19th September 2011, 17:54 | #1481 | Link | |
AviSynth plugger
Fixed today in v2.5.11.3
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
12th October 2011, 17:46 | #1482 | Link | |
What's the deal with pel=2 and assumeframebased()? I read people use it for more speed but documentation only states it is necessary when feeding field based material.
sad6.mt_lut("x x 255 / *") In theory I mean, because mdegrain denoising is limited to the internal mask that is already passed, so we can not get back the denoising we have just lost. What could be done is make the internal mask a more flexible element where masktools can work with, or in the other hand by now find a correlation of the above code and try to match in the internal mask creation (through thSAD, lambda, etc)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 13th October 2011 at 00:44. |
27th October 2011, 23:52 | #1483 | Link | |
Is there a way to increase the performance of this, or is my flow entirely wrong? :
It may be worthy to note I'm using MeGUI 2050 x86, and if my script looks funny, that's because I barely understand what I'm doing with it. Last edited by Dragonshadow; 27th October 2011 at 23:59. |
28th October 2011, 00:33 | #1484 | Link |
Unregistered User
I experienced similar slow times, but I thought that was pretty normal. After all, compensating is a slow process and MflowBlur creates "many copies of partially compensated pixels at intermediate time moments in some blurring interval around current frame".
avi + m2t -> Vdub + DGIndex -> AE CS3 -> x264 -> Hell On Earth Woop, woop! That's the sound of the police! |
28th October 2011, 08:04 | #1486 | Link | |
Also, how would I selecteven to 29.97 from 60p? It's literally 60fps, not 59.94. |
28th October 2011, 17:04 | #1487 | Link |
Unregistered User
Playback 30fps at 99,9% speed? Reflowing the entire video will definitely throw away valuable information per frame, and flow predictions aren't perfect.
28th October 2011, 17:25 | #1488 | Link |
I don't understand what you mean, throwing away information? I'm going to be uploading this to youtube, and last I recall they convert everything to 29.97. If I do it myself ahead of time then I avoid possible encoding and audio sync issues. If mflowfps isn't the best way to reduce from 60fps to 29.97fps, then what is? (Likewise, if mflowblur isn't the best way to add motion estimated blur, what is?)
28th October 2011, 17:49 | #1489 | Link | ||
Unregistered User
To convert 24 fps cinema movies to 25 fps DVD's, the studio's just play the movies 4% faster instead of messing with the frames. To go from 30 fps to 29.97, you could to the same and go 1% slower in stead of regenerating the frames. Quote:
28th October 2011, 19:00 | #1490 | Link |
Small point but 30FPS to 29.97FPS is a reduction of 0.1% not 1.0%.
28th October 2011, 19:17 | #1491 | Link | ||
AssumeFPS("ntsc_video", sync_audio=true) Quote:
Be sure to try with/without to make sure it is an effect you want. |
28th October 2011, 20:20 | #1492 | Link | ||
Unregistered User
That's probably a good point. That's it. That's how they do it in Hollywood. Quote:
31st October 2011, 10:57 | #1493 | Link |
What exactly is the "temporal" flag actually used for with MAnalyse? I'm not sure if I need it or not for blending, and it's the only thing stopping me from going multi-threaded.
Right now I'm trying to figure out what's causing my audio to be out of sync no matter what I do. I'm using megui so the audio is encoded with nero aac encoder before the video is encoded. Last edited by Dragonshadow; 1st November 2011 at 02:55. |
3rd November 2011, 17:55 | #1495 | Link |
Mdegrain does not require any specific levels in Msuper. But MAnalyse does.
Therefore - if you use the same 'super' clip for both MAnalyse and MDegrain, then you need all levels. (Or as much as you want to be used in MAnalyse.) - if you use separate 'super' clips for MAnalyse and MDegrain, then you need all (or as much as...) levels for the super clip of MAnalyse, but can use minimal levels (1) for the super clip of MDegrain.
5th November 2011, 17:15 | #1496 | Link |
Pig on the wing
A small bug noticed: MShow doesn't support 32-pixel blocks. It shows only green borders around the video.
5th November 2011, 17:54 | #1497 | Link |
Pig on the wing
Seems more like there is something wrong with 32-pixel blocks.
Using this script: Code:
DGSource("2001.dgi") Crop(0,112,-0,-112,true) prefilt=FFT3DFilter(sigma=3,bt=3) superanalyse=MSuper(prefilt,pel=1) supermdg=MSuper(pel=1,levels=1) fv1=MAnalyse(superanalyse,blksize=32,dct=5,isb=false,delta=1) bv1=MAnalyse(superanalyse,blksize=32,dct=5,isb=true,delta=1) MDegrain1(supermdg,bv1,fv1,thsad=200) The next frame is overlaid there. If I use blksize=16, there's no problem. The issue occurs at scene changes only.
6th November 2011, 11:38 | #1498 | Link |
Indeed, it looks like the SATD calculation (at least dct=5 and 6, maybe the other SATD modes too) goes totally wrong when blksize=32. I'll take a closer look at this issue soon.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding Last edited by cretindesalpes; 6th November 2011 at 11:50. |
6th November 2011, 17:30 | #1499 | Link |
Pig on the wing
While testing various settings, I noticed that I have to use the same pel for the super clips used in MAnalyse and MDegrain (otherwise I only get a crash). Is this intentional?
6th November 2011, 19:34 | #1500 | Link |
Vectors must have been generated with the same pel setting as the superclip used in the utility functions (MDegrain, MCompensate, etc). Anyway it should definitely output an error message instead of crashing in case of inconsistency.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
