2nd March 2011, 23:50 | #11441 | Link |
I, too, noticed the RAM problem on my PC.
In the creating m2ts phase everything is fine but in the creating movie only BD structure phase the memory usage causes my system to barely respond as Windows begins swapping. In the first picture you can see the ram usage for the m2ts creation and when it begins to rise that's the creating movie only BD structure(when you look at the process list neither BD-RB nor tsmuxer are shown with that much memory, tsmuxer with 250-300 MB as in the m2ts creation phase). In the second picture you see the memory usage after BD-RB is finished and more than 3 GB are released. |
3rd March 2011, 02:44 | #11442 | Link | |
Luckily I can still use my iPad from bed so I can read reports. |
3rd March 2011, 02:53 | #11443 | Link | |
And to continue with bug reports replies goes above and beyond!! So a sincere |
3rd March 2011, 19:24 | #11447 | Link |
@jdobbs
My source is AVC 1080i 25fps, MBAFF, but content is progressive. DB-RB encoded it as 1080p25 (progressive) which is not blu-ray compliant (correct me if I am wrong). Should I have selected "Use DECOMB filter on interlaced sources" in the setup and insert DEINTERLACER_TYPE=4 in the .ini for this source? |
4th March 2011, 00:14 | #11448 | Link |
Multiplexing M2TS... Failed to build structure, aborted
First, and foremost, sorry to hear you are laid up. Get well soon.
For a long time I have seen this error while processing titles that have a lot of small files. At first I chalked it up to forgetting to shutdown my virus checker, but have found that does not seem to help. I first processed this title with 37.05 but when I got the error I could not restart so I went back to 37.04. As you will see from the logs, this error occurred multiple times. Each time I just hit the backup button and told it to resume. Because of the number of files the logs are quite large so I did not post the .ini, .cmd or inspect files. The inspect reports no problems. Virus checking is turned off. Machine is Intel Dual Core (2.97) with 4 gb memory and 700 gb of free disk space (unfragmented) Code:
[Status] LABEL=ABOUTMARRY VERSION=v0.37.04 (beta) SOURCE_SIZE=27924320256 SOURCE_VIDEO_SIZE=27924320256 TARGET_SIZE=24641536000 REDUCTION=.88243995821905 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=-1 QUICK=0 ENCODE_STEP=0 COMPLETED=24 REBUILD_COMPLETE=1 [00078] AUDIO=10000111 PGS=100000000111 M2TS_TARGET=495755842 RATE=24741 NSTART=27000000 NEND=33462080 NSIZE=471244800 FLINK=-1 MLINK=0 [00014] M2TS_TARGET=3470854749 RATE=24734 NSTART=27000000 NEND=348550560 AUDIO=10000000 NSIZE=3256092672 FLINK=-1 MLINK=0 [00015] M2TS_TARGET=478064798 RATE=24597 NSTART=27000000 NEND=33266885 AUDIO=10000111 NSIZE=450115584 FLINK=-1 MLINK=0 [00017] M2TS_TARGET=504967329 RATE=24640 NSTART=27000000 NEND=33608477 AUDIO=10000111 NSIZE=477210624 FLINK=-1 MLINK=0 [00018] M2TS_TARGET=1067144553 RATE=24916 NSTART=27000000 NEND=40817553 AUDIO=10000111 NSIZE=1006516224 FLINK=-1 MLINK=0 [00020] M2TS_TARGET=413410893 RATE=24884 NSTART=27000000 NEND=32358478 AUDIO=10000111 NSIZE=389345280 FLINK=-1 MLINK=0 [00021] M2TS_TARGET=190974352 RATE=24583 NSTART=27000000 NEND=29503751 AUDIO=10000111 NSIZE=179097600 FLINK=-1 MLINK=0 [00023] M2TS_TARGET=2145257228 RATE=24711 NSTART=27000000 NEND=55002975 AUDIO=10000111 NSIZE=2013333504 FLINK=-1 MLINK=0 [00024] M2TS_TARGET=260220446 RATE=24584 NSTART=27000000 NEND=30412158 AUDIO=10000111 NSIZE=247449600 FLINK=-1 MLINK=0 [00026] M2TS_TARGET=1518718871 RATE=24735 NSTART=27000000 NEND=46804785 AUDIO=10000111 NSIZE=1424013312 FLINK=-1 MLINK=0 [00027] M2TS_TARGET=1445487819 RATE=24723 NSTART=27000000 NEND=45858840 AUDIO=10000111 NSIZE=1352724480 FLINK=-1 MLINK=0 [00029] M2TS_TARGET=2097275084 RATE=24609 NSTART=27000000 NEND=54486834 AUDIO=10000111 NSIZE=1963726848 FLINK=-1 MLINK=0 [00030] M2TS_TARGET=466017756 RATE=24697 NSTART=27000000 NEND=33084828 AUDIO=10000111 NSIZE=436463616 FLINK=-1 MLINK=0 [00032] M2TS_TARGET=1157188331 RATE=24763 NSTART=27000000 NEND=42073183 AUDIO=10000111 NSIZE=1086154752 FLINK=-1 MLINK=0 [00033] M2TS_TARGET=475776836 RATE=24735 NSTART=27000000 NEND=33203072 AUDIO=10000111 NSIZE=447713280 FLINK=-1 MLINK=0 [00890] M2TS_TARGET=966951332 RATE=24690 NSTART=27000000 NEND=39631368 AUDIO=10000111 NSIZE=909176832 FLINK=-1 MLINK=0 [00035] M2TS_TARGET=76619621 RATE=24517 NSTART=27000000 NEND=28006005 AUDIO=10000111 NSIZE=74489856 FLINK=-1 MLINK=0 [00037] M2TS_TARGET=425338658 RATE=24501 NSTART=27000000 NEND=32596841 AUDIO=10000111 NSIZE=397529088 FLINK=-1 MLINK=0 [00038] M2TS_TARGET=393388514 RATE=24947 NSTART=27000000 NEND=32086331 AUDIO=10000111 NSIZE=369125376 FLINK=-1 MLINK=0 [00040] M2TS_TARGET=1077028332 RATE=24759 NSTART=27000000 NEND=41031517 AUDIO=10000111 NSIZE=1014988800 FLINK=-1 MLINK=0 [00041] M2TS_TARGET=220354604 RATE=24872 NSTART=27000000 NEND=29856603 AUDIO=10000111 NSIZE=206192640 FLINK=-1 MLINK=0 [00043] M2TS_TARGET=1375661602 RATE=24770 NSTART=27000000 NEND=44914771 AUDIO=10000111 NSIZE=1291769856 FLINK=-1 MLINK=0 [00044] M2TS_TARGET=569561595 RATE=24523 NSTART=27000000 NEND=34488731 AUDIO=10000111 NSIZE=535621632 FLINK=-1 MLINK=0 [00046] M2TS_TARGET=3349516854 RATE=24734 NSTART=27000000 NEND=70684265 AUDIO=10000111 NSIZE=3115603968 FLINK=0 MLINK=0 ________________________________ ----------------------- [08:41:56] BD Rebuilder v0.37.04 (beta) - Source: ABOUTMARRY - Input BD size: 26.01 GB - Approximate total content: [01:59:05.596] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [08:41:56] PHASE ONE, Encoding - [08:41:56] Extracting A/V streams [VID_00078] - [08:55:34] Reencoding: VID_00078 (1 of 24) - [08:55:34] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,444 frames - Bitrate: 24,741 Kbs - [08:55:34] Reencoding: VID_00078, Pass 1 of 1 - [08:58:49] Video Encode complete - [08:58:49] Reencoding audio tracks (if req'd) - [09:03:34] Multiplexing M2TS - [09:03:54] Extracting A/V streams [VID_00014] - [09:05:52] Reencoding: VID_00014 (2 of 24) - [09:05:52] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 24,119 frames - Bitrate: 24,734 Kbs - [09:05:52] Reencoding: VID_00014, Pass 1 of 1 - [09:30:41] Video Encode complete - [09:30:41] Multiplexing M2TS - [09:32:04] Extracting A/V streams [VID_00015] - [09:32:23] Reencoding: VID_00015 (3 of 24) - [09:32:23] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,340 frames - Bitrate: 24,597 Kbs - [09:32:23] Reencoding: VID_00015, Pass 1 of 1 - [09:35:41] Video Encode complete - [09:35:41] Multiplexing M2TS - [09:35:49] Extracting A/V streams [VID_00017] - [09:36:07] Reencoding: VID_00017 (4 of 24) - [09:36:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,522 frames - Bitrate: 24,640 Kbs - [09:36:07] Reencoding: VID_00017, Pass 1 of 1 - [09:39:40] Video Encode complete - [09:39:40] Multiplexing M2TS - [09:39:49] Extracting A/V streams [VID_00018] - [09:40:25] Reencoding: VID_00018 (5 of 24) - [09:40:25] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,363 frames - Bitrate: 24,916 Kbs - [09:40:25] Reencoding: VID_00018, Pass 1 of 1 - [09:47:47] Video Encode complete - [09:47:47] Multiplexing M2TS - [09:48:02] Extracting A/V streams [VID_00020] - [09:48:17] Reencoding: VID_00020 (6 of 24) - [09:48:17] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,856 frames - Bitrate: 24,884 Kbs - [09:48:17] Reencoding: VID_00020, Pass 1 of 1 - [09:51:10] Video Encode complete - [09:51:10] Multiplexing M2TS - [09:51:17] Extracting A/V streams [VID_00021] - [09:51:24] Reencoding: VID_00021 (7 of 24) - [09:51:24] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,335 frames - Bitrate: 24,583 Kbs - [09:51:24] Reencoding: VID_00021, Pass 1 of 1 - [09:52:46] Video Encode complete - [09:52:46] Multiplexing M2TS - [09:52:49] Extracting A/V streams [VID_00023] - [09:54:01] Reencoding: VID_00023 (8 of 24) - [09:54:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 14,921 frames - Bitrate: 24,711 Kbs - [09:54:01] Reencoding: VID_00023, Pass 1 of 1 - [10:09:08] Video Encode complete - [10:09:08] Multiplexing M2TS [10:09:45] - Failed to build structure, aborted ----------------------- [11:47:14] BD Rebuilder v0.37.04 (beta) - Source: ABOUTMARRY - Input BD size: 26.01 GB - Approximate total content: [01:59:05.596] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [11:47:15] PHASE ONE, Encoding - [11:47:15] Multiplexing M2TS - [11:47:56] Extracting A/V streams [VID_00024] - [11:48:07] Reencoding: VID_00024 (9 of 24) - [11:48:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,819 frames - Bitrate: 24,584 Kbs - [11:48:07] Reencoding: VID_00024, Pass 1 of 1 - [11:49:59] Video Encode complete - [11:49:59] Multiplexing M2TS - [11:50:03] Extracting A/V streams [VID_00026] - [11:50:54] Reencoding: VID_00026 (10 of 24) - [11:50:54] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 10,553 frames - Bitrate: 24,735 Kbs - [11:50:54] Reencoding: VID_00026, Pass 1 of 1 - [12:01:32] Video Encode complete - [12:01:32] Multiplexing M2TS - [12:02:06] Extracting A/V streams [VID_00027] - [12:02:57] Reencoding: VID_00027 (11 of 24) - [12:02:57] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 10,049 frames - Bitrate: 24,723 Kbs - [12:02:57] Reencoding: VID_00027, Pass 1 of 1 - [12:13:16] Video Encode complete - [12:13:16] Multiplexing M2TS - [12:13:49] Extracting A/V streams [VID_00029] - [12:15:01] Reencoding: VID_00029 (12 of 24) - [12:15:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 14,646 frames - Bitrate: 24,609 Kbs - [12:15:01] Reencoding: VID_00029, Pass 1 of 1 - [12:29:48] Video Encode complete - [12:29:48] Multiplexing M2TS - [12:30:25] Extracting A/V streams [VID_00030] - [12:30:43] Reencoding: VID_00030 (13 of 24) - [12:30:43] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,243 frames - Bitrate: 24,697 Kbs - [12:30:43] Reencoding: VID_00030, Pass 1 of 1 - [12:34:01] Video Encode complete - [12:34:01] Multiplexing M2TS [12:34:07] - Failed to build structure, aborted ----------------------- [12:51:26] BD Rebuilder v0.37.04 (beta) - Source: ABOUTMARRY - Input BD size: 26.01 GB - Approximate total content: [01:59:05.596] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [12:51:28] PHASE ONE, Encoding - [12:51:28] Multiplexing M2TS - [12:51:34] Extracting A/V streams [VID_00032] - [12:52:15] Reencoding: VID_00032 (14 of 24) - [12:52:15] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,032 frames - Bitrate: 24,763 Kbs - [12:52:15] Reencoding: VID_00032, Pass 1 of 1 - [13:00:27] Video Encode complete - [13:00:27] Multiplexing M2TS - [13:00:45] Extracting A/V streams [VID_00033] - [13:01:01] Reencoding: VID_00033 (15 of 24) - [13:01:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,306 frames - Bitrate: 24,735 Kbs - [13:01:01] Reencoding: VID_00033, Pass 1 of 1 - [13:04:22] Video Encode complete - [13:04:22] Multiplexing M2TS - [13:04:29] Extracting A/V streams [VID_00890] - [13:05:02] Reencoding: VID_00890 (16 of 24) - [13:05:02] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 6,731 frames - Bitrate: 24,690 Kbs - [13:05:02] Reencoding: VID_00890, Pass 1 of 1 - [13:11:54] Video Encode complete - [13:11:54] Multiplexing M2TS - [13:12:12] Extracting A/V streams [VID_00035] - [13:12:15] Reencoding: VID_00035 (17 of 24) - [13:12:15] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 537 frames - Bitrate: 24,517 Kbs - [13:12:15] Reencoding: VID_00035, Pass 1 of 1 - [13:12:49] Video Encode complete - [13:12:49] Multiplexing M2TS - [13:12:51] Extracting A/V streams [VID_00037] - [13:13:05] Reencoding: VID_00037 (18 of 24) - [13:13:05] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,983 frames - Bitrate: 24,501 Kbs - [13:13:05] Reencoding: VID_00037, Pass 1 of 1 - [13:16:08] Video Encode complete - [13:16:08] Multiplexing M2TS - [13:16:14] Extracting A/V streams [VID_00038] - [13:16:27] Reencoding: VID_00038 (19 of 24) - [13:16:27] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,711 frames - Bitrate: 24,947 Kbs - [13:16:27] Reencoding: VID_00038, Pass 1 of 1 - [13:19:13] Video Encode complete - [13:19:13] Multiplexing M2TS [13:19:19] - Failed to build structure, aborted ----------------------- [13:30:44] BD Rebuilder v0.37.04 (beta) - Source: ABOUTMARRY - Input BD size: 26.01 GB - Approximate total content: [01:59:05.596] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [13:30:46] PHASE ONE, Encoding - [13:30:46] Multiplexing M2TS - [13:30:51] Extracting A/V streams [VID_00040] - [13:31:29] Reencoding: VID_00040 (20 of 24) - [13:31:29] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 7,477 frames - Bitrate: 24,759 Kbs - [13:31:29] Reencoding: VID_00040, Pass 1 of 1 - [13:38:59] Video Encode complete - [13:38:59] Multiplexing M2TS - [13:39:12] Extracting A/V streams [VID_00041] - [13:39:20] Reencoding: VID_00041 (21 of 24) - [13:39:20] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,523 frames - Bitrate: 24,872 Kbs - [13:39:20] Reencoding: VID_00041, Pass 1 of 1 - [13:40:56] Video Encode complete - [13:40:56] Multiplexing M2TS - [13:40:59] Extracting A/V streams [VID_00043] - [13:41:45] Reencoding: VID_00043 (22 of 24) - [13:41:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 9,546 frames - Bitrate: 24,770 Kbs - [13:41:45] Reencoding: VID_00043, Pass 1 of 1 - [13:51:21] Video Encode complete - [13:51:22] Multiplexing M2TS - [13:51:43] Extracting A/V streams [VID_00044] - [13:52:02] Reencoding: VID_00044 (23 of 24) - [13:52:02] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,991 frames - Bitrate: 24,523 Kbs - [13:52:02] Reencoding: VID_00044, Pass 1 of 1 - [13:56:09] Video Encode complete - [13:56:09] Multiplexing M2TS - [13:56:16] Extracting A/V streams [VID_00046] - [13:58:07] Reencoding: VID_00046 (24 of 24) - [13:58:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 23,276 frames - Bitrate: 24,734 Kbs - [13:58:07] Reencoding: VID_00046, Pass 1 of 1 - [14:20:01] Video Encode complete - [14:20:01] Multiplexing M2TS [14:21:04]PHASE ONE complete [14:21:04]PHASE TWO - Rebuild Started - [14:21:04] Rebuilding BD file Structure [14:31:58] - Encode and Rebuild complete - WORKFILES folder removed. [14:31:59]JOB: ABOUTMARRY finished. |
5th March 2011, 00:40 | #11450 | Link |
Sleep Problem Fixed
Since installing v0.37.05 my computer no longer goes into sleep mode while encoding.
Love BDRB!
Windows 7 Pro Quad Core Intel Core i7 920 Asus P6T Deluxe V2 2 ATI Radeon HD 4770 Video Cards 6GB OCZ Gold DDR3 1600 Intel X25-M 80GB SSD HD 2 HANNS-G 28" Monitors 2 Hyundai 19" Monitors |
5th March 2011, 00:45 | #11451 | Link |
Here's wishing you a fast recovery!
5th March 2011, 10:56 | #11454 | Link |
I made a conversion using "Alternate movie only Output mode" to PAL DVD5.
Source audio is AC3 5.1, 448 kbps. I wanted to convert the audio to 2-ch 192. In the setup I selected both "Do not reencode AC3 (blu-ray only)", and "Use 192 kbps, 2 ch for AC3 encoding" The recoded audio became 192 kbps 5.1 rather than 2 ch. Is this a bug or intentional? Here the .avs: Code:
#Created by BD Rebuilder - v0.37.05 (beta) LoadPlugin("C:\Program Files\VIDEO\BD_Rebuilder\tools\nicaudio.dll") audio=NicAC3Source("00000.track_4352.ac3").Amplify(1.2) audio = (AudioChannels(audio) > 6) ? GetChannel(audio,1,2,3,4,7,8) : audio ConvertAudioTo16bit(ResampleAudio(audio, 48000)) |
5th March 2011, 16:56 | #11455 | Link | |
I don't see, though, how it could ever come out to 192Kbs for ALTERNATE/DVD-5 DD5.1 (unless you have modified ALTERNATE.TXT). DVD-5 should always use 448Kbs for 5.1. I'll look at it. [Edit] Well -- I stand corrected. It does use the selected audio settings (in SETUP) in ALTERNATE DVD-5 and DVD-9 encoding. Good catch. The AVS creation doesn't consider the fact that ALTERNATE DVD uses those settings and that's why the conversion from DD5.1->DD2.0 isn't done. I'll fix it for the next release. Last edited by jdobbs; 5th March 2011 at 17:17. |
5th March 2011, 18:05 | #11456 | Link |
Most important: first get your ankle fixed!
Perhaps you can have a look at my earlier post where I managed to produce a non-compliant blu-ray stream. |
5th March 2011, 22:56 | #11457 | Link | |
No preprocessing? I know there are tools that will create a BD structure and flag the video as 1080 25fps progressive (even though it is illegal). I'm not sure what BD-RB will do if it is fed bad information. Last edited by jdobbs; 5th March 2011 at 23:00. |
5th March 2011, 23:40 | #11458 | Link | |
The actual content however is progressive (identical field pairs, similar to most 'interlaced' DVDs). So it seems it would be a candidate for progressive encoding with --fake interlaced, but it looks as if --fake interlaced got lost somewhere along the chain. Added: Converting the same source in Alternate Mode to PAL DVD-5: Script: Code:
LoadPlugin("C:\Program Files\VIDEO\BD_Rebuilder\tools\decomb521.dll") FieldDeinterlace(blend=false) BilinearResize(720,576) ConvertToYV12().AssumeFPS(50000,1000) - TSmuxer creates the .mpv interlaced with 25 frames/s=50 fields/s. Movie duration still reported (MPC_HC) to be 50% but playback speed is now correct@25fps. - DVDAuthor creates the .vob at 25 progressive frames. Number of frames/fields=162'549/325'098. Movie duration and playback speed correct 100% of the original. => The final authored DVD fills the DVD-5 medium to 53 % only, movie duration and playback speed are correct. Added 2: Analyzing the original once more (using AvSP) indicates that it is 217.318 fields/s = 108.659 frames/s, progressive content i.e. the temporal resolution is 108.659 frames/s. Number of frames/fields=706'523/1'413'046. (I would assume that the odd framerates are due to rounding effects and should in fact be 100 frames/s or 200 fields/s respectively.) Irritating ...... Is the exceptional temporal resolution of 100 pictures/s causing the problems? I have increasing doubts whether the original is really blu-ray compliant or is properly flagged. Last edited by Sharc; 6th March 2011 at 14:52. Reason: Added, editorial |
6th March 2011, 15:25 | #11459 | Link | |
If what you are saying in your second "added" statement is true, and AvSP is anywhere near right -- then the source would have to be illegal to begin with. I'd have a hard time believing a "rounding error" could result in being off by more than 8%. Can you open the source with BDEDIT and see what the CLPI and MPLS say for video type and rate? Last edited by jdobbs; 6th March 2011 at 15:31. |
6th March 2011, 16:30 | #11460 | Link | ||
But probably "Resize - 1080p to 720p" has been set. I don't think this would have interfered with the Alternate Mode backup because it has always worked with other sources before. Quote:
Tab PLAYLIST: AVC, 1080i, 25 Last edited by Sharc; 6th March 2011 at 16:35. |
