1st May 2004, 05:20 | #121 | Link |
teh 8bit fool
it's probably something really stupid but i can't seem to figure it out.
using dif4u 1.4.7 w/ numenu scenarist ed., cce sp trial 2.66.01.07 eclcce v1.8b that came with numenu. followed the new big 3 guide. numenu completes the demuxing and vobsubbing and launches cce this is what i get from cce: Code:
couldn't find appopriate video codec for 'YV12' Code:
vinfo_open() failed: *** Could not open the file <X:\lost\D_VTS_01_0\FRAMESERVING\007.vaf> *** The system cannot find the file specified. [Windows error code: 0x2 2 the funny thing is i somehow got it to work once before but it froze at the stage of importing it into scenarist (maybe because i'm still using 2.6?) please let me know if i need to pull anything from the log. |
5th May 2004, 04:44 | #127 | Link |
Bavarian Ripping Angel
Hi
I don't know dvdlab but, I dont think that create motion menues with scenarist is complicated if you got it once. If you use only one programm you wont get problems which the other programms come with. |
5th May 2004, 15:04 | #129 | Link |
Dizzin It Fizzast Fo Yizz
he was saying it's not hard in Scenarist
"Those that can't... butcher. Those that can... DoItFast4U!" DoItFast4U! v.1.4.7 now available with: • Lightning fast subripping (up to 100x faster) •Choice of DoCCE4U/BatchCCE •DVD2AVIdg useable by ReAuthorist •Bitrate control for use with NuMenu4U •Extras Bitrate applied to smaller PGCs in Main VTS •ScenAid integration •Right-Click Menus •Minimize to Systray •Improved Deinterlace Scripts See: http://www.doitfast4u.com. Use the donation link on the above URL or the app itself to make a $15+ donation and join the VIP list today! |
5th May 2004, 18:56 | #130 | Link |
Linux Encoder
Tried re-encoding the menu of Finding Nemo NTSC R1.
I'm getting this error when "Processing SST Files & Analyzing Bitmaps..." Number: 9 Description: Subscript out of range EXE Name: NuMenu4U EXE Path: C:\Program Files\NuMenu4U EXE Version: Version 1.4.7 Call Stack (lowest level first) SUB_STREAM::Item (line 5) Anything else you might need to know what could be going on? |
5th May 2004, 19:30 | #132 | Link |
I just got some error aswell when it gets to the part where it wants to load scenarist, nemenu then give a message saying to load manually but then scenarist wont compile...
So for now i out the last numenu that didnt use scenarist as i just need to run it to remove the fake files from the video_ts.vob of Stuck On You |
5th May 2004, 19:59 | #134 | Link |
Legend
@zeul, if you need logs/scripts for the error master yoda mentioned, but not trying to strip out fake files then i can help out. unfortunately most dvd menus (about 5 or 6) i have tried gives that error, so i can re-create that easily
keep up the good work m8 |
8th May 2004, 16:42 | #137 | Link |
Germanicus
servus...
Can NuMenu4U handle DTS streams? I always get the same problem eith dts streams. I can choose the stream in menu, but it always starts with DD 5.1 stream. I don´t know what´s going on, but it´s really weird. any idea?
cya fourtyfour |
9th May 2004, 21:59 | #138 | Link |
Zeul
Alan here again. I have just tried Alan Partridge Series 2 disc 1 again using version 1.4.7 on its on (not using the big 3) and I get the following error: Number: 9 Description: Subscript out of range EXE Name: NUMenu4U EXE Path: C:\Program Files\NuMenu4U EXE Version: Version 1.4.7 Call Stack (lowest level first) SUB_STREAM::Item (line 5) I can send you the log file if you require it. |
12th May 2004, 06:44 | #139 | Link | |
Error
I am getting this error when trying to compile in Scenarist
12th May 2004, 08:08 | #140 | Link |
@fourtyfour
If you mean DTS streams in the main video play, then yes. If you mean DTS streams in the menu - then no. I have never seen a menu with DTS audio. From the files you have sent me, i can see that the ifo was not properly updated - this would result in no other sub or audio streams being selected (even though the button commands were correct). Did you run NuMenu4u with full scenarist control or update the ifo later? @AlanPartridge This error seems to be a common one, and it (and others) is being caused by a problem in the way NuMenu4u handles more than 1 BMP per cell. The latest build addresses this, but requires a bit more testing before a public release. @Sn8kbordin Not seen this before, please send me the script - see pm |
