15th June 2010, 06:14 | #1321 | Link | |
Acid fr0g
@turment on Telegram Last edited by tormento; 15th June 2010 at 06:32. |
15th June 2010, 08:08 | #1322 | Link |
"Do you think that the thSAD number is too high or low?"
dunno. "I read in the documentation that a too low number could cause "staggered denoising" but what is a too low number for that parameter?" depends. "As I want remove grain only, do you think I should use a different thSADC for chroma?" dunno. The reason thSAD is a parameter and not hardcoded, is because sometimes you have to change it to get good results. Should you use a different thSADc for chroma? Is there chroma noise? If there is do you want to remove it? Is it the same strength as the luma noise? Denoising is a preference thing anyway.Try different thSAD(c) values and use the one you like the most. |
15th June 2010, 08:24 | #1323 | Link |
Pig on the wing
While we have some more experts in the thread, two simple questions (which probably don't warrant a simple answer :P) : is there really any use using UMH for search method and under what circumstances could MRecalculate prove to be useful?
The reason why I ask these questions is that I have a lot of handheld shot (shaky, that is), grainy 8mm film transfer stuff to process and I want to get the stabilization process work done as well as possible. In addition to this, one long reel is filmed at an enduro race so there's a lot of movement going on pretty much all the time. From what I've been testing things, in these cases using MDepan for creating the log file to feed to Deshaker's second pass is the way to go.
16th June 2010, 03:43 | #1324 | Link |
just for the record, I know absolutely nothing about deshaking video.
That said, I think the most important things to look at will be pre-denoising and adequate motion vector length (I'm not sure what resolution your source footage is, but iirc mvtools could have a restrictive maximum mv length if its really bad, or HD, or both) |
16th June 2010, 13:05 | #1325 | Link |
Pig on the wing
If I've understood correctly (regarding Deshaker at least), the basic idea is for the motion detection engine to lock onto the background or some other static object. Deshaker's 1st pass can be set to ignore motion of blocks falling under certain conditions, for example those blocks whose movement happens in the "wrong" direction. The great thing about MAnalyse is that the settings can be tweaked a lot and the result can be immediately seen with MShow. I was just wondering whether there are options to helping MAnalyse towards the preferred behaviour.
The problem with MDepan is that I don't know which motion vectors are ignored when the stabilization data (hor and ver pan, rotation and zoom per frame) is created (either for DepanEstimate or to a Deshaker-style log file). Fizick, would it be possible to create an MShow-like view of discarded and accepted blocks? Currently tweaking the "wrong" and "range" parameters is practically impossible. Also, what does "range" actually do? Is the parameter coupled with "wrong"?
17th June 2010, 07:45 | #1326 | Link | |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
# film stabilizing script by videoFred. # Version 06/2010 #==================================================================================== # specify the source clip here with full path name film="C:\Documents and Settings\Eigenaar\Mijn documenten\films\Dirk\videofred_002.avi" #GENERAL PARAMETERS #-------------------------------------------------------------------------------------------- result="result2" # specify the wanted output here # result1= stabilized/cropped/resized clip # result2= comparison original vs not cropped stabilized clip trim_begin=0 # trim frames at the beginning # useful to skip fast to a certain scene #SIZE, CROP AND BORDERS PARAMETERS #-------------------------------------------------------------------------------------------- CLeft=20 CTop=20 CRight=20 CBottom=20 #crop values after Depan and before final resizing W=720 H=576 #final size after cropping #STABILIZING PARAMETERS #-------------------------------------------------------------------------------------------- maxstabH=20 maxstabV=20 #maximum values for the stabilizer (in pixels) 20 is a good start value est_left=40 est_top=40 est_right=40 est_bottom=40 # crop values for special Estimate clip # the stabilizer will use this region only est_cont=1.0 # contrast value for special Estimate clip # change this if the stabilizer wont work # END VARIABLES, BEGIN SCRIPT #============================================================================================= # NEEDED PLUGINS #------------------------------------------ Loadplugin("Depan.dll") LoadPlugin("DepanEstimate.dll") LoadPlugin("MT_Masktools.dll") source1= Avisource(film).trim(trim_begin,0).converttoYV12() #STABILIZING #.............................................................................................. stab_reference= source1.crop(est_left,est_top,-est_right,-est_bottom).tweak(cont=est_cont)\ .MT_binarize(threshold=80).greyscale().invert() mdata=DePanEstimate(stab_reference,trust=1.0,dxmax=maxstabH,dymax=maxstabV) stab=DePanStabilize(source1,data=mdata,cutoff=0.5,dxmax=maxstabH,dymax=maxstabV,method=1,mirror=15) stab2= stab.crop(CLeft,CTop,-CRight,-CBottom).Lanczos4Resize(W,H) stab3=DePanStabilize(source1,data=mdata,cutoff=0.5,dxmax=maxstabH,dymax=maxstabV,method=1,info=true) WS= width(stab) HS= height(stab) stab4= stab3.addborders(10,10,10,10,$B1B1B1).Lanczos4Resize(WS,HS) result1=stab2 #SPECIAL SERVICE CLIP FOR COMPARISON #................................................................................................ service_clip= overlay(source1,stab_reference,x=est_left,y=est_top)\ .addborders(2,2,2,2,$FFFFFF).Lanczos4Resize(WS,HS) #SPECIAL COMPARISON CLIP FOR TESTING THE STABILIZER #....................................................................................................... result2= stackhorizontal(subtitle(service_clip,"baseclip for stabilizer -only the B/W clip is used",\ size=32,align=2),subtitle(stab4,"test stabilizer: dx=horizontal, dy=vertical",size=32,align=5)) Eval(result) Only this information will be used for DepanStabilize(). Result2 will show you all the needed information. Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
17th June 2010, 10:54 | #1327 | Link |
Pig on the wing
The problem is that the region changes in each scene, sometimes during the scene With 4.5hrs of material to process, I'm trying to automate things as much as possible (even to the extent that I've butchered your restoring script a bit and turned it into a bloated function )
17th June 2010, 11:29 | #1328 | Link | ||
Fred.
17th June 2010, 11:49 | #1329 | Link |
Pig on the wing
Sure, after I've cleaned it up a little Even after that I know I'll be embarrassed to post it, but let's see if someone could enhance it further. For some reason I've never been able to get the Eval blocks work correctly with boolean operators.
17th June 2010, 11:58 | #1330 | Link |
Very good. When you are ready, please post it in the 'Power of Avisynth' thread.
Thank you in advance Boulder! Fred.
17th June 2010, 13:50 | #1332 | Link | ||
Pig on the wing
I'll also post one difficult scene to stabilize, unless DepanStabilize manages to fix it. For now I've had to edit the Deshaker log file from MDepan manually to avoid sudden jumps in the stabilized video. Quote:
17th June 2010, 20:17 | #1333 | Link |
Pig on the wing
By the way, what are the correct resizing parameters for creating a pelclip (both luma and chroma since I'm using YV12) for pel=4?
For pel=2 it's (width*2,height*2,src_left=0.25, src_top=0.25) for luma and (width*2,height*2,src_left=0.5, src_top=0.5) for chroma but should all the parameters be doubled for pel=4?
18th June 2010, 08:17 | #1335 | Link |
viterra
Help properly configure MVTools that there were no ghosts and sailing parts of the image with the brightness variations. For this sample http://www.mediafire.com/?mrdkatnmyqd
And if it possible - keep thSAD = 400 and limit = 255. sample.avs included. Last edited by Vitaliy Gorbatenko; 18th June 2010 at 09:58. |
19th June 2010, 01:08 | #1336 | Link |
ангел смерти
Boulder, if you have a good script, I'll test it on the BD of Blade Runner. They butchered that: there's so much gate weave throughout the film that I can't watch it until I fix it. Either the camera was wobbling the entire time, or no one bothered to lock down the telecine.
19th June 2010, 09:45 | #1337 | Link |
Pig on the wing
This is what I've been using as my latest attempt:
AVISource("w:\nimeton 1.avi",pixel_type="YUY2") block_size=16 block_size_recalc=8 lambda= 100*block_size*block_size/64 lambda_recalc= 100*block_size_recalc*block_size_recalc/64 lsad= 400*block_size*block_size/64 Crop(16,16,-16,-16,true).ConverttoYV12() Unflicker() cleaned=DegrainMedian() pelclipluma=Spline64Resize(width*4,height*4,src_left=0.375, src_top=0.375) pelclipchroma=Spline64Resize(width*4,height*4,src_left=0.75, src_top=0.75) pelclip=pelclipluma.MergeChroma(pelclipchroma) supaclip=MSuper(pel=4,rfilter=4,pelclip=pelclip) supacliprecalc=MSuper(cleaned,pel=4,rfilter=4,pelclip=pelclip,levels=1) vec=Manalyse(supaclip,truemotion=false,global=true,blksize=block_size,overlap=block_size/2, \dct=5,search=5,searchparam=8,lambda=lambda,lsad=lsad,plevel=0,pnew=25,badsad=400,temporal=true) # temporal=false if SetMTMode is called vecrecalc=MRecalculate(supacliprecalc,vec,truemotion=false,blksize=block_size_recalc,overlap=block_size_recalc/2, \dct=5,search=5,searchparam=8,lambda=lambda_recalc,pnew=25,thsad=100) MDepan(last,vecrecalc,error=80,thscd1=625,thscd2=160,info=true,wrong=3,zoom=false,range=0,log="w:\deshaker\nimeton 1.log") function Unflicker (clip o) { screen = mt_lutf(o,o,mode="average",yexpr="x",U=1,V=1) #.greyscale screenTS = screen.temporalsoften(1,9,0,9,2).merge(screen,0.249).temporalsoften(2,5,0,5,2) calmed = o.mt_makediff(mt_makediff(screen,screenTS),U=2,V=2) deflk = o.Deflicker() masky = o.mt_lut("x 32 < x 16 - 16 * x 204 > 255 204 x - abs 255 30 / * - 255 ? ?").removegrain(11,-1) return o.mt_merge(calmed,masky,U=2,V=2) } I've used the script to create a log file to feed to Deshaker and run the 2nd pass there with only ConverttoRGB24(matrix="pc.601") in the script. I noticed that limiting correction to 2 percent will eliminate most shakiness coming from handheld camera movements (not to mention that some scenes have been shot by a 60-70 -year-old person). It could be that even 1 percent is enough for your purposes. Unflicker is for removing the slight flickering in the source material. Deshaker 2nd pass settings that I've used: If you or anyone else has any suggestions to improve things, please let me know Oh, one more bug report to Fizick: if I try to set pel=2 in the MSuper statement that is then fed to MRecalculate, VDub crashes after advancing one frame. This occurs if the MSuper clip that is fed to MAnalyse uses pel=4.
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 19th June 2010 at 09:47. |
19th June 2010, 18:21 | #1338 | Link |
I've done two projects in the past months which involved 16+ hours of 8mm, Super8, and 16mm. The more recent project was 8+ hours. So, I know what it is like to try to get through a lot of film.
You might want to consider some alternative workflows if you want to do more deshaking. First, if you Google my name (John Meyer is my real name) and Deshaker, you will find both a Deshaker guide I wrote, as well as a script I wrote which automates the Deshaker process from within the editing program, Sony Vegas. Another person has taken my script, added a UI that mimics Deshaker, and created a DLL version of the script. If you have Vegas, or if you are doing this for a living and therefore can charge off the purchase of Vegas, you will find this permits a workflow that completely gets around the scene change problem (although Deshaker does have a scene change flag) and also permits you to do really advanced motion stabilization that would either be impossible with depan, or which would just take too much time. The short version of what I do is to first run an AVISynth scene detection script on my film capture. This gives me frame numbers for the scene changes. This isn't perfect, but it is good enough, and if I miss a few scene changes it doesn't matter much. I then use these numbers to automatically (one click) cut the film in Vegas into individual scenes. Then, the Deshaker script is run on each individual scene, something that can be done in batch mode, so you just click once and walk away for a few hours. The stabilized footage is added to each scene in Vegas as a "take." This means that if the stabilization screws up (which does happen), you just press a button to return to the original. Now, what I have found with VideoFred's script is that the depan works amazingly well for gate weave and simple camera shake. True, it does force you to zoom in to hide the resulting stabilization black borders, whereas Deshaker has the ability to synthesize new borders. However, as long as you are doing small corrections, you don't have to zoom in much, and the compromise is IMHO not bad. So, my new workflow is to do a quick scrub through the film, and find scenes that I think need the "heavy duty" stabilization. I then only run Deshaker on that. Then, when that is finished, I frame serve the result into VideoFred's script. None of this may be useful if you don't use Vegas, but perhaps it gives you some ideas for an alternate workflow. The idea of trying to do anything with AVISynth that has to be changed scene-by-scene sounds too painful to contemplate, especially when dealing with many hours of material. |
24th June 2010, 21:48 | #1340 | Link | |
AviSynth plugger
(also fixed info in MDepan)
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 24th June 2010 at 23:09. Reason: just released! |
