testing interlace pattern, lets encode etc) It just flashes the cmd, closes it immediatly and moves to the next step. So it never does any actual encoding... any ideas? Thanks!
BTW Ive also tried running it under compatibility mode, still does same thing Last edited by RipcordAFF; 17th March 2007 at 18:24. |
17th March 2007, 18:40 | #1374 | Link |
@buzzqw
Ta and for all the fish.
What kind of audio boost does AutoMKV use ? I'm not averse to a little hands-on and H264 is the forefront of modern movie encoding... so I'm sure you know what's best for the community at large, given the limitations of software. Pascal |
17th March 2007, 19:03 | #1375 | Link |
HDConvertToX author
@weaver4
i no more use bepipe but soundout (link in AutoMKV changelog!) i will update the dependices to AviSynth 2.57! Thanks! @Konstantin_by maybe... try upgrading avisynth build (link on first post) @RipcordAFF Bautodeint.exe NEED a yv12 decoder installed Install the Koepi XviD Build (link on first post) @delacroixp http://en.wikipedia.org/wiki/Replay_Gain is a very good Normalizer @ALL In next update (full package) i will include ffmpeg.exe for invoking SoundOut fuction. From my test seems more stable and faster then xvid/x264 when calling SoundOut. I tested even VirtualDub , that's proven even more stable, but is a little slower. Also using ffmpeg i can force the encoding directly with ffmpeg (in mp3) when both nicaudio / directshowsource / SoundOut fail BHH
17th March 2007, 19:35 | #1376 | Link |
[QUOTE=buzzqw;971677
automkv on start don't load any dll... (and i haven't installed vista)... trying to upgrade ffdshow ?? or running automkv in winxp compatibility mode ? BHH[/QUOTE] yea, that dll was bein loaded when vista tries to render the video for creating thumbnails in explorer. had nothing to do with the workings of AMKV. i tried reencoding the file with vitrual dub to a smaller size xvid .avi and there was a warnign when i loaded the source file [*] AVI: Opening file "C:\Users\schizosmurf\Videos\Bleach\Bleach19.avi" [!] AVI: Stream 0 (video) has a non-zero start position of 3 samples (+125 ms). VirtualDub does not currently support a non-zero start time and the stream will be interpreted as starting from zero. so maybe the non-zero starting point is the problem and explains why the AMKV error log showed 10:19:20 Number of Frames: 10:19:20 Framerate: 10:19:20 Movie lenght in Seconds: 0 10:19:20 Movie Width: 10:19:20 Movie Height: 10:19:20 !!! BREAK - FILE NOT SUPPORTED !!! 0 frames 0 framerate movie length of 0 width/height of zero, obviously these are all incorrect stats for the source file... also is ffdshow even needed? |
17th March 2007, 20:21 | #1377 | Link | |
HDConvertToX author
after opening (in virtualdub) in "video" select direct stream copy and the same for audio, then go to file and save it with a new name your problem should be fixed BHH
17th March 2007, 20:39 | #1378 | Link |
just tried that and same result, seems vdub copied the "non-zero starting point" into the new file. i even tried cutting out the first ~1s hoping it would then create a new starting point in teh new file, but it stills keeps the "non-zero starting point"
17th March 2007, 21:58 | #1379 | Link | |
Playing with MKV files...
Which setting is that? I still haven't deciphered the steps on the 0-1 quality scale that's used in the settings.
@ALL Does anyone know of a video player for WindowsXP that is more efficient at playing X264 video than VLC media player. I was having an issue with video freezing up for several seconds at a time or occasionally having high action portions of the screen scrambled, but audio plays normally through during this brief interruption. After looking at my system monitor during these times, I have come to the horrible realization my CPU is not powerful enough to play back some parts of the files I am creating! But another computer in the house (not mine) is able to play them back. Would my graphics card have any effect on playback performance? I have a very low end graphics card and would be willing to replace it if it would fix this issue. |
17th March 2007, 22:24 | #1380 | Link | ||
HDConvertToX author
@schizosmurf
try this create an avs script with directshowsource("c:\my_broken_avi.avi") #where the file name is the name of broken one's feed automkv with this file (both for audio and video) try encoding @nx6 on advanced audio setting is possible to select the -CBR or -BR setting for Nero Quote:
2) mediaplayer classic +coreavc + haali media splitter 3) mplayer Quote:
BHH
