17th February 2010, 23:16 | #1302 | Link |
Ok, I've run in to a little problem. The filter has a tendency to undercorrect fast motion--and I suspect the cause is MFlow's limitation of any vector over 127 being thrown out. Whether it happens depends on the resolution of the video and what "pel" value one is using. I need to find a workaround. If I use pel=1, it fixes it on lower resolutions, but also causes jaggies. I tried using MRecalculate, but as I expected, it did not help. I thought about trying MFlowInter, but it only seems able to generate an in-between frame, and I want to simply warp the current frame toward its neighbors. Any suggestions? I'd really like to make this work, one way or another.
EDIT: I tried MFlowInter, not only did it add undesirable frame blending, but it also did not fix the problem. Last edited by um3k; 18th February 2010 at 00:54. |
25th February 2010, 10:56 | #1303 | Link | |
This question more properly resides here under the MVtools thread, I think.
1st March 2010, 17:23 | #1304 | Link | |
I just got a crash using AviSynth 2.5.8 SEt's MT mod and VirtualDub points to mvtools2.dll.
VirtualDub crash report -- build 32809 (release) -------------------------------------- Disassembly: 02f64660: 660f6fda movdqa xmm3, xmm2 02f64664: 660f61da punpcklwd xmm3, xmm2 02f64668: 660f70d300 pshufd xmm2, xmm3, 00h 02f6466d: 660f6eda movd xmm3, edx 02f64671: 8b5520 mov edx, [ebp+20h] 02f64674: 660f6fe3 movdqa xmm4, xmm3 02f64678: 660f61e3 punpcklwd xmm4, xmm3 02f6467c: 53 push ebx 02f6467d: 660f70dc00 pshufd xmm3, xmm4, 00h 02f64682: 660f6ee0 movd xmm4, eax 02f64686: 56 push esi 02f64687: 8b7510 mov esi, [ebp+10h] 02f6468a: 660f6fec movdqa xmm5, xmm4 02f6468e: 57 push edi 02f6468f: 8b7d08 mov edi, [ebp+08h] 02f64692: 660f61ec punpcklwd xmm5, xmm4 02f64696: 660fefc0 pxor xmm0, xmm0 02f6469a: 660f70e500 pshufd xmm4, xmm5, 00h 02f6469f: c744240c100000 mov dword ptr [esp+0ch], 00000010 00 02f646a7: 2bd1 sub edx, ecx 02f646a9: 2bf1 sub esi, ecx 02f646ab: 8bc1 mov eax, ecx 02f646ad: 2bf9 sub edi, ecx 02f646af: bb02000000 mov ebx, 00000002 02f646b4: eb0a jmp 02f646c0 02f646b6: 8da42400000000 lea esp, [esp+00] 02f646bd: 8d4900 lea ecx, [ecx+00h] 02f646c0: f30f7e2c02 movq xmm5, [edx+eax] 02f646c5: f30f7e30 movq xmm6, [eax] 02f646c9: 660f60e8 punpcklbw xmm5, xmm0 02f646cd: 660fd5ec pmullw xmm5, xmm4 02f646d1: 660ffde9 paddw xmm5, xmm1 02f646d5: 660f60f0 punpcklbw xmm6, xmm0 02f646d9: 660fd5f3 pmullw xmm6, xmm3 02f646dd: 660ffdf5 paddw xmm6, xmm5 02f646e1: f30f7e2c06 movq xmm5, [esi+eax] <-- FAULT 02f646e6: 660f60e8 punpcklbw xmm5, xmm0 02f646ea: 660fd5ea pmullw xmm5, xmm2 02f646ee: 660ffdee paddw xmm5, xmm6 02f646f2: 660f71d508 psrlw xmm5, 08h 02f646f7: 660f67e8 packuswb xmm5, xmm0 02f646fb: 660fd62c07 movq [edi+eax], xmm5 02f64700: 83c008 add eax, 08h 02f64703: 83eb01 sub ebx, 01h 02f64706: 75b8 jnz 02f646c0 02f64708: 8b7d08 mov edi, [ebp+08h] 02f6470b: 8b7510 mov esi, [ebp+10h] 02f6470e: 8b5520 mov edx, [ebp+20h] 02f64711: 037d0c add edi, [ebp+0ch] 02f64714: 037514 add esi, [ebp+14h] 02f64717: 035524 add edx, [ebp+24h] 02f6471a: 034d1c add ecx, [ebp+1ch] 02f6471d: 836c240c01 sub dword ptr [esp+0ch], 01h 02f64722: 897d08 mov [ebp+08h], edi 02f64725: 897510 mov [ebp+10h], esi 02f64728: 895520 mov [ebp+20h], edx 02f6472b: 0f8576ffffff jnz 02f646a7 02f64731: 5f pop edi 02f64732: 5e pop esi 02f64733: 5b pop ebx 02f64734: 8be5 mov esp, ebp 02f64736: 5d pop ebp 02f64737: c3 ret 02f64738: cc int 3 02f64739: cc int 3 02f6473a: cc int 3 02f6473b: cc int 3 02f6473c: cc int 3 02f6473d: cc int 3 02f6473e: cc int 3 02f6473f: cc int 3 02f64740: 55 push ebp 02f64741: 8bec mov ebp, esp 02f64743: 83e4f0 and esp, 0f0h 02f64746: 51 push ecx 02f64747: 0fbf4d28 movsx ecx, word ptr [ebp+28h] 02f6474b: 0fbf552c movsx edx, word ptr [ebp+2ch] 02f6474f: b880000000 mov eax, 00000080 02f64754: 660f6ec8 movd xmm1, eax 02f64758: 0fbf4530 movsx eax, word ptr [ebp+30h] 02f6475c: 660f6fd1 movdqa xmm2, xmm1 Built on Aegis on Sat Feb 20 22:12:08 2010 using compiler version 1400 Windows 6.1 (Windows Vista x86 build 7600) [] EAX = 1be01728 EBX = 00000002 ECX = 1be01728 EDX = ff3a0000 EBP = 0addf1c8 ESI = e41fe8d8 EDI = ec207af0 ESP = 0addf1b0 EIP = 02f646e1 EFLAGS = 00010287 FPUCW = 027f FPUTW = ffff Crash reason: Access Violation Crash context: An out-of-bounds memory access (access violation) occurred in module 'mvtools2'... ...reading address 00000000. Pointer dumps: EAX 1be01728: 393b3b3b 39393938 8d7b5938 9190918f 93919091 95949592 91919190 91919091 ECX 1be01728: 393b3b3b 39393938 8d7b5938 9190918f 93919091 95949592 91919190 91919091 ESP 0addf1b0: 07f5e8e8 07fb4628 07f5e838 00000010 00000000 00000248 00000000 02f62cbd 0addf1d0: 08009218 00000010 00000000 000002e0 1be01728 000002e0 1b1a1728 000002e0 0addf1f0: 00000058 00000054 00000054 00000004 0288f968 00000001 00000000 000000fe 0addf210: 000002e0 010102e0 00000000 00000000 00000000 1be01728 000002e0 00000001 EBP 0addf1c8: 00000000 02f62cbd 08009218 00000010 00000000 000002e0 1be01728 000002e0 0addf1e8: 1b1a1728 000002e0 00000058 00000054 00000054 00000004 0288f968 00000001 0addf208: 00000000 000000fe 000002e0 010102e0 00000000 00000000 00000000 1be01728 0addf228: 000002e0 00000001 1b1a1728 00000054 00000001 00000000 000002e0 00000170 Thread call stack: 02f646e1: mvtools2!_AvisynthPluginInit2@4 [02f50000+6740+dfa1] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 1005417a: AviSynth!DllGetClassObject [10000000+da50+4672a] 02ec9f71: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+d211] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 1005417a: AviSynth!DllGetClassObject [10000000+da50+4672a] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 02ec3e38: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+70d8] 02ec199d: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+4c3d] 02ec1a3c: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+4cdc] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 02ec9f71: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+d211] 02ec78c8: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+ab68] 02ec31f1: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+6491] 02ebbfc1: mt_masktools!0002bfc1 02ed1bea: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+14e8a] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 02ec6f88: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+a228] 02ec9e10: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+d0b0] 02ec199d: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+4c3d] 02ec1a3c: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+4cdc] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 02ec7d68: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+b008] 02ebc377: mt_masktools!0002c377 02ec3f70: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+7210] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 02ec1bc1: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+4e61] 02f61b93: mvtools2!_AvisynthPluginInit2@4 [02f50000+6740+b453] 02ec9e10: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+d0b0] 02ec199d: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+4c3d] 02ec1a3c: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+4cdc] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 02ec78c8: mt_masktools!_AvisynthPluginInit2@4 [02e90000+2cd60+ab68] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 7c3416b3: MSVCR71!__crtLCMapStringA [7c340000+13ae+305] 100372e6: AviSynth!DllGetClassObject [10000000+da50+29896] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 1006492e: AviSynth!DllGetClassObject [10000000+da50+56ede] 771e2149: ntdll!RtlAllocateHeap [77190000+5209d+ac] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 1003bd40: AviSynth!DllGetClassObject [10000000+da50+2e2f0] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 7c3416b8: MSVCR71!__crtLCMapStringA [7c340000+13ae+30a] 1006492e: AviSynth!DllGetClassObject [10000000+da50+56ede] 7c3416b8: MSVCR71!__crtLCMapStringA [7c340000+13ae+30a] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 1000464d: AviSynth!0000464d 1005533b: AviSynth!DllGetClassObject [10000000+da50+478eb] 10005337: AviSynth!00005337 10005407: AviSynth!00005407 1005627b: AviSynth!DllGetClassObject [10000000+da50+4882b] 771d5e6c: ntdll!NtWaitForSingleObject [77190000+45e60+c] 754a179c: KERNELBASE!WaitForSingleObjectEx [754a0000+1730+6c] 754a17c4: KERNELBASE!WaitForSingleObjectEx [754a0000+1730+94] 10009559: AviSynth!avs_release_value [10000000+75d0+1f89] 1000adb7: AviSynth!avs_release_value [10000000+75d0+37e7] 1000e2cd: AviSynth!DllGetClassObject [10000000+da50+87d] 76b71194: kernel32!BaseThreadInitThunk [76b20000+51182+12] 771eb3f5: ntdll!RtlInitializeExceptionChain [77190000+5b392+63] 771eb3c8: ntdll!RtlInitializeExceptionChain [77190000+5b392+36] -- End of report |
4th March 2010, 19:37 | #1305 | Link |
I suppose this is quite obvious, but unfortunately the best and fastest way to fix any bug is to replicate it. This involves finding the simplest test case that triggers it.
1) which filters are needed / is it dependent on a specific input video (or source filter) / does it depend on specific options in the filters? (this helps pinpoint which filter / which part of a filter is responsible) 2) how fast does it occur? (first frame / <1000 frames / >50000) 3) is it always on the same frame (+-10 frames)? 4) Is there a relationship with other system components - like maxed out CPU load or network traffic? 5) And since you mentioned MT - is there a difference on the amount of threads used? I suppose it never occurs single-threaded?
GA-P35-DS3R, Core2Quad Q9300@3GHz, 4.0GB/800 MHz DDR2, 2x250GB SATA HD, Geforce 6800 Last edited by TSchniede; 4th March 2010 at 19:38. Reason: typo |
2nd June 2010, 20:57 | #1308 | Link |
AviSynth plugger
i do not like the limitation of vector length to 64 (for pel=2).
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
4th June 2010, 16:32 | #1310 | Link |
I have a suggestion for you guys (Terka, Fizick, et al.) to think about...
We have the function MMask, which can convert MVTools2's vector data into a "normal" clip, where, using kind=5, colours (in U,V) represent motion vectors (in X,Y). Could we have a function that does the inverse of this, i.e. turns the "kind=5" colourmap back into a vector clip (such as produced by MAnalyse), suitable for driving MCompenstae, Mflow, etc.? This would then open the door to manipulating vector data using various avisynth functions, and applying the results to the source clip. For example, to obtain a map of the *acceleration* over three frames, you could do: MotionMap = MMask(Source, Vectors, kind=5) AccelMap = Subtract(MotionMap, MotionMap.DeleteFrame(0)) ... and then use that data, via the new function (called, perhaps, "MUnmask"?) to create a parabolic, rather than linear, interpolation of the motion between frames n-1 and n+1. Take things one step futher, and you've got cubic interpolation, and so on. You could also apply a combination of masks and blurs to a motion map before using it in compensation, to create an effect similar to varying the mvtools "lamda" factor (vector coherence) across the frame, depending on detected content. I.e., you could enforce higher vector coherence (strong "blur" of U & V data) where regular textures/patterns are detected, but reduce it where an edge is detected between two separately moving objects. Lots of possibilities open up for more precise, or more creative, motion manipulation! =:o} Interested? (Hmmm... Should I putting this in development?) Last edited by pbristow; 4th June 2010 at 16:37. |
4th June 2010, 18:14 | #1312 | Link |
Pig on the wing
Edit: never mind, I got it..MDepan must be returned in order to create a log file.
4th June 2010, 18:36 | #1313 | Link |
MVtools are esencial avisynth plugin. So every development of them is big plus. I think the vectors modifying could be useful.
There aslo exists some 'requests' about what new feature(s) to have, Didee posted some here in forum. Maybee he could have something to say. Also there are some papers over internet about phase correlation etc. |
4th June 2010, 19:59 | #1314 | Link |
Pig on the wing
A bug report: if I use range=1 in MDepan, the debug text (with info=true) is only displayed in the first frame when loading the script. It disappears when seeking to the next frame.
14th June 2010, 19:06 | #1315 | Link |
Acid fr0g
One question: is MDegrain3 more precise and stronger or only stronger in removing noise?
I'd like to use as a standard avs part a very light grain removal part to increase compressibility without remove too much details. I am thinking about a thSAD=200 or so with the usual motion compensated denoise script of the documentation. Do you think that the thSAD number is too high or low? I read in the documentation that a too low number could cause "staggered denoising" but what is a too low number for that parameter? As I want remove grain only, do you think I should use a different thSADC for chroma? And, returning to my first question, as far as PRECISION and DETAILS are concerned, is it better to use MDegrain3 or MDegrain2?
@turment on Telegram |
14th June 2010, 20:05 | #1316 | Link |
In that sense, there is no "precision" in MDegrainX. The "precision" is in MAnalyse.
Before we had MVTools, the problem was that the dumb PC could not distinguish between noise and detail. Now that we have MVTools, the problem is that the dumb PC still can't distinguish between noise and detail. What has changed is that, due to motion compensation, the likelyhood to catch more noise than detail has become bigger. But the basic problem hasn't changed. Good old TemporalSoften uses differences between single pixels to make its decisions. Shiny new MVTools uses differences between single pixels, summed up over 8x8 blocks, to make its decisions. The method as a whole has become more robust, but the mechanism of making decisions is still the same. ("Hey! Now there is weighting, too!" -- [bored:] "ttempsmooth!")
14th June 2010, 22:00 | #1317 | Link | |
Also, "its just differences of blocks of pixels instead of singly pixels" rather misses the point. VQ is just quantizing blocks of pixels instead of single pixels, but the coding gain is ridiculous. And its ridiculous because working on blocks of pixels is not comparable to working on single pixels. When dealing with blocks, even if your metric is incredibly simple, you are matching features whenever you do a block search, you can't do block matching without getting some feature detection. This combined with the higher signal correlation between frames as opposed to pixels within a frame are why mvtools is so good. The high correlation allows for fast metrics and lazy pixel grouping to work very well, thereby enabling a "fast" implementation. You can actually apply the same methodology to pixels within a frame (which is basically what tnlmeans does) but because correlation is so much lower, you have to have much more granular pixel grouping to get usable results, and to get truly good result you would probably need a much better metric then sad or sse as well. |
14th June 2010, 22:06 | #1318 | Link |
Acid fr0g
Guys, your knowledge is fascinating but is it better, precision related, Degrain2 or Degrain3?
Didée, you told precision is in MAnalyse. Do you think that using Degrain3, as far as precision is concerned, is similar do Degrain2 if the same MAnalyse process is used? If positive, does Degrain3 removes only more noise? I thought that thSAD was the only parameter that decided the amount of noise (let me say that) to be removed. You overwhelmed me.
14th June 2010, 23:14 | #1319 | Link | |
mp4guy - hey, of course I have exaggerated a bit, wasn't that obvious? I just wanted to make the point that the algorithms still aren't "seeing" anything. And, even with (inherently) better feature correlation, turing's machine still will not tell apart whether any given difference is due to a change in a detail's reprentation from one frame to the next, or because of noise, or because of something else. It's just a difference.
In particular, any "weak" detail that is "hidden" below the noise (signal amplitude of detail is same - or even lower - than the noise level) by chance might survive, or by chance will get filtered away. Dice game. Quote:
tormento: MDegrain3 removes more noise. MDegrain2 keeps more detail. That's basically it. If you guys insist, I'll dig out my Babylon-5 samples once more. SAD fights a losing battle there. And SATD won't do better.
15th June 2010, 04:30 | #1320 | Link | ||||
All of that said I think we are essentially in agreement and that I am just quibbling over terminology (that I still don't agree with) but that is irrelevant to the actual point.Also, no offense was meant, there was just a certain ways your previous comment could have been read that bothered me. |
