21st November 2008, 16:09 | #5161 | Link | |
RE: Found MpegSplitter.ax - Now what?:D
clsid: Thanks for the tip on MpegSplitter.ax. I found MpegSplitter.ax in the standalone filters per your direction. Next I went into GSpot to change the merit of same. Odd thing though...could not see MpegSplitter.ax in GSpot's list of codecs and filters. Tried dropping file in other directories...nothing worked - still couldn't see it. So I couldn't change the merit to prioritize MpegSplitter.ax. Next I tried some other desperate stuff like deleting ffdshow.ax from ffdshow's directory and renaming MpegSplitter.ax as the "new" ffdshow.ax. All that did was render ffdshow useless and VMC defaulted back to the old default a/v codecs. So, honestly I feel like a noob here, but how best can I acheive the objective I am going for...BD/HD-Dvd playback in VMC with full HD-audio decoding using ffdshow? Much appreciated, Bebo clsid - got you PM - thanks will try. Last edited by bebo; 21st November 2008 at 16:33. |
21st November 2008, 16:33 | #5162 | Link |
To register u should paste this file into system32 directory (but not necessary), and register it, which means drag and drop over regsvr32.exe or choose start>> run>> regsvr32 mpegsplitter.ax U will see it in gspot as MPC - Mpeg Splitter (Gabest)
But... the only player which use this splitter (as standalone) issss.... MPC HC.. suuprise . Windows Media Player and others players refuse to play m2ts tested file (can't connect with mpegsplitter). So we deal with bug here. (?) |
21st November 2008, 16:40 | #5163 | Link | |
I guess this means that for TrueHD streams I will have to drop out of my VMC integration project and fire up 'ol Arcsoft TMT using the file structure. A bit clunky when demo-ing the rig but seems like that's it for now. So, I am out here on the fringe? Has nobody taken VMC player all the way to bright (full SD/HD A/V)? Hmmm... ....well I guess I must continue to bug Mike@haali to update the splitter to support MLP from .mt2s Last edited by bebo; 21st November 2008 at 16:42. |
21st November 2008, 16:45 | #5164 | Link |
You can use this registry tweak to force usage of the splitter.
Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\Media Type\Extensions\.m2ts] "Source Filter"="{1365BE7A-C86A-473C-9A41-C0A6E82C9FA3}"
MPC-HC 2.1.7.2 |
21st November 2008, 19:58 | #5166 | Link | |
im just concerned with the quality. ive so far used the ffmpeg deinterlacer, because I felt it has provided the best quality so far. what about yadif is that respect, does he provide a comparable quality as well, or is it primarily only a fast deinterlacer? |
21st November 2008, 20:19 | #5167 | Link | |
4:2:0 hater
21st November 2008, 21:06 | #5168 | Link | |
(you have to disable haali mpeg splitter, uninstall and reinstall if needed), also, restart was also required in my case after I registered MpegSplitter.ax. (I can't explain this) I can also use it with graph edit. |
21st November 2008, 22:14 | #5169 | Link |
I only have a gefore 7600gt, can I use it? if so, how to enable hardware deinterlacing in ffdshow? I only know about this deinterlacing box, but apparently all those deinterlacing options are for software/cpu deinterlacing
21st November 2008, 23:14 | #5170 | Link | |
21st November 2008, 23:40 | #5171 | Link | |
22nd November 2008, 00:51 | #5172 | Link | |
4:2:0 hater
HW deinterlacing is like DXVA, very susceptible, but it produces wonderful quality. |
22nd November 2008, 07:34 | #5176 | Link | |
Please remember to subtract decoding time. rev2303:MMX-EXT rev2307:SSSE3 rev2333:SSSE3 + 4 threads On Core2 Quad, MPEG-2 1080i, libmpeg2 yadif disabled ffdshow_rev2333_20081117-mt.exe:User: 7s, kernel: 0s, total: 7s, real: 8s, fps: 158.8, dfps: 153.2 6.53ms/frame 0.00ms/yadif Same file, yadif double frame rate ffdshow_rev2303_20081106-mt.exe:User: 41s, kernel: 0s, total: 41s, real: 42s, fps: 29.2, dfps: 29.2 34.25ms/frame 27.72ms/yadif -> 100% ffdshow_rev2307_20081107-mt.exe:User: 28s, kernel: 0s, total: 29s, real: 29s, fps: 42.3, dfps: 42.3 23.64ms/frame 17.11ms/yadif -> 162% ffdshow_rev2333_20081117-mt.exe:User: 11s, kernel: 0s, total: 11s, real: 18s, fps: 109.3, dfps: 65.6 15.24ms/frame 8.71ms/yadif -> 318% |
22nd November 2008, 10:33 | #5178 | Link |
strcpy_s and some other secure string manipulation functions were added to the CRT at MSVC8.
http://msdn.microsoft.com/en-us/library/8ef0s5kh(VS.80).aspx https://buildsecurityin.us-cert.gov/...g/317-BSI.html My next patch will use those functions. I also wrote an alternative functions so that we can do without completely dropping MSVC7.1. However MSVC7.1 is not the recommended compiler. Of course the official CRT is better than my code. ICL9 and MinGW 4.0.x may be dropped at the same time. Supporting 6 compilers is a mess. If some of the developers have only MSVC8, it is possible to continue supporting. |
22nd November 2008, 11:30 | #5179 | Link | |
22nd November 2008, 11:36 | #5180 | Link | |
ffdshow/AviSynth wrangler
But honestly I'd keep the MinGW only build, if only to be able to build ffdshow with 100% free tools...
now playing: [artist] - [track] ([album]) |
