16th July 2008, 18:34 | #101 | Link | |
platinum, sorry if i missed this, but what motherboard are you running? |
16th July 2008, 18:35 | #102 | Link | |
Results for x264.exe v0.58.747 encoded 1442 frames, 20.14 fps, 3905.08 kb/s encoded 1442 frames, 20.16 fps, 3905.08 kb/s encoded 1442 frames, 21.55 fps, 3905.08 kb/s encoded 1442 frames, 20.58 fps, 3905.08 kb/s encoded 1442 frames, 4.84 fps, 3942.92 kb/s encoded 1442 frames, 5.02 fps, 3942.92 kb/s encoded 1442 frames, 5.00 fps, 3942.92 kb/s encoded 1442 frames, 4.86 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 21.86 fps, 3887.38 kb/s encoded 1442 frames, 21.70 fps, 3887.34 kb/s encoded 1442 frames, 21.74 fps, 3889.11 kb/s encoded 1442 frames, 21.64 fps, 3889.96 kb/s encoded 1442 frames, 5.23 fps, 3953.73 kb/s encoded 1442 frames, 5.21 fps, 3953.23 kb/s encoded 1442 frames, 5.21 fps, 3953.35 kb/s encoded 1442 frames, 5.23 fps, 3953.35 kb/s System Details -------------- Name Intel Core Duo T2600 Codename Yonah Specification Genuine Intel(R) CPU T2600 @ 2.16GHz Core Stepping C0 Technology 65 nm Stock frequency 2166 MHz Core Speed 2163.9 MHz (13.0 x 166.5 MHz) FID range 6.0x - 13.0x Northbridge Intel i945GM rev. 03 Southbridge Intel 82801GHM (ICH7-M/U) rev. B0 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 13 Memory Frequency 332.9 MHz (1:2) Memory Type DDR2 Memory Size 2034 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 1.263 V Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3 Package Socket 479 mPGA (platform ID = 5h) Temperature sensor 0 79°C (174°F) [0x15] (core #0) Temperature sensor 1 77°C (170°F) [0x17] (core #1) |
16th July 2008, 18:40 | #103 | Link |
anyone interested in doing a 1080p benchmark? i'm guessing the fps would be about half of 720p. awesome benchmark though, this really just makes me want to spend the $$ on a dual xeon/skulltrail setup. i've been using ripbot264 to do bluray->avchd 1080p backups to dvdr+dl and 7-9 fps second passes are killing me!
18th July 2008, 02:41 | #104 | Link |
here are my q6600 times:
Results for x264.exe v0.58.747 encoded 1442 frames, 59.46 fps, 3904.62 kb/s encoded 1442 frames, 58.97 fps, 3904.62 kb/s encoded 1442 frames, 59.16 fps, 3904.62 kb/s encoded 1442 frames, 59.27 fps, 3904.62 kb/s encoded 1442 frames, 16.78 fps, 3953.18 kb/s encoded 1442 frames, 16.74 fps, 3953.18 kb/s encoded 1442 frames, 16.75 fps, 3953.18 kb/s encoded 1442 frames, 16.75 fps, 3953.18 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 62.52 fps, 3888.35 kb/s encoded 1442 frames, 62.23 fps, 3889.37 kb/s encoded 1442 frames, 62.36 fps, 3889.68 kb/s encoded 1442 frames, 61.81 fps, 3887.62 kb/s encoded 1442 frames, 18.72 fps, 3963.17 kb/s encoded 1442 frames, 18.73 fps, 3962.98 kb/s encoded 1442 frames, 18.65 fps, 3962.72 kb/s encoded 1442 frames, 18.74 fps, 3962.66 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3000.8 MHz (9.0 x 333.4 MHz) FID range 6.0x - 9.0x Northbridge NVIDIA nForce 750i SLI SPP rev. A2 Southbridge NVIDIA nForce 750i SLI MCP rev. A3 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 400.1 MHz (5:6) Memory Type DDR2 Memory Size 3072 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 1.325 V Voltage sensor 0 3.26 Volts [0xCC] (+3.3V) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 64°C (147°F) [0x40] (TMPIN0) Temperature sensor 1 37°C (98°F) [0x25] (TMPIN1) Temperature sensor 0 84°C (183°F) [0x10] (core #0) Temperature sensor 1 82°C (179°F) [0x12] (core #1) Temperature sensor 2 79°C (174°F) [0x15] (core #2) Temperature sensor 3 80°C (175°F) [0x14] (core #3) Temperature sensor 0 70°C (157°F) [0x46] (GPU Core) |
25th July 2008, 12:33 | #105 | Link |
Testeur de codecs
Here really interessing result from my acer one with atom 1.6 Ghz. Will be interessing to have encoding with celeron 420 (1.6 Hz), pentuim E2140 (1.6 Ghz), sempron AM2 2800+ (1.6 Ghz), pentium M 730 (1.6 Ghz) ... to compare the core efficiency.
x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 5.81 fps, 3905.08 kb/s encoded 1442 frames, 5.83 fps, 3905.08 kb/s encoded 1442 frames, 5.81 fps, 3905.08 kb/s encoded 1442 frames, 5.82 fps, 3905.08 kb/s encoded 1442 frames, 1.42 fps, 3942.92 kb/s encoded 1442 frames, 1.41 fps, 3942.92 kb/s encoded 1442 frames, 1.41 fps, 3942.92 kb/s encoded 1442 frames, 1.42 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 6.65 fps, 3888.54 kb/s encoded 1442 frames, 6.62 fps, 3888.46 kb/s encoded 1442 frames, 6.63 fps, 3889.11 kb/s encoded 1442 frames, 6.61 fps, 3887.82 kb/s encoded 1442 frames, 1.58 fps, 3953.03 kb/s encoded 1442 frames, 1.57 fps, 3953.47 kb/s encoded 1442 frames, 1.56 fps, 3953.35 kb/s encoded 1442 frames, 1.57 fps, 3953.50 kb/s System Details -------------- Name Intel Atom Codename Diamondville Specification Intel(R) Atom(TM) CPU N270 @ 1.60GHz Core Stepping C0 Technology 45 nm Stock frequency 1666 MHz Core Speed 1596.2 MHz (12.0 x 133.0 MHz) FID range 6.0x - 12.0x Northbridge Intel i945GME rev. 03 Southbridge Intel 82801GHM (ICH7-M/U) rev. B0 CAS# 4.0 RAS# to CAS# 4 RAS# Precharge 4 Cycle Time (tRAS) 12 Memory Type DDR2 Memory Size 500 MBytes Channels Single Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) max VID 1.263 V Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 512 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3 Package Socket 437 FCBGA8 (platform ID = 2h) Temperature sensor 0 82°C (179°F) [0x2B] (core #0)
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
19th August 2008, 19:52 | #106 | Link |
Some kind of a fansubber
Results for x264.exe v0.58.747 encoded 1442 frames, 16.48 fps, 3905.08 kb/s encoded 1442 frames, 16.43 fps, 3905.08 kb/s encoded 1442 frames, 16.49 fps, 3905.08 kb/s encoded 1442 frames, 16.46 fps, 3905.08 kb/s encoded 1442 frames, 4.10 fps, 3942.92 kb/s encoded 1442 frames, 4.10 fps, 3942.92 kb/s encoded 1442 frames, 4.10 fps, 3942.92 kb/s encoded 1442 frames, 4.07 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 18.58 fps, 3887.97 kb/s encoded 1442 frames, 18.58 fps, 3887.75 kb/s encoded 1442 frames, 18.49 fps, 3887.97 kb/s encoded 1442 frames, 18.54 fps, 3889.11 kb/s encoded 1442 frames, 4.56 fps, 3953.12 kb/s encoded 1442 frames, 4.56 fps, 3953.01 kb/s encoded 1442 frames, 4.58 fps, 3953.01 kb/s encoded 1442 frames, 4.58 fps, 3953.35 kb/s System Details -------------- Name Intel Pentium D 830 Codename SmithField Specification Intel(R) Pentium(R) D CPU 3.00GHz Core Stepping A0 Technology 90 nm Stock frequency 3000 MHz Core Speed 2992.7 MHz (15.0 x 199.5 MHz) FID range 14.0x - 15.0x Northbridge Intel i945G/GZ rev. A2 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Memory Frequency 332.5 MHz (3:5) Memory Type DDR2 Memory Size 3072 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Voltage sensor 0 1.26 Volts [0x4F] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 43°C (109°F) [0x2B] (TMPIN0) Temperature sensor 2 57°C (134°F) [0x39] (TMPIN2) Code:
Results for x264.exe v0.58.747 encoded 1442 frames, 34.26 fps, 3905.08 kb/s encoded 1442 frames, 34.16 fps, 3905.08 kb/s encoded 1442 frames, 34.37 fps, 3905.08 kb/s encoded 1442 frames, 34.17 fps, 3905.08 kb/s encoded 1442 frames, 8.92 fps, 3942.92 kb/s encoded 1442 frames, 8.92 fps, 3942.92 kb/s encoded 1442 frames, 8.92 fps, 3942.92 kb/s encoded 1442 frames, 8.91 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 38.53 fps, 3889.96 kb/s encoded 1442 frames, 38.71 fps, 3889.96 kb/s encoded 1442 frames, 38.58 fps, 3889.96 kb/s encoded 1442 frames, 38.65 fps, 3889.96 kb/s encoded 1442 frames, 10.02 fps, 3953.35 kb/s encoded 1442 frames, 10.02 fps, 3953.35 kb/s encoded 1442 frames, 9.99 fps, 3953.35 kb/s encoded 1442 frames, 9.98 fps, 3953.35 kb/s System Details -------------- Name Intel Core 2 Duo E8400 Codename Wolfdale Specification Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Core Stepping C0 Technology 45 nm Stock frequency 3000 MHz Core Speed 3000.1 MHz (9.0 x 333.3 MHz) FID range 6.0x - 9.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IB (ICH9) rev. 02 CAS# 4.0 RAS# to CAS# 4 RAS# Precharge 4 Cycle Time (tRAS) 12 Command Rate 2T Memory Frequency 400.0 MHz (5:6) Memory Type DDR2 Memory Size 2046 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 1.225 V Voltage sensor 0 1.18 Volts [0x4A] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 0h) Temperature sensor 0 45°C (112°F) [0x2D] (CPU) Temperature sensor 1 41°C (105°F) [0x29] (System) Temperature sensor 0 63°C (145°F) [0x2A] (core #0) Temperature sensor 1 60°C (139°F) [0x2D] (core #1) Temperature sensor 0 50°C (121°F) [0x32] (GPU Core) |
24th August 2008, 02:21 | #107 | Link |
the hedgehog
results on a Athlon64x2 5000+ with 110% OC
x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 28.35 fps, 3905.08 kb/s encoded 1442 frames, 28.34 fps, 3905.08 kb/s encoded 1442 frames, 28.38 fps, 3905.08 kb/s encoded 1442 frames, 28.41 fps, 3905.08 kb/s encoded 1442 frames, 6.71 fps, 3942.92 kb/s encoded 1442 frames, 6.70 fps, 3942.92 kb/s encoded 1442 frames, 6.71 fps, 3942.92 kb/s encoded 1442 frames, 6.69 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 29.69 fps, 3889.96 kb/s encoded 1442 frames, 29.73 fps, 3887.89 kb/s encoded 1442 frames, 29.66 fps, 3889.23 kb/s encoded 1442 frames, 29.65 fps, 3889.05 kb/s encoded 1442 frames, 7.07 fps, 3953.35 kb/s encoded 1442 frames, 7.06 fps, 3953.36 kb/s encoded 1442 frames, 7.07 fps, 3953.39 kb/s encoded 1442 frames, 7.08 fps, 3952.99 kb/s System Details -------------- Name AMD Athlon 64 X2 5000+ Codename Brisbane Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ Core Stepping BH-G2 Technology 65 nm Stock frequency 2600 MHz Core Speed 2860.1 MHz (13.0 x 220.0 MHz) Northbridge NVIDIA SPP190 (C51XE) rev. A2 Southbridge NVIDIA nForce 570 SLI rev. A2 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 408.6 MHz (CPU/7) Memory Type DDR2 Memory Size 1024 MBytes Channels Single Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 1.350 V Voltage sensor 0 1.33 Volts [0x53] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket AM2 (940) Temperature sensor 0 70°C (157°F) [0x46] (TMPIN0) Temperature sensor 1 41°C (105°F) [0x29] (TMPIN1) Temperature sensor 2 11°C (51°F) [0xB] (TMPIN2) Temperature sensor 0 46°C (115°F) [0x17D] (core #0) Temperature sensor 1 47°C (116°F) [0x17F] (core #1) Temperature sensor 0 49°C (120°F) [0x31] (GPU Core)
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73 latest MPC-HC (MVS2010 SP1, GCC 4.7.1) VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on |
27th August 2008, 14:28 | #108 | Link |
Result from my MAC PRO bi quad 3Ghz under Windows Server 2008 X64:
Results for x264.exe v0.58.747 encoded 1442 frames, 63.88 fps, 3904.94 kb/s encoded 1442 frames, 64.42 fps, 3904.94 kb/s encoded 1442 frames, 64.50 fps, 3904.94 kb/s encoded 1442 frames, 64.28 fps, 3904.94 kb/s encoded 1442 frames, 32.08 fps, 3974.08 kb/s encoded 1442 frames, 31.91 fps, 3974.08 kb/s encoded 1442 frames, 31.95 fps, 3974.08 kb/s encoded 1442 frames, 31.84 fps, 3974.08 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 65.84 fps, 3894.25 kb/s encoded 1442 frames, 65.00 fps, 3895.56 kb/s encoded 1442 frames, 65.47 fps, 3895.56 kb/s encoded 1442 frames, 65.75 fps, 3894.31 kb/s encoded 1442 frames, 35.72 fps, 3981.71 kb/s encoded 1442 frames, 35.50 fps, 3981.30 kb/s encoded 1442 frames, 35.53 fps, 3981.22 kb/s encoded 1442 frames, 35.55 fps, 3981.71 kb/s System Details -------------- Name Intel Xeon X5365 Name Intel Xeon X5365 Codename Clovertown Codename Clovertown Specification Intel(R) Xeon(R) CPU X5365 @ 3.00GHz Specification Intel(R) Xeon(R) CPU X5365 @ 3.00GHz Core Stepping B3 Core Stepping B3 Technology 65 nm Technology 65 nm Stock frequency 3000 MHz Stock frequency 3000 MHz Core Speed 2992.6 MHz (9.0 x 332.5 MHz) Core Speed 2992.6 MHz (9.0 x 332.5 MHz) FID range 6.0x - 9.0x FID range 6.0x - 9.0x Northbridge Intel 5000X rev. 31 Southbridge Intel 6321ESB rev. 09 Memory Frequency 332.5 MHz (1:1) Memory Type FB-DDR2 Memory Size 9210 MBytes Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 1.413 V max VID 1.413 V Number of processors 2 Number of threads 8 Number of threads 4 (max 4) Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 771 LGA (platform ID = 6h) Package Socket 771 LGA (platform ID = 6h) Temperature sensor 0 82°C (179°F) [0x12] (core #0) Temperature sensor 1 77°C (170°F) [0x17] (core #1) Temperature sensor 2 74°C (165°F) [0x1A] (core #2) Temperature sensor 3 79°C (174°F) [0x15] (core #3) Temperature sensor 0 71°C (159°F) [0x1D] (core #0) Temperature sensor 1 69°C (156°F) [0x1F] (core #1) Temperature sensor 2 67°C (152°F) [0x21] (core #2) Temperature sensor 3 67°C (152°F) [0x21] (core #3) Temperature sensor 0 61°C (141°F) [0x3D] (GPU Core) |
31st October 2008, 01:42 | #109 | Link |
Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 85.05 fps, 3904.32 kb/s encoded 1442 frames, 84.90 fps, 3905.23 kb/s encoded 1442 frames, 84.28 fps, 3905.23 kb/s encoded 1442 frames, 84.74 fps, 3905.23 kb/s encoded 1442 frames, 23.99 fps, 3952.92 kb/s encoded 1442 frames, 23.90 fps, 3952.94 kb/s encoded 1442 frames, 23.99 fps, 3952.94 kb/s encoded 1442 frames, 23.96 fps, 3952.94 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 91.83 fps, 3891.41 kb/s encoded 1442 frames, 92.20 fps, 3889.53 kb/s encoded 1442 frames, 91.82 fps, 3883.49 kb/s encoded 1442 frames, 92.01 fps, 3883.38 kb/s encoded 1442 frames, 26.95 fps, 3962.86 kb/s encoded 1442 frames, 26.93 fps, 3962.76 kb/s encoded 1442 frames, 26.90 fps, 3963.64 kb/s encoded 1442 frames, 26.87 fps, 3962.99 kb/s System Details -------------- Name Intel Core 2 Quad Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9650 @ 3.00GHz Core Stepping E0 Technology 45 nm Stock frequency 3000 MHz Core Speed 4050.4 MHz (9.0 x 450.0 MHz) FID range 6.0x - 9.0x Northbridge Intel P45 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 540.1 MHz (5:6) Memory Type DDR3 Memory Size 3328 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 1.250 V Voltage sensor 0 1.34 Volts [0xA8] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 31°C (87°F) [0x1F] (SYSTIN) Temperature sensor 1 49°C (119°F) [0x61] (CPUTIN) Temperature sensor 2 19°C (65°F) [0x25] (AUXTIN) Temperature sensor 0 68°C (154°F) [0x25] (core #0) Temperature sensor 1 61°C (141°F) [0x2C] (core #1) Temperature sensor 2 66°C (150°F) [0x27] (core #2) Temperature sensor 3 68°C (154°F) [0x25] (core #3) Temperature sensor 0 37°C (97°F) [0x24] (GPU Core) |
29th January 2009, 06:38 | #110 | Link |
encoded 1442 frames, 89.17 fps, 3904.94 kb/s encoded 1442 frames, 90.13 fps, 3904.94 kb/s encoded 1442 frames, 89.08 fps, 3904.94 kb/s encoded 1442 frames, 89.60 fps, 3904.94 kb/s encoded 1442 frames, 32.73 fps, 3974.08 kb/s encoded 1442 frames, 32.80 fps, 3974.08 kb/s encoded 1442 frames, 32.61 fps, 3974.08 kb/s encoded 1442 frames, 32.70 fps, 3974.08 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 92.57 fps, 3895.56 kb/s encoded 1442 frames, 92.85 fps, 3895.56 kb/s encoded 1442 frames, 92.94 fps, 3895.56 kb/s encoded 1442 frames, 91.65 fps, 3895.56 kb/s encoded 1442 frames, 36.32 fps, 3981.22 kb/s encoded 1442 frames, 36.56 fps, 3981.22 kb/s encoded 1442 frames, 36.05 fps, 3981.30 kb/s encoded 1442 frames, 36.28 fps, 3981.30 kb/s System Details -------------- Name Intel Processor Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (Engineering Sample) Core Stepping Technology 45 nm Core Speed 3900.0 MHz (20.0 x 195.1 MHz) Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 Memory Frequency 1560.6 MHz () Memory Type DDR3 Memory Size 3070 MBytes Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 0.825 V Voltage sensor 0 1.36 Volts [0x55] (CPU VCORE) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package Socket 1366 LGA (platform ID = 1h) Temperature sensor 0 32°C (89°F) [0x20] (TMPIN0) Temperature sensor 1 49°C (120°F) [0x31] (TMPIN1) Temperature sensor 2 40°C (103°F) [0x28] (TMPIN2) Temperature sensor 0 72°C (161°F) [0x21] (core #0) Temperature sensor 1 73°C (163°F) [0x20] (core #1) Temperature sensor 3 70°C (157°F) [0x23] (core #3) Temperature sensor 2 70°C (157°F) [0x23] (core #2) Temperature sensor 0 39°C (102°F) [0x27] (GPU Core) |
1st February 2009, 19:40 | #111 | Link |
Encoding Dinosaur!
This is what you can expect from AMD's current entry level dual-core laptop CPU:
Results for x264.exe v0.58.747 encoded 1442 frames, 18.92 fps, 3905.08 kb/s encoded 1442 frames, 19.01 fps, 3905.08 kb/s encoded 1442 frames, 19.07 fps, 3905.08 kb/s encoded 1442 frames, 19.09 fps, 3905.08 kb/s encoded 1442 frames, 4.42 fps, 3942.92 kb/s encoded 1442 frames, 4.42 fps, 3942.92 kb/s encoded 1442 frames, 4.42 fps, 3942.92 kb/s encoded 1442 frames, 4.40 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 19.90 fps, 3889.96 kb/s encoded 1442 frames, 19.79 fps, 3889.96 kb/s encoded 1442 frames, 19.83 fps, 3889.96 kb/s encoded 1442 frames, 19.87 fps, 3889.96 kb/s encoded 1442 frames, 4.63 fps, 3953.35 kb/s encoded 1442 frames, 4.64 fps, 3953.35 kb/s encoded 1442 frames, 4.64 fps, 3953.35 kb/s encoded 1442 frames, 4.65 fps, 3953.35 kb/s System Details -------------- Name AMD Turion X2 RM-60 Codename Griffin Specification AMD Athlon(tm) X2 Dual-Core QL-60 Core Stepping Technology 65 nm Stock frequency 1900 MHz Core Speed 1900.0 MHz (9.5 x 200.0 MHz) FID range 5.0x - 5.5x Northbridge AMD 780G rev. 00 Southbridge ATI SB700 rev. 00 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 1T Memory Frequency 333.3 MHz (3:5) Memory Type DDR2 Memory Size 2814 MBytes Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 1 (Build 6001) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket S1 (638) Package Type 0x2 Temperature sensor 0 73°C (162°F) [0x245] (core #0) Temperature sensor 1 73°C (163°F) [0x248] (core #1) Last edited by DJ Bobo; 3rd February 2009 at 14:16. |
2nd March 2009, 19:31 | #112 | Link |
AMD Phenom II 920 2800 Mhz
Results for x264.exe v0.58.747 encoded 1442 frames, 59.25 fps, 3903.62 kb/s encoded 1442 frames, 59.60 fps, 3905.01 kb/s encoded 1442 frames, 59.37 fps, 3905.01 kb/s encoded 1442 frames, 59.98 fps, 3905.01 kb/s encoded 1442 frames, 15.27 fps, 3953.03 kb/s encoded 1442 frames, 15.32 fps, 3952.80 kb/s encoded 1442 frames, 15.34 fps, 3952.80 kb/s encoded 1442 frames, 15.31 fps, 3952.80 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 61.01 fps, 3886.90 kb/s encoded 1442 frames, 61.30 fps, 3891.55 kb/s encoded 1442 frames, 61.46 fps, 3891.55 kb/s encoded 1442 frames, 61.67 fps, 3891.55 kb/s encoded 1442 frames, 16.43 fps, 3963.38 kb/s encoded 1442 frames, 16.44 fps, 3963.43 kb/s encoded 1442 frames, 16.45 fps, 3963.43 kb/s encoded 1442 frames, 16.43 fps, 3963.43 kb/s System Details -------------- Name AMD Phenom Codename Deneb Specification AMD Phenom(tm) II X4 920 Processor Core Stepping Technology 45 nm Stock frequency 2800 MHz Core Speed 2813.2 MHz (14.0 x 200.9 MHz) FID range 5.0x - 14.0x Northbridge NVIDIA nForce 560 rev. A3 Southbridge NVIDIA nForce 560 rev. A3 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 401.9 MHz (1:2) Memory Type DDR2 Memory Size 3070 MBytes Channels Single Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 1.350 V Voltage sensor 0 1.38 Volts [0x56] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 37°C (98°F) [0x25] (TMPIN0) Temperature sensor 1 59°C (138°F) [0x3B] (TMPIN1) Temperature sensor 2 46°C (114°F) [0x2E] (TMPIN2) Temperature sensor 0 54°C (128°F) [0x1AC] (core #0) Temperature sensor 1 54°C (129°F) [0x1B0] (core #1) Temperature sensor 2 54°C (129°F) [0x1B0] (core #2) Temperature sensor 3 54°C (129°F) [0x1B0] (core #3) Temperature sensor 0 63°C (145°F) [0x3F] (GPU Core) |
3rd March 2009, 01:22 | #113 | Link | |
My old E2160@2180 and old x264 revs. Pretty useeless indeed.
7th March 2009, 03:19 | #114 | Link |
Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 26.93 fps, 3905.08 kb/s encoded 1442 frames, 26.83 fps, 3905.08 kb/s encoded 1442 frames, 26.58 fps, 3905.08 kb/s encoded 1442 frames, 26.50 fps, 3905.08 kb/s encoded 1442 frames, 6.75 fps, 3942.92 kb/s encoded 1442 frames, 6.78 fps, 3942.92 kb/s encoded 1442 frames, 6.76 fps, 3942.92 kb/s encoded 1442 frames, 6.75 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 29.84 fps, 3889.96 kb/s encoded 1442 frames, 29.62 fps, 3889.96 kb/s encoded 1442 frames, 29.69 fps, 3889.96 kb/s encoded 1442 frames, 29.63 fps, 3889.96 kb/s encoded 1442 frames, 7.52 fps, 3953.35 kb/s encoded 1442 frames, 7.49 fps, 3953.35 kb/s encoded 1442 frames, 7.53 fps, 3953.35 kb/s encoded 1442 frames, 7.53 fps, 3953.35 kb/s System Details -------------- Name Intel Core 2 Duo E6600 Codename Conroe Specification Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz Core Stepping B2 Technology 65 nm Stock frequency 2400 MHz Core Speed 2399.9 MHz (9.0 x 266.7 MHz) FID range 6.0x - 9.0x Northbridge NVIDIA nForce 650i SLI SPP rev. A2 Southbridge NVIDIA nForce 650i SLI MCP rev. A3 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 400.0 MHz (2:3) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 1.350 V Voltage sensor 0 1.31 Volts [0x52] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 0h) Temperature sensor 0 55°C (130°F) [0x37] (CPU) Temperature sensor 1 49°C (120°F) [0x31] (System) Temperature sensor 0 58°C (136°F) [0x1B] (core #0) Temperature sensor 1 58°C (136°F) [0x1B] (core #1) Temperature sensor 0 77°C (170°F) [0x4D] (GPU Core) |
28th March 2009, 00:31 | #115 | Link |
Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 107.12 fps, 3904.62 kb/s encoded 1442 frames, 106.85 fps, 3904.62 kb/s encoded 1442 frames, 107.18 fps, 3904.62 kb/s encoded 1442 frames, 107.48 fps, 3904.62 kb/s encoded 1442 frames, 29.22 fps, 3953.18 kb/s encoded 1442 frames, 29.25 fps, 3953.18 kb/s encoded 1442 frames, 29.19 fps, 3953.18 kb/s encoded 1442 frames, 29.05 fps, 3953.18 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 114.79 fps, 3889.34 kb/s encoded 1442 frames, 115.72 fps, 3889.34 kb/s encoded 1442 frames, 115.06 fps, 3889.34 kb/s encoded 1442 frames, 115.94 fps, 3889.34 kb/s encoded 1442 frames, 32.53 fps, 3962.76 kb/s encoded 1442 frames, 32.76 fps, 3962.76 kb/s encoded 1442 frames, 32.55 fps, 3962.76 kb/s encoded 1442 frames, 32.63 fps, 3962.75 kb/s System Details -------------- Name Intel Processor Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (Engineering Sample) Core Stepping Technology 45 nm Core Speed 4405.0 MHz (21.0 x 209.8 MHz) Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 Memory Frequency 1678.1 MHz () Memory Type DDR3 Memory Size 6136 MBytes Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 0.825 V Voltage sensor 0 1.42 Volts [0xB2] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package Socket 1366 LGA (platform ID = 1h) Temperature sensor 0 39°C (102°F) [0x27] (SYSTIN) Temperature sensor 1 59°C (138°F) [0x76] (CPUTIN) Temperature sensor 2 17°C (62°F) [0x1DE] (AUXTIN) Temperature sensor 0 79°C (174°F) [0x1A] (core #0) Temperature sensor 1 71°C (159°F) [0x22] (core #1) Temperature sensor 2 74°C (165°F) [0x1F] (core #2) Temperature sensor 3 71°C (159°F) [0x22] (core #3) Temperature sensor 0 56°C (132°F) [0x38] (GPU Core) Temperature sensor 0 63°C (145°F) [0x3F] (GPU Core) |
23rd June 2009, 14:24 | #117 | Link |
You can find here some results, but they are made with newer x264:
http://www.forum-3dcenter.org/vbulle...4&postcount=32 http://www.forum-3dcenter.org/vbulle...6&postcount=41 http://www.forum-3dcenter.org/vbulle...5&postcount=92 http://www.forum-3dcenter.org/vbulle...0&postcount=94 http://www.forum-3dcenter.org/vbulle...0&postcount=96 PII: http://www.forum-3dcenter.org/vbulle...2&postcount=37 http://www.forum-3dcenter.org/vbulle...&postcount=100 http://www.forum-3dcenter.org/vbulle...&postcount=101 http://www.forum-3dcenter.org/vbulle...&postcount=102 |
27th June 2009, 07:08 | #119 | Link | |
wish i had i7 (T_T)
28th June 2009, 13:29 | #120 | Link |
Encoding Dinosaur!
@ m3mbran3
You did notice that the i7 posted above is not at stock speed but overclocked to 4.4GHz right? So don't get too sad
AMD Athlon X2 QL-60 (1.9GHz) - 3GB DDR2-667 - ATi Radeon HD 3200 - Windows 7 Ultimate 32-bit Encode to Vorbis at ultra high speed using SSE3 multithreaded encoder by Lancer! |
