Old 26th May 2011, 11:57   #201  |  Link
ChaosKing
I just tried your beta, but it still crashes with: SmoothLevels(gamma=2.22)
and now
SmoothLevels(useMT=-1,lmode=1,gamma=2.22,useOPT=-1)
crashes too.
Old 26th May 2011, 13:58   #202  |  Link
LaTo
LaTo INV.
LaTo's Avatar
and now
crashes too.
Originally Posted by ninja_racoon View Post
^I've tried the beta2, it still giving me error
(gamma=1.1,Lmode=2,protect=16,useMT=0,useOPT=2) beta2 <-- error
(gamma=1.1,Lmode=2,protect=16,useMT=4,useOPT=2) beta2 <-- crash
@ChaosKing & @ninja_racoon: Here is a new fixed version (I hope ): > SmoothAdjust-FIX.dll <
(It's a bit hard to debug without the target CPU)
Originally Posted by Ponder View Post
One final thought, I know you are quite busy working on 2.0beta, Any chance of a
Ecurve = Ylevelss type only if it is not too time consuming in the future.
@Ponder: YlevelsS is the same as SmoothLevels(Lmode=2,Ecurve=0)
fair enough
but:
=400fps
=120fps
that's on an o/c Q9650, XPSP3, Avisynth 2.6
@leeperry: Try the fixed version in this post, it should be much faster when smooth=0.
LaTo is offline   Reply With Quote
Old 26th May 2011, 15:15   #203  |  Link
Ponder
@Lato
Yes, they are from same sine family, but parameter must be very different, since I can't get
the contrast similar to YlevelsS, I don't want to use tweak to get contrast after SMOOTHLEVELS,
it slows thing down and risk polarizing. Can we have a third Ecurve mode where one can define
their own whacky function?
Ponder is offline   Reply With Quote
Old 26th May 2011, 22:47   #204  |  Link
leeperry
Kid for Today
AMAZING, I get +700fps now
now to try it w/ movies, thank you so much for the quick fix
PS: I've A/B'ed the old and new versions around 50 times on many samples...the new one looks noticeably clearer and sharper when doing TV>PC, you've come a long way since the first script version..major kudos to you!
Old 27th May 2011, 11:10   #205  |  Link
ninja_racoon
Does it really prevents banding with smooth=50 and dither=50 settings when I encode using x264?
it still crashes for me.
(gamma=1.1,Lmode=2,protect=16,useMT=0,useOPT=2) <-- error
(gamma=1.1,Lmode=2,protect=16,useMT=4,useOPT=2) <-- crash
ninja_racoon is offline   Reply With Quote
Old 27th May 2011, 18:44   #206  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Update 2011/05/27
v2.00 beta2:
tweaked smoothing algorithm
fixed crash with mod4 clip
fixed freeze in debug view
tweaked speed when smooth=0
Todo-list:
- finish higher bitdepth support
- repair AVX code
- fix all bugs reported
Download here: > SmoothAdjust v2.00 beta2 <
Old 27th May 2011, 19:27   #207  |  Link
LaTo
LaTo INV.
LaTo's Avatar
@ChaosKing & @ninja_racoon: About the crash/error with AVX stuff, please check the 6 dlls in this package: > AVX_debug.zip <
Could you test them with SmoothLevels(gamma=2.0) and with SmoothTweak(contrast=2.0)?
Then see which ones work and report here.
Thanks for all!
Old 28th May 2011, 16:52   #208  |  Link
ChaosKing
Only SmoothAdjust.6.dll is working. 1-5 = big crash
Old 28th May 2011, 17:24   #209  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Great, I think I got it
Old 29th May 2011, 17:08   #210  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Update 2011/05/29
v2.00 beta3:
fixed misaligned clip in AVX
finished 16bits support (stacked MSB/LSB)
Todo-list:
- check avisynth 2.6.x support (any inputs?)
- fix all bugs
Download here: > SmoothAdjust v2.00 beta3 <
Old 29th May 2011, 20:40   #211  |  Link
markanini
Tell us more about the tweaked smoothing algorithm
markanini is offline   Reply With Quote
Old 30th May 2011, 09:35   #212  |  Link
ninja_racoon
Yes, no.6 is working
Old 30th May 2011, 09:40   #213  |  Link
LaTo
LaTo INV.
LaTo's Avatar
beta3 should work too, right?
Old 30th May 2011, 09:40   #214  |  Link
ninja_racoon
Thanks!
Old 30th May 2011, 18:53   #215  |  Link
mandarinka
mandarinka's Avatar
The 16bit hack is a nice idea, imho, getting hig bitdepth working without core changes.
Avisynth itself moves slowly and filters would need rewriting for a new colorspace anyway.
Now if only somebody wrote an import filter for x264cli
mandarinka is offline   Reply With Quote
Old 30th May 2011, 23:09   #216  |  Link
cretindesalpes
cretindesalpes's Avatar
# "last" is a stacked MSB/LSB 16-bit clip
Interleave (Dither_get_lsb (), Dither_get_msb ())
TurnRight ()
AssumeFieldBased ().AssumeTFF ()
Weave ()
TurnLeft ()
# Ready to be encoded with:
# avs2yuv -raw "script.avs" -o - | x264-10bit --demuxer raw --input-depth 16 --input-res 1280x720 --fps 24 --output "blah.mp4" -
# Set --input-res and --fps according to your video settings.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding
Last edited by cretindesalpes; 30th May 2011 at 23:20. Reason: Reduced the font size
cretindesalpes is offline   Reply With Quote
Old 31st May 2011, 09:10   #217  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Update 2011/05/31
v2.00 beta4:
fixed YV16 & YV24 support
added Y8 & YV411 support
Todo-list:
- fix all bugs
Download here: > SmoothAdjust v2.00 beta4 <
Now you can process YUY2 clip without quality loss in Avisynth 2.6.x:
ConvertToYV16() #Lossless
SmoothAdjust(...)
ConvertToYUY2() #Lossless
My todo list is empty, so if you have any feature request...
Old 31st May 2011, 09:54   #218  |  Link
cretindesalpes
Previously...
Originally Posted by Wilbert View Post
Looks like a great plugin! Would you be willing to release it as open source?
Maybe I don't know, but before I need to complete my todo-list
Old 31st May 2011, 13:40   #219  |  Link
Dogway
I was going to test the 16bit version, I think it could be more convenient if you could remap the values internally(?)
I also think you could add an option for when dealing with TVrange sources, specially in smoothlevels and tweak where you have no way.
more room when show=true for settings
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 31st May 2011, 21:32   #220  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Originally Posted by cretindesalpes View Post
Previously...
Good pick... Maybe with the 2.0final
You only need to multiply value by 256.
If I remap the value internally, it avoids fine adjustments.
In SmoothLevels you only need to set output_low/output_high at 16/235 (or 4096/60160 in 16bits).
In SmoothTweak TVrange/PCrange doesn't change the processing (you can set "limiter=true" in TVrange).
